Linksys Wireless-G WRT54G Router Logo
Posted on Jul 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't Send My Huawei EC228 Connection to My Router from my PC
I have the Huawei EC228, and a WRT54G Linksys Router. I want to use the connection from the EC228 and send it to my router with an ethernet cable from my PC so I can connect wirelessly with my laptop? Any help? Please give step by step instructions if you know how.
Anonymous
Level 3:
President:
  • Master 2,559 Answers
  • Posted on Jul 26, 2009
Anonymous
Master
Level 3:
President:
Answers
2559
Questions
Helped
1213044
Points
9283
Only way that can be done is to unplug it from the pc and plug it into the laptop,But if your laptop has built in wireless,you can connect directly to the router via wireless connection.
It was working fine until ive reset my linksys wrt54g, and i did my setup again, but i dont get any internet connection, my linksys is using a cable to my pc. please help
When you resetted your linksys router, chances are, the setup for WAN connection was lost. You can try these steps:
1. Connect the internet directly to your pc. If your pc was able to browse the internet, move on to the next step. If not, you'll have to contact your ISP for the settings of your internet connectivity.
2. Connect back the internet to the WAN port of the router, and connect your pc to the router's LAN port.
3. Open the router's page in a browser (the address usually is 192.168.1.1, username is admin and password is admin)
4. If your router has a setup wizard, run the setup wizard, because it usually clones your pc's mac address.
Hope this helps.
3helpful
2answers
How to configure Linksys WRT54G router with BSNL's C2110 modem?
The Linksys WRT54G broadband router is one of the most popular consumer routers there are. Linksys makes configuring your router easy. This article will walk you through the initial setup options for this particular model, but many of the basics we talk about here can be applied to any router setup. Setting up the router consists of four basic steps, such as Testing your Internet connection, connecting your hardware, setting up the connection and power cycling the entire network. Aside, from setup, we'll also describe some security concerns so you can make an educated decision on the administration of your home network.
Test Your Internet Connection First While this seems like something you would not need to be, make sure your Internet connection actually works. If you haven't already, plug the cable modem directly into the back of the computer and make sure you can get onto the internet. You may need to reboot the machine first.
Connect The Modem and Router to the PC Now that we have confirmed the Internet connection works, the next step is to connect the modem to the router and the router to the PC. The modem will attach to the router's Internet Port. You will then attach the router to the PC via any of the four Ethernet ports in the rear. Check the LED lights in the front of the router to confirm all of the connections are properly made. The Power, WLAN, Ethernet Port to PC and the Internet should all be lit.
Configure The Linksys WRT54G Settings With all connection made, you will now need to login to the router via your web browser. Type 192.168.1.1 and hit enter. You should see the login screen. Leave the username blank and type admin as the password and hit enter.
You will now need to configure the router's connection to the Internet. Under the Setup / Basic Setup section, make sure the router is setup to Automatic Configuration - DHCP. This allows the router to receive an IP address from your Internet Service Provider.
Next, go to the MAC Address Clone tab in the same area and enable Mac Address Cloning. This allows the router to clone your PCs MAC address, as the ISP may require this.
Power Cycle the Router and Modem Now that everything is configured, you'll want to power cycle everything. This is done to make sure everything has an IP address from the modem all the way through to the PC. To power cycle, shutdown everything. Unplug the modem and router power source. Shutdown the computer. Plug in the modem and wait for all green lights. Next, plug in the router and wait a few minutes until its lights are also green. Lastly, boot up the PC. You should have an Internet connection.
Change the Linksys WRT54G Router Password You noticed when setting up the router, that there was a default username of nothing and a password of "admin." Be sure to log back into the router once everything is running properly and type in a username and change the password. If you don't, a hacker that sees you have a WRT54G router could login to the router with the default credentials.
2answers
Need settings for Huawei HG510 with Linksys wireless WRT54G
You could reset you router to default settings.
On the back of you router, you will find a little hole
using a pen, press that reset button.
Linksys switch to new pc
Have you tried going to the Linksys Forums and asking this question, I had similar issues when we moved house and the guys over there were most helpful.
2helpful
4answers
What router will work with my Huawei EC228 USB modem?
The Huawei EC228 is compatible with the Cradlepoint MBR-1000 and the CRT-350.
Wireless connection is not secure when I'm logged in from PC,anyone can use
Click on this link
http://www.portforward.com/english/routers/wireless/routerindex.htm
Then choose the brand and model of the router and follow the steps how to secure your wireless connection.
Connection Ports
you cannot turn off the individual ports of a linksys wrt54g router. you can try to disable the local area connection of the computer that uses the particular port of the router.
Telephone connection
Unless you have dial up, you arent supposed to be losing any connection between the two. If you are, i would call them up and have them come out to fix it for free. That is completely rediculous.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
