Question about Boating
Twin 502 magnums after 3000 rpms 1 motor lackes
Twin 502 magnums after 3000 rpms 1 motor lackes 200/300 rpms both run fine use no oil or miss losing about 7mph on top end
    Champion:
  • 207 Answers
Is this a problem that has been happening since it was new if not then it sounds like your cables are streching and the motors need to be sinked together but it doesnt sound like u have a major problem just some adjustments let me know and ill try to guide you thriugh what to do thanks thomas at finish line cycles and watercraft
Posted on Jul 27, 2009
Engine rpms is constantly going up and down.
Is the air filter clean?
Governor Ajustment Briggs V-twin - YouTube
? 3:12
www.youtube.com/watch?v=tOoArROpM_oJun 26, 2010 - Uploaded by IFIXIT4U The Briggs manual does not do a very good job. You have to adjust the tension on the two springs to set the RPMs that the engine runs at the low and high position. ... I really really need help guys my race motor has a 21hp vtwin brigs, .... Briggs & Stratton opposed twin carburetor series 1 of 3 disassemble ...
Sep 17, 2015 | Briggs & Stratton Briggs Stratton Intek V...
When I plug my Magnum 2 HP 5 gallon compressor in, it blows out oil out of the red plug that you put oil in
Could be you are filling it too much, such as to the top of the oil hole instead of the bottom of the hole. I suggest you check the manual.
Perhaps the compressor isn't level or perhaps the crankcase breather is blocked or not working properly or perhaps there is too much piston blow-by for the breather to cope with.
Feb 03, 2015 | Magnum Air Tools & Compressors
My 2005 dodge Magnum 2.7 liter started knocking as if it had no oil
you are most probably looking at a rebuild. There was a class action suit against Chrysler because of that motor. they made the oil passages in that motor too narrow, and it doesn't take a lot of gunk to block them up and a good section of the motor loses oil pressure. I remember that their policy was to blame the customer if he missed a single service. a lot of those engines failed under warranty.
Mar 06, 2013 | 2005 Dodge Magnum
2007 magnum se 2.7 v6 wont turn over
Sounds like the engine is toast.
The warning light means the oil pressure has dropped below 10psi which can mean the engine is low on oil, or that something has happened to the oil pump or other components.
The crank bearings may be seized from lack of oil.
See if you can turn the crank by turning the alternator pulley.
Jan 26, 2013 | 2006 Dodge Magnum
Belt noise
1) LUBE the deck belt this happen by lack of maintenance
2) LUBE the rollers bearing too
3) Test the bearing main motor need repair+LUBE
4) Deck can be worn by lack of maintenance.
see the diagram
God bless you
Jul 27, 2012 | Magnum Fitness Exercise & Fitness
How do i check oil pressure on 2005 dodge magnum
remove the oil sending unit and install a oil pressure gauge.You did not specify the motor so you can find it by the oil filter.remove the oil sending unit and install the gauge.Let the motor get to operating temperature and check pressure.Should be @ idle over 5 psi.5 is minimum.@ 3000 rpm should be 45-105.Hope this helps.Good luck.
Dec 12, 2009 | 2005 Dodge Magnum
Runs fine untill i hit about 3000 rpms then it starts missin
have you tried to clean the throttle body? Believe it or not it does make a difference
Jun 17, 2009 | 1995 GMC Sierra C1500
Boating Logo
54 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
