Question about Video Game Consoles & Games
My xbox randomly turned itself off earlier today. I left alone for several hours, tried to turn it on but nothing happened. I switched outlets on the surge protector and then it turned on. This time it was on for about 30 minutes before turning off again and I haven't been able to turn it back on. I've checked all the power cords, unplugged them and plugged them back in. I even plugged the power supply directly into the wall and that didn't help. The light on the power supply is red, which I thought meant that it was connected with the xbox. Can you help? Thank you
  • 1 more comment
  • rob_benz Jul 26, 2009
    so there's nothing wrong with the unit itself? I just need to order a new power supply, right? And just to clarify, we're talking about the black box with the light on it that connects to the xbox and a power outlet? Thanks
    Please include specific instructions about how to remedy this situation.
    it was an xbox 360, good call. thanks man.
  • 6,784 Answers
HI, this is a damaged power supply issue here. you can purchase a new version ro, you can replace the original as well. the red light is a strong indicator of a serious malfunction concerning the power supply.
Click here to be directed to a site were you can purchase your replacement power supply.
Posted on Jul 26, 2009
    President:
  • 2,559 Answers
The power supply is bad due to overheating
Sharp 80le632u lcd turn off randomly & suddenly
Checked Power Board is it any solder is not proper. Resolder all main point.
Jun 04, 2017 | Sharp Aquos Televison & Video
LN32C550 turns off
Look for loose contacts in power outlet. Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 02, 2012 | Samsung LN32C550 32 in TV
My XBOX 360 will not turn on. The power bar has a green light but pressing the eject button or power button on the console will not turn it on. We have tried plugging it in to a different outlet but that...
Hi christoph52893,
If the Xbox 360 power supply light is green, this means the Xbox 360 power supply is ok and it is an issue with the console itself. You will need to contact Xbox 360 customer support to service your console. However, if you have a flashing orange or yellow light, it means that your console is fine but instead there is something wrong with your power supply. It indicates that it's not getting enough power.
Hope it helps.
Thank you for using FixYa.
Jul 05, 2011 | Microsoft Xbox 360 Console
Washer won't turn on at times. It acts like it has no power. Unplugging electric cord from wall socket and reconnecting seems to reset the unit and it functions normally for a while. After an hour or...
Try this first, unplug the unit and connect it to a different outlet and see if it corrects the problem. If it still continues, you will need to replace the control board. Good luck.
Jun 18, 2011 | LG WM2301HW Front Load Washer
Power supply light is red
This issue occurs when the external power supply has detected a fault. The power supply has several built-in safeguards to help prevent damage to either the console or to the power supply itself. The power supply will turn itself off if one of the following conditions is true:
  • There is too much current
  • The voltage is too high
  • The temperature of the power supply is too high
Under these conditions, the light on the power supply turns red.
Step 1: Make sure that the power supply is cool loadTOCNode(2, 'whattotry'); The red light may indicate that the power supply is too hot or that it has already overheated. If the power supply light is red, follow these steps:
  1. Make sure that your Xbox 360 console is turned off.
  2. Disconnect your Xbox 360 Power Supply from your Xbox 360 console and from the wall socket.
    For more information about how to disconnect the Xbox 360 power supply, click the following article number to view the article in the Microsoft Knowledge Base: 906205 (http://support.microsoft.com/kb/906205/ ) How to connect and disconnect the Xbox 360 power supply
  3. Let the power supply cool for several hours in a well-ventilated space. Do not connect the Xbox 360 power supply to the console or to the wall socket during this time.
  4. After the power supply has cooled for several hours, reconnect the Xbox 360 Power Supply to the console and to the wall socket.
If the power supply light is still red, go to step 2. Step 2: Make sure that the power supply is plugged in correctly loadTOCNode(2, 'whattotry'); If the power cord is plugged in to an extension cord, a surge protector, or a power strip, the current or voltage that flows through the power supply may not be correct. Make sure that the power supply is plugged directly into a working wall outlet.
Step 3: Plug the power supply into a different wall socket loadTOCNode(2, 'whattotry'); Try a different wall socket. Ideally, plug the power supply into a wall outlet that is elsewhere in the house.
Jul 16, 2009 | Microsoft Xbox 360 Console
Tomtom Rider GPS won't turn on
My Rider 1 is showing the same sympton. Was working fine now I can't get past the initial "Tomtom" screen.
Does it power up when connected to the mains charger?- No, need to prod reset and then turn on manually.
Does it switch on when connected to the bike cradle? - No, only sign of life if by manually turning on but only get as far as the Tomtom screen, not the main menu.
Any ideas welcome
Jul 14, 2009 | Tomtom RIDER GPS Devices
Picture turns pink/red. Power off/on corrects...
I had that problem several times with my Z50, I would cut it off, wait and it would fix itself. Now today, it went POP! Complete loss of video, I have audio. I am off the warranty period. I feel very alone now.
Feb 05, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Pain in the a
IS THIS STILL GOING ON?
Oct 14, 2007 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
