SOURCE: simpson encore 605 wash machine 6kg. Washer pump
Hi mark just read your posting.Now what country do you live in.If you live in Australia then I can give you some phone numbers.Regarding your machine it does sound like the control board.Probably the power supply section of the board is faulting.Please reply with additional information and I can help you further.
Testimonial: "Nice reply with information to put me in contact with someone who may have parts. Thanks. I await some more contact phone numbers."
SOURCE: electrolux ewf 1090, have an electrolux ewf1090
ewf1090 washing machine not working?
error E50 is displayed?
but no reference in manual that helps.
SOURCE: Electrolux Eco Valve EWF1087 washing machine,will
8 November, Today I picked this model off the footpath, yet to set it up I hope it works LeonZ -Reservoir, Vic.
SOURCE: water in cycles is always cold
You need to check the heating element continuity using a multimeter. If there is continuity then check voltage at the time of the heating , if there is no voltage then the control panel is a suspect including the relay to the coil.
The machine washing speed is not only TIME but WEIGHT... If you are able to push the Quick Wash, then that is the Quickest to get the job done "RIGHT"
