Question about Kenmore 15912 Built-in Dishwasher
Dishwasher backing up
I just put my dishwasher on, and 10 minutes later my kitchen was flooded. The water doesn't drain.
  • 636 Answers
Sound like you have a few things going on there.there is a float switch which is located at the front right side of dish washer, make sure this floats freely . also sounds as through your drain line may have become plugged. Ease to fix , remove the line and hard line from the pump with a set of plyers. and remove the debris from the diaphram within the hard line.. before starting this be sure to remove as much water from within the dishwash, easiest way is to use a shop vac.
Posted on Jul 26, 2009
DD-603 cycle and draining problems.
check your kitchen drain as it might be blocked or if you have a garbage disposal (kitchen insinkerator) make sure it is cleared before running the dishwasher.
Jul 18, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
How to reset the flood switch on a fisher & paykel
Hi - unfortunately my good friend it cannot be reset as one would like quite easily anyhow... water has found its way to the base of the drwaers and have activated the flooding switch - one could pull it apart to dry it - tip the water out from the base but if the leaks not repaired you will have the same problem later and will be on-going.
5 Fault Codes
Fault Code LED Display Fault Possible Causes
F1 ----#
The flood switch has been activated.
A leak has occurred in the base of the dishwasher.
Cause
 The fill valve has failed open.
 The flood switch is faulty.
 Excessive water has been added to a wash sub cycle, indicating leaking seal or siphoning.
hope this is useful tp you - let me know if you require further asspstance...
Jul 16, 2011 | Fisher and Paykel DS602 Dishwasher
Flooding in both drawers of dishwasher
I suppose "flooding in both drawers of ..." implies water is not draining out. Is that right?
It is a very little information to give you any clear solutions.
Did the water get into the drawers without starting any wash program? Most likely it is the backflow from kitchen sink back through the dishwasher drain hose. Does your kitchen sink plumbing have an air gap sowehere. If so, is it clear?
If the water is the back flow then it is likely to be smelly and you do not want to run it through the dishwasher. I would suggest take the drain hose out from under the sink downpipe and drop into an empty bucket. Then take all the fixtures out from the drawers and empty out water using a small container.
Put the washer arms back and run each drawer on a short rinse cycle collecting the drain water in the bucket. If cycle runs clear, then get plumber to check the kitchen downpipe.
Reconnect drain hose.
Hope this helps.
Dec 28, 2010 | Fisher DD603FCSS Dishwasher
Hoover HED 6612/1-80 dishwasher all four lights flash and beep whilst the machine drains, after a couple of minutes the beeping stops but the four lights glow. Cannot reset to cancel. Also still makes...
Not sure if you have got a user manual for this dishwasher. You can download one from this site.
You have a flood situation inside the dishwasher. See page 12 of the manual. There may be no water at the bottom of the machine but there is some overfill occuring. Also see error codes on page 13. This can be either because the flood detection circuit is faulty and giving false trigger or there is water in the base of the dishwasher housing due to leaking door gasket or hoses.
Some things to try. Turn mains power off and back on and see if there is any difference.
If not, then turn power off and pull dishwasher out from the kitchen benchtop. Put a few towels on the floor and tilt the dishwasher side to side on the base and see if any water comes out. Wait 5-6 minutes and turn power back on. See if it makes any difference.
Dec 15, 2010 | Hoover Dishwashers
My bottom dish washer was draining the water on the top dishwasher and there is always water left over on the top.I remove the pipes and put CLR to clean up drain.Start both dishwasher on rinse cycle ( 12...
Hi
Thanks for using FixYa.
F1 error means that the flood switch has been activated. You'll need to reset it by powering off the breaker or by unplugging the unit from the power socket and mains for more than five minutes. Please check that there is no blockage in the drain hose and it is not raised higher otherwise the water will run back to the dishwasher. Also perform the following procedure---
    • Unplug power and remove bottom dish drawer
    • Use a Sponge and dry all the excess water underneath
    • Remove circuit board cover
    • Dry all around and underneath as much as possible
    • Apply hairdryer for 10-15min
Please rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Oct 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water will not drain from Kitchen Aid Dishwasher
my dishwasher did this for awhile. i found a small object lodged in the drain under the moving sprayer. i put a small amount of powdered clorox2 and ran a cycle. afterwards i ran a jetdry cycle. i havent had a problem since.
Apr 23, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Dishwasher fills with water when running faucet
The drain hose from the dishwasher should exit the dishwasher, then head up to the nderside of the counter top, before heading back down to connect to the disposal drain connection.
If the drain hose doesn't do this, the dishwasher is improperly installed, and clean dishes risk being contaminated, which can cause people to become ill.
Jan 25, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Bosch slimline dishwasher flooded kitchen
Your debris filter needs to be cleaned. It is found under the dry bar in the bottom of the tub. It looks like a plastic mesh and you can usually remove it to wash it out if not use an old toothbrush etc... this should help.
Jan 11, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kenmore 15912 Built-in Dishwasher Logo
109 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
