Question about Garden
Should my blade clutch on a ydh2148 go out in less than 100 hours of use
  • 155 Answers
If it is an electric clutch it will need adjusting the gap in the middle should be 10 thou use a feeler guage and adjust all 3 sides by tightening the nuts.
Posted on Jul 26, 2009
Cultivator spinning slow
If the blades are turning slowly while the machine is on tick-over, then it is more than likely a clutch issue. Clutch springs will stretch and occasionally break. With less resistance on the clutch shoes they grip the clutch drum and this in-turn will cause the blades to turn.
Check clutch springs.
Apr 10, 2013 | Stihl Garden
Electric blade clutch won't work and battery went dead
If you have a new battery and it went dead that quickly I would check the charging system on the mower engine. Many of them use a voltage regulator and if it goes bad it will not properly charge the battery. Get the engine running (do not engage the PTO) and use a multimeter set on DC voltage. Place the multimeter leads on the battery and you should see approximately 13-14 volts DC at the battery terminals when it is running. If less then that then it's a problem with the charging system and further tests would be needed to figure out if it is a bad regulator or charging coil.
Aug 23, 2012 | Husqvarna Garden
Received a * used* Swisher ZT 2660 26hp in October of 2010 has 50 hours on the meter. First 2 or 3 cuts all went fine last cut of the year when the mower would contact grass / leaves the blades would...
Is the belt slipping? If it's slipping you'll notice it, because it'll smoke pretty soon. If, as you watch it under varying load, it slows down with the blades then the belt is fine.
If it's not the belt then it's going to be the electric clutch that drives the belt. Get your voltmeter out and tap into the wires that go to the clutch, watch it as the mower runs. Anything under about 13V and the clutch may slip. If the voltage is good then the clutch is worn out. They don't cost too much, I'm pretty sure they're well under $100 still.
Make sure the wires that plug into the clutch are making a good connection. You want to check the voltage between the switch and clutch so that you're also checking the switch- if it's got a little crud in it, or a bad connection farther up the line, it can cause the clutch to slip, and you'll see this as the voltage dropping.
lp
Jan 10, 2011 | Swisher 60" 26 Hp Zero Turn Radius Riding...
A carpenter was contracted to repair a kitchen for $18000, the work took him 6 hours more than he has estimated and as a consequence, he earned $100 per hour less than he had estimated. how many hours had...
I will try to solve it systematically so it will be easier to understand. Note: The solution involves solving a quadratic equation.
Let amount of hours estimated be x:
Expected rate: $18000/(x hours)
Time spent extra: 6 hours.
Totals hours spent: (x + 6) hours
New rate: $18000/(x+6 hours)
Now:
18000/(x+6) x
The new rate is less than old rate by $100, therefore we can make the above inequality equality by adding $100 to the new rate.
18000/(x+6) + 100 = 18000/x
Solve by cross multiplaction:
(18000 + 100(x+6) * x = 18000 * (x+6)
18000x + 100x(x+6) = 18000x + 108000
Simplify:
100x(x+6) = 108000 (cancel 18000x on both sides)
x(x+6) = 1080 (divide by 100)
x^2 + 6x - 1080 = 0
Solve the above quadratic equation by any method (completing square, factorization or quadratic formula)
x = (-b+-(b^2 - 4ac)^.5)/2a where a = 1; b = 6; c = -1080
x = 30 or -36 (hours cannot be negative so disregard this result)
Therefore x = Estimated time = 30 hours
Check:
18000/30 = $600 per hour x+6 = 36 $18000/36 = $500 or $100 per hour less than estimated
Nov 12, 2010 | Office Equipment & Supplies
Clutch adjustment for Interntional Tractor 986
tighten/shorten the cable that is attached to the back of the pedal
Apr 03, 2010 | The Times Case Corporation Tractors...
Roof air conditioner shut off
First inspect the plug blades. If they are dirty, black, melted or corroded, there's your problem. replace BOTH the plug and the receptacle.
Then ensure your power is adequate, a 100' 12 gauge extension cord will blow out a air conditioner in oh, right about two hours.. Use less than 50' for small, and 100' for 12 (heavy guage) extension cords.
Third, maybe your start/run capacitor is toasted from any or all of the above.
Discharge safely and replace the inexpensive capacitor from an online source or a local appliance service shop.
Aug 30, 2009 | Dometic Rooftop RV Air Conditioner
Blades run in reverse and only for a short distance going forward
ok when was the last time you had the hydrolic fluid changed ?
or the oil for that mater ?
oil breaks down
you wouldnt cook your french fries in year old oil but you will cook your tranny with it in a cub or mtd machine 100-120 hours max for the fluids in an mtd b4 they start to loose texture or viscosity ( sound it out)
hydro pumps di die mtd has 1 monster that is quite expensive also have you changed the filter on the rear axcel lately or is it full of nut butter and in bypass mode
100 hours doesnt seam like much but for a tractor it is
service service service
Jul 25, 2009 | Garden
How much is it to replace a pulley and ac belt
A pulley and clutch set cost less than US$100. in US. In Canada, prepare to pay double or more. If do it yourself, loan a pulley puller and clutch remover from PartSource... and it took me less than an hour to replacei them..
Jul 10, 2009 | 1997 Honda Accord
Blades not engaging
Tim, first turn key on engage and disengage blade button. See if you can hear the clutch making a clicking noise. If not check switch., if not your problem is in the clutch.
May 29, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
