SOURCE: norstar m7310 phone problem
Sounds like a **** button.
Unplug the phone and rake (pull your fingers across) the face of the phone...
The button that you have programmed for your accountant sounds like a good place to start looking.
SOURCE: Have Norstar M7310 5 line phone 2 lines say they
You need to unplug something, just not the phone.
The two lines are probably conferenced together. Go find the gray Nortel cabinet and pull the plug on it.
Carl
Testimonial: "Thanks Carl, that worked."
SOURCE: lines ring to intercom
It sounds like although they're labeled as line buttons actually they're programmed as station buttons.
If you press feature *0 and one of the buttons it will tell you what the button is programmed as.
Also did you try pressing the intercom button then dialing 9? that might be the way the set was programmed.
SOURCE: NorStar M7310 Corded Phone do
Power lines were replaed t/o our building over the weekend. Coming into work today the M7310 had messages but it will not let me access them. I hit MSG, NEXT, but it goes immediately to FLASKTK and stays there until I release it. THoughts?
THank you.
SOURCE: My Norstar M7310 is stuck in handsfree mode. Is there a feature or programming fix for it?
Nothing in programming typically would help with exception to maybe swap by plugging in a M7208 into your problem jack then swap back to m7310 again. Going to 08 and back to 10 can sometime clears issues otherwise sounds like a bad phone and needs repair.
