Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Door and rubbers are extremely hot and we are burrning ourselves while opening and taking food out
  • 31 Answers
Your refrigerator has a stopped up Condenser Coil that needs cleaning with a vacuum cleaner. Also check that the Condenser Fan is working. The Condenser Fan may be bad....It sits under the bottom of the ref near the compressor and runs to cool the compressor. Hopes this helps! Handy Henry
Posted on Jul 26, 2009
How do I prevent the fridge door from sticking too much and making it hard to open
Make sure the gaskets and surfaces are clean, any grease on them will make them hard to open. Check the hinges are free and not gummed up. Spilled coke etc, will also cause them to stick due to the sugar acting like glue. Putting hot food in there mayl also cause this problem.
Feb 25, 2015 | Westinghouse Refrigerators
We have a frigidaire upright (ffu17m7hwd) which formed a lot of ice and we are in the midst of defrosting and don't want to experience this again. Can you assist please? Had to throw food out due to...
Freezer burn to food is caused by air & moisture in contact with it.
There should be a tight seal by the rubber gasket along all the inside edges of the freezer door. This gasket prevents unwanted hot moisture and hot air from entering the freezer compartment and causing ice build up. You can test the integrity of the rubber gasket seal by seeing how the freezer door will pinch a slip of paper in various spots around the freezer door. If the slip of paper pulls out easily, there is not a good seal at that spot. If that's the case (which I believe it is), the door gasket needs to be replaced. By the way, ice will build up over time because you need to access the food in the freezer, hence you will introduce moist air each time you open the freezer door.
Aug 28, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The lights in the refrigerator did not turn off and are extremely hot. The food does not get cold, however the bottom freezer is working fine
Greetings,
the first thing to do is unscrew the bulbs to keep that heat from affecting the food...now, make sure the door is actually striking the switch..if not adjust door...if not, could be the door switch or the main board which controls the lights....
Jan 11, 2011 | LG Refrigerators
Defrost heater staying on causing rubber strip on doors to get extremely hot
hmmm... This would cause a freezer meltdown and spoiling of your food. Are you talking about the heating element behind the freezer panel ? There should be a safety to shut off the heater - there is another type of heating element to prevent moisture during hot humid summer days, controled by an "energy saver" switch - on older refrigerators - when this is on it is normal for the base between the freezer and fridge to be warm - but if it is the defrost element in the freezer, this is not normal at all - usually it should say on for around 20-25 mins or as needed - in which case you have a defrost timer / defrost components problems and need to get it serviced A.S.A.P.
Sep 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore refregerator lights on/burning even doors are closed
If I understand correctly, you have the bottom freezer with the two doors that open into the fresh food section. Also you have to open one of the two doors first in order to get into the fresh food section. If i ma correct. The switch on the door you have to open first to get into the fresh food section is bad. This is why it makes not difference if you hold both in. The switch on the second door does something else. You will need to replace the switch that the first. You can test this switch by, take the switch out. They are tricky to get out. Take a putty knife and slide it under one end of the switch, push in while you are prying outward. It should pop out. There should be three wires going to the switch. One of the wires is hot (110 Volts), one goes to the fan inside the fridge and the other goes to the light. (The switch operates like this. When you close the door, it turns the light off and the fan on. When you open the door, it turns the fan off and the light on.) Once you find out which one is hot, connect one of the others to it. If the fan comes on try connecting the hot to the other wire. The light in the fridge should turn off. If so replace the switch. I hope you can understand the way I tried to explain.
Please rate solution
Sep 05, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My dishwasher stinks!
There is food trap of sorts that's part of the soft food disposer. Problem is that food lays down in all the nooks and crannies and festers.
Try this site on YouTube:
http://www.youtube.com/watch?v=JhchaOhpQQo
You probably don't need to go to this guy's extremes (but he's thorough!). You probably just need the part about how to clean the strainer and bottom of the washer. I think this'll help. There are other videos, some selling products (that I haven't used). Also some of the videos are helpful, you'll just need to take a look. Once you've cleaned the goo, you can help it clean with just one cup of white vinegar and hot water occasionally. Also, use the least amount of detergent that you can, and still get your dishes clean.
Best regards, --W/D--
Jul 09, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Fresh food door pops open
check magnet in rubber,or hinge on the door
Feb 17, 2009 | Refrigerators
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
245 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
