Question about Kingston flash memory card - 256 MB - MMCplus Graphic Card
My memory card
I have a Kingston memory card of 256MB and was surprised one day to see this message on my photo camera "memory card error".
What am I supposed to do then??
Any advice please.
    President:
  • 2,559 Answers
Try formating option on the camera
Posted on Jul 26, 2009
Memory Error
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Sep 30, 2012 | Pentax X70 Digital Camera
Hi there, I purchased an SDC02G Kingston Taiwan 2GB micro SD card to take holiday photographs which are very important to me. When i returned home from my holiday i was veiwing my pictures when i dropped...
First of all, do not save any new file to camera's memory card.
Take out memory card, and connect it to computer using a card reader. You should see memory card shown as a drive letter (like H:) in Windows Explorer.
Download asoftech photo recovery software
http://www.asoftech.com/apr/
Install and open the photo recovery software, select the memory card, and click 'Start' button.
Mar 21, 2011 | Kingston 2GB Secure Digital Memory Card
Hello sir, i have 4gb kingston digital memory card.And music are copied into it that is going on .but i am getting memory card error when memory card is in camera
Check the manuals of your Camera see if it supports up 4GB of Memory. Also note that some cameras can only take a particular kind of memory card confirm that your camera supports Kingston.
Oct 28, 2010 | Kingston 4GB Secure Digital High Capacity...
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
1GB Memory Card
try another card - 1Gb is like $10-$15 these days.
Feb 24, 2009 | Ricoh Caplio R5 Digital Camera
Memory card error
Hi michellefwon,
Try the card in your computer using a SDHC card reader to see if it will read your picture files. If that doesn't work then you'll have to shop for data recovery software on line. Ontrack Data Recovery is a very reputable recovery company. They offer recovery services by sending them your card or by purchasing their do-it-yourself software.
Their Website:
http://www.ontrackdatarecovery.com/
Kingston Tech Support
Jan 14, 2009 | Kingston 4GB Secure Digital High Capacity...
Memory card
Hi!
Maximum memory size for your camera is 256MB (according to the manual). However, some users claim that the camera can support up to 512MB. To be safe, just use a 256MB card.
Good luck and have a nice day!
Oct 02, 2008 | Olympus Camedia C-350 Digital Camera
Memory card error
did you try pluging the card into the pc using a card reader
May 01, 2008 | Archos AV400 Digital Media Player
Card error on my memory card
i have sold kingston sandisk and pny cards for years-sandisk excellent pny fine kingston is ****-made by pny but just not the same-switch card out asap and change brands-cards are slow and unreliable
Nov 20, 2007 | Casio Exilim Card EX-S100 Digital Camera
Message Display
sometimes this problem occures due to defective or fake memory media. try using a good branded card.
Sep 09, 2006 | Panasonic Lumix DMC-FZ10 Digital Camera
Computers & Internet Logo
60 people viewed this question
Top Kingston Computers & Internet Experts
Cleverer2
Computer Links
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
