Question about Garden
Karcher 3.99 electic pressure washer. Compressor/pump run but do not build up high pressure.
  • 636 Answers
I have had a problem similar in the past , mine is gas powered and all it was was the o-rings were worn out and was by-pasting on the wond. It could be also the electic control switch is fault on that model. Hope this helps.
Posted on Jul 26, 2009
    President:
  • 583 Answers
Check filter and manually adjust pressure by screwing down---clockwise thebrassnut on the outlet side
Karcher K2.94 intermittent pumping and buzzing
try the machine with the lance removed from the gun.
buzzing is usually the noise made by the motor when it cant turn. if the pump start to pruduce pressure but the pressure builds up too high then the motor will stop turning... faulty lance or faulty spill valve (dump valve)
If you have a Karcher then you should always post your machines barcode.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Aug 05, 2013 | Garden
When machine is just sitting when on, motor kicks in & out ( pulsating)
sounds normal. Unloader opens because pressure is too high. Pressure goes down and unloader closes. Pressure builds and the unloader opens again Leave it running like that and the water will heat up. If you have a thermo valve it will protect you a little. One of the fastest ways to destroy your pump is to let it run for long periods without using it.
Jan 12, 2013 | Karcher Garden
Karcher 3.99 Pump runs but same pressure as garden hose
The pump could be rebuilt i has three cylinders on a type of cam. The pistons have o-rings that can be changed. Take the chance and layout your parts as you take apart and take pic as you go.
Mar 03, 2018 | Karcher K 5.85 M Electric Pressure Washer
Karcher K4.97M electric waterblaster cycling
It sounds to me like the unloader valve is bypassing internally.
Nov 16, 2009 | Karcher K2.26 Electric Power Washer
Troy bilt pressure washer will not build or reach high pressure
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
Sep 04, 2009 | Karcher 2500 PSI Pressure Washer
Karcher Power Washer that surges up and down with water pressure.
Before you start it up:
1. Disconnect the high pressure hose 2. Connect the water supply and turn on 3. Make sure water is flowing through the pump
Start the motor, run for about 10 seconds and then turn off.
Turn off the water supply, connect the high pressure hose, turn water back on, start the motor and away you go.
May 29, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 620m runs but will not pump water
The pump that connects to the motor could be bad/and or loose
May 10, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2500 no pressure problem
sounds like you have an inlet blockage to the pump or not enough volume to feed the pump. make sure hose is turned full on when washing and see what happens. if not you may have to remove adapter wher hose screws in and check for a blockage.
Jul 13, 2008 | Karcher 2500 PSI Pressure Washer
Karcher HD 655 S Does not come up to full pressure
yes...check the check valve. A one-way directional valve, this part is also known as a DUMP valve. It opens when too much pressure builds in the hand wand (when not spraying water) in order to protect the pump, by returning the high pressure to its source reservoir. I suspect the DUMP valve is stuck in open condition (or nearly open).
Jun 10, 2007 | Karcher 2500 PSI Pressure Washer
Garden Logo
123 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
