Sub-Zero 632 / S
Problem for Sub-Zero 632 / S
Sub zero 532 ice maker
By drrob1950 on Nov 21, 2007
My ice maker is jammed. I can feel the frozen water, but it won't empty. I need instructions on how to remove the ice maker and replace with new one, if necessary.
Same Problem
Oct 11, 2009
-   hotpoint gsx22gr not filling ice trays ,water works-   windydaywind
May 16, 2009
-   My 532 is not filling the ice tray,"no water comes out the filler tube".It was first over filling and dumping below.Then it just stopped filling the ice tray up with water.....??????????
Scott -   handiscotty
Dec 30, 2008
-   my # 532 subzero isn't fillingl the ice maker tray with water???/-   rosecoltseam
Jun 18, 2008
-   Ice maker makes and dumps ice, but also dumps water in bin, creating nice BIG single ice"cube"! Need help in how to "get into" ice maker. (Drawing would be helpful.)-   Guest
Jun 08, 2008
-   Model 532 (mfg Ap '96) All ice cubes come out ok but into a block in the collection bin. -   Guest
Best Solution
posted on Jun 30, 2008
Very Helpful)
bl_wagner
Rank: Apprentice
Rating: 95%, 7 votes
When my repair tech came out, he showed me that the fill tube sometimes retracts toward the rear of the freezer. He simply pulled it forward with a pair of needle nose pliers until it rested in the delivery reservoir. This placement allows the detector to know when the tray is full and shut off; thus not overfilling the freezing tray and/or splashing additional water onto the freezer wall and into the ice cube drawer.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Jul 01, 2009
Not Rated)
bkfixman
Rank: Apprentice
Rating: 0%, 0 votes
My sub-zero 532 constantly stops making ice because the fill tube gets frozen solid with ice not allowing water to enter the ice tray. I periodically ( every month), remove everything from the freezer, warm the tube till the ice thaws and flows out, then replace everything and it works for a month or so. This months Popular Mechanics discusses a similar issue and suggests the water solenoid has a slow leak, thus allowing water to "drip". I can see how slow moving drips of water can freeze up the fill tube. So I am now looking for the correct solenoid water valve an hope this will do the job.
Was this helpful?
Yes
No
Solution #3
posted on Aug 14, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I ordered a replacement ice maker from a local appliance store and it cost $259. There are 3-screws that hold the ice maker in place and an additional 2 screws that hold the lever arm in place. Once you've removed the screws, pull the unit forward and remove the cover on the left end of the unit. Pull on the wire harness while pushing down on the plastic latch that holds the harness in place (you can only access this latch by removing the cover on the left end of the unit). Install in reverse order. Took me about 15 min to replace. Took me about another 4 hours to realize that it wasn't working b/c the ice-maker switch had been turned off!
Popular Solutions for Sub-Zero 632 / S
Questions and Unsolved Problems for Sub-Zero 632 / S
Do you recommend Sub-Zero 632 / S?
Answer
Answer
refrigerator is not cooling but freezer side is
Answer
Water pooling in bottom of refigerator side alreadyreplaced the door seals
13 Other Users Have The Same Problem - Continued
Comment by subzero man, posted on Jun 01, 2008
Mysub zero 532 will make and discharge ice cubes but it does not refill with water. How do I trouble shoot this? Is the water tube blocked perhaps or is the watervalve defective? Is it something else? How do I troubleshoot this problem? Where is the water valve located?
Comment by classi, posted on Feb 16, 2008
My 532 ice maker quit working after removing the ice drawer as well, had a tech out said I needed to replace the ice maker at $500. Part of that charge is travel as I live outside any major cities. I wonder if anyone has replaced this ice maker and how difficult it would be to do? Also I assume you can order direct but have no idea on the cost.
Any response would be appreciated.
My 532 ice maker quit working as well, a tech came out and said it needed to be replaced $500. Part of this is due to travel as live outside any major city, has anyone replaced this themselves and how difficult was it? I assume you can order direct but have no idea on cost.
Any input would be appreciated
Comment by KLHandy, posted on Feb 09, 2008
My sub-zero ice maker not making ice.
Comment by sellwithsam, posted on Feb 07, 2008
RE: Model 532 (mfg Ap '96) All ice cubes come out ok but then refill water is excessive, re-filling tray plus a quart or so more... which freezes into a block in the collection bin.
Any idea what's wrong?
Comment by caforres, posted on Jan 19, 2008
I have the same problem. What heater bulb may be faulty, where is it?
Comment by upnorth, posted on Dec 11, 2007
I, too, have a 532 Sub-zero icemaker that not only makes ice cubes but also delivers water to the ice colection box which ultimately freezes in the bottom of the collection box.
In an earlier suggestion, when commenting on the cubes not leaving the tray, there was mention of a bulb which defrosted the cubes just before injection. Where would that bulb be located? Perhaps my problem is that the liquid water is attempting to fill an ice tray that is full of ice cubes and therefore overflows into the colection box.
Comment by rjison, posted on Dec 08, 2007
There is a heater bulb that is used to defrost the ice prior to releasing it from the maker. When the bulb fails the ice maker freezes up.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sub-Zero 632 / S:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(816) 471-5334
* Please Contact us for More Information
At Your Service Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
