Question about Garden
Husqvarna riding mower will not go in forward or reverse. it is hydrolic
  • 636 Answers
Check this site out it is called manuals online. Have you checked the oil level ? could be something simple like an o-ring.
Posted on Jul 26, 2009
Why won't my Husqvarna Riding Mower go into gear? After having a tractor tire repaired and replacing the wheel and tire onto my Husqvarna Riding Mower, it will not go forward or into reverse.
It is possible that the neutral lever (free wheeling lever) has been actuated by pulling the lever out during the repair. For normal operation the lever should be pushed in.
Hope this helps?
Manual -See page 8 item (M)
http://www.husqvarna.com/ddoc/HUSO/HUSO2007_USen/HUSO2007_USen__532418916.pdf
Oct 05, 2016 | Husqvarna Garden
How can I adjust the transmission linkage on a Husqvarna riding mower model LTH145 product # 954-14-00-06?
The Hydro-Gear transmission in this model tractor does not have an adjustment capability. You can either bend or straighten the actuating rod to adjust it in small amounts. However, with no reverse or forward the transmission may be bad. Check the v-belt first. Replace the v-belt if loose or worn. Otherwise you are probably needing a transmission.
May 06, 2015 | Husqvarna Garden
It will run backwards but not forward
If you are able to move in reverse but not forward, you need to adjust the levers. First you will need to elevate the rear wheels and set the neutral. This will then allow you to set the levers for proper forward and reverse movements.
May 03, 2015 | Husqvarna Zero Turn Mower Z5426
John deere 445 no reverse
you have air in your hydrolic line crack open line and let the air bleed out
Sep 08, 2014 | Garden
Husqvarna 2754GLS, Hydrostatic forward/reverse pedal will not return to neutral position.
Parts and Diagrams for Husqvarna 2754 GLS 96043004700 2008 01
I suggest following all the safety procedures suggested in the operators manual first!
ENGINE NOT RUNNING,wheels blocked to prevent being run over, check the return spring ref # 161
Apr 12, 2014 | Husqvarna Garden
My Husqvarna Rider 16c wont reverse - first it was slow in reverse then not at all
You need to check the cable, it is a push pull telescopic style so it is possible to get forward and no reverse, if it was a hydro problem you would not get forward or reverse, there is also timing gears on the forward and reverse pedal, you nee to make sure they have not jumped a tooth as this would reduce movement on the cable at the hydro
Feb 12, 2013 | Husqvarna Garden
Husqvarna Riding mower wont reverse gth2350 riding mower
I think theres 2 flow paths forward and reverse try checking the fluid level you may have to lower the rear end out of the machine or most all ridders ive seen allow you to take the backing plate off and then block the rear tires off the ground the fluid level should be about and inch from the top of the threads... if yours has a resivor off to the side with a breather fill it to the bottom of the threads... now that the fluid is full and up on blocks or jack stands start the engine and at an idle put it all the way forward to flush the bubles out this has to be done in small chunks 5 minutes forward and then laiter go 10 back let sit for 20 minutes in between and check the fluid level a couple of times to see if it whent down from this... best of luck hope this helped
Oct 03, 2012 | Husqvarna "GTH24V52LS 52"" Kawasaki 726cc...
Lost reverse on right transaxel
could possibly have a broken selector fork on the transaxle, if so the transaxle will have to be pulled right down to repair the broken parts.
May 07, 2009 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
Garden Logo
168 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
