Question about Fuji FinePix A350 Digital Camera
Cant take a picture
The camera when it is in the picture taking setting displays a black screen with the message zoom error. Lens is not opening
  • 1 more comment
  • jue40 Dec 26, 2007
    hi i have the s5700 took pictures in the morning, then went to use in the afternoon and zoom error message appears and i carnt take pictures. the camara is only 4 months old tryed phoning fijifilm number not in use anybody got a number for them.
  • Aloha Chuck Dec 28, 2007
    My lens assembly no longer works (does not extend or retract) and has a "zoom error" message (or had). Now the LCD display is almost unreadable as well. The camera was purchased in October 2005. Is this repairable and at what cost?
  • Anonymous May 26, 2008
    my camera was working fine and all of a sudden when i turned it on it read zoom error. ive put in new batteries, shook it, turned it off and on and also tried to see if anything , dust, lint, that sort of thing might of gotten stuck in
    it nothing shows but i still can't get it to work
This is a common problem with this camera and it needs to be sent back to Fuji for repair.I've been through it three times and then they replaced the A350 with an A400 and now I'm having the same problems with the A400.
They want to swap it with a E500.
Both of these replacements are less of a camera then the A350.
If they won't repair it under warranty I suggest you stay away from Fuji cameras in the future,I know I will never buy one again
Posted on Dec 20, 2007
Canon digital camera A480 Lens error message
Probably the zoom is stack with dust. This is very common in this type of cameras.
You can take it apart and test the mobile parts as shown in this videos:
http://www.desmontalo.com/?p=272
http://www.desmontalo.com/?p=268
Apr 28, 2012 | Canon Cameras
Canon A620 is taking black images/ Can't see images on screen
First try pressing the DISP or DISPLAY button on the back of your camera. If that didn't fix it... A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 28, 2010 | Canon PowerShot A620 Digital Camera
Fujifilm finepix j38 series reads zoom error and wont take a pic.
If you have some skills, you can open the camera and cline your zoom lens with toothbrush and compressed air. Try to separate zoom lens from the electric motor. usually is 2 or 3 screws. You will see a lot of sand inside the camera and lens. And next time when you will go to the beach, you will take more care about your camera.
Solution 2, and more easy is to buy another zoom lens from ebay.Or another camera same model with broken LCD or other technical problem than zoom lens.
May 31, 2010 | Fuji Cameras
Zoom error
It sounds as though your lens is sticking while trying to extend. Check the lens to see if it binds. Also look at the retracted lens and see if the center portion is properly centered or is cocked to one side and out of alignment.
Once your camera is working properly, as you say it does at times, hold the camera with the lens pointed downward and run the zoom in and out several times to see if there is dirt caught between the lens cylinders. Sometimes that will work any debris out.
May 20, 2010 | Fuji FinePix S2000hd Digital Camera
CANON POWER SHOT SD750 DOESNT TAKE PICTURES BLACK SCREEN
Mine started working again. The only thing I can attribute to it is that I zoomed the lens in and out several times. The next time I turned it on, it worked. Go figure. I'll update if things change.
Dec 03, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Zoom error
I just got one from Newegg.com. It was a refurbished item so I knew I was taking a chance. Straight out of the box it gives me a "zoom error" and will not take pics or even display an image. From what I've read about this it is most likely something in the zoom mechanism and needs to be fixed by the factory.
The only thing you can do is send it back to be fixed. I know this isn't much of a solution.
Dec 15, 2007 | Fuji FinePix S5700 Digital Camera
Zoom error message
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 07, 2007 | Olympus SP-350 Digital Camera
Fuji FinePix A350 Digital Camera Logo
91 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
