if the leaver moves freely but wont move first check belt is on pulley and if so you have sheared off keyway on the pulley on top of drive axle remove pully replace keyway reinstall
You might have a worn engine pulley. You can manually adjust the drive belt tension by pulling back on the left foot pedal. This worked on mine and is a sign that the pulley V groove has worn to a U groove and the belt looses traction.
Was this helpful?
Yes
No
Popular Solutions for Husqvarna 26 Hp 54" Deck Zero
thumbscrew w/ a plastic triangular head fell off (found in yard)- cannot locate from where. two...
(More)
THUMBSCREW W/ A PLASTIC TRIANGULAR HEAD FELL OFF (FOUND IN YARD)- CANNOT LOCATE FROM WHERE. TWO IDENTICAL ONES HOLD ON FOOTWELL PANEL BTWEEN LEGS, TWO ARE UP ON ROLLBAR. THIS ONE CAME FROM WHERE??? ITS ABOUT TWO" LONG, ABOUT 3/8" DIAM. WE'VE LOOKED EVERYWHERE.
it is a ayp lt 4218 c k gro, dual blades, 42 " when i got it it was apart. all parts are here ,...
(More)
it is a ayp lt 4218 c k gro, dual blades, 42 " when i got it it was apart. all parts are here , on rod is off, not sure where it goes, several choices. so i need a diagram to put it back together
