Question about Lowrance LMS-330C GPS Receiver
Lowrance LMS-334c iGPS
Unit wont change from map back to sonar when you press the pages key also when you press zoom in zoom out keys they work in reverse
2 Suggested Answers
SOURCE: Cannot access main menu or pages screen
I think I can help with your issue. I have an LMS 334c and have had a few issues in the past. Called the factory (this answer is not listed any where in your manual) and they instructed me to "Soft Re Boot" my unit and it would put everything back to factory settings. Try this anytime it does not respond for whatever reason.
Turn the unit off.
At the same time press the Pages and Power button. Hold both down until you see the square box come up in the screen. You should have your factory settings again. May need to try a few times.
Lowrance said it works just like a computer, ever now and then it just tries to disect to much information at one time and hangs up.
Good luck. James Cantwell
Posted on May 04, 2009
Lms-332c lowrance fishfinder unit turns on as soon as the power wire is plugged in and goes to blinking pinging beeping between hi and low light settings constantly. All other features seem to work fine. A...
Hello
I don't know whether you have made a factory reset to this device or not. If not, set it first and see whether it helps you. To make it factory settings:
[1] Press 'MENU""MENU" (down arrow to system setup) "ENT" (down arrow to RESET options/ ENT
[2] The unit asks if you want to reset all the options. Press [<---] to YES and then ENT. All options are reset, and the unit reverts back to map page at 4000 miles zoom range. Any recorded sonar logs of GPS data will be unchanged. OK.
Sep 23, 2011 | Lowrance LMS-332C GPS Receiver
Hello- My 332c will not show speed. It worked before.The spinner wheel is not damaged.Speed just flashes 0.00 mph Thanks, Jeff
Try setting up the speed in the overlay data menu again:
1. Press MENU, arrow down to OVERLAY DATA and press ENT
2. Highlight the option for speed (WATER SPEED or GROUND SPEED) and press ENT
3. Highlight the REMOVE button and press ENT
4. Highlight (PRESS ENT TO ADD) and press ENT
5. Arrow down to SONAR DATA and press ENT
6. Arrow down to WATER SPEED and press ENT, a check will be displayed in the box
7. Press EXIT twice
If the speed is still flashing, the data is still invalid. Try resetting the unit completely:
1. Turn unit off
2. Press and hold the PAGES and POWER key until the "DO NOT RELY..." alarm appears
3. Set up the overlay data for speed again: 1. Press MENU, arrow down to OVERLAY DATA and press ENT; 2. Highlight (PRESS ENT TO ADD) and press ENT; 3. Arrow down to SONAR DATA and press ENT; 4. Arrow down to WATER SPEED and press ENT, a check will be displayed in the box; 5. Press EXIT twice
If the speed is still flashing, good chance the speed sensor is bad even though the wheel still spins. Install the latest LMS-332 updates from http://www.lowrance.com/en/Products/Marine/Full-Size-SonarGPS-Chartplotter-Combos/LMS-332C/Downloads/LMS-332C-Software-Update/ and set up the overlay data again.
If it turns out that the speed sensor is bad, just use speed from the GPS. This can be set up from the overlay data menu as GROUND SPEED.
(note: the overlay data must be set up for each page individually. So if you set up speed to be displayed on the map screen, it will not also be set up on the sonar page)
Jul 12, 2009 | Lowrance LMS-332C GPS Receiver
Hi,when i switch on my lms-332c the map does not come up on the screen.If I remove and replace the map card it works perfectly. Can I fix this? regards nigel
I am guessing that the card you are using is a NAVIONICS chart? There have been some Lowrance units that were made around the same time that have had problems recognizing a Navionics chart right from power up.
Make sure the LMS-332 has the latest firmware version which can be downloaded from http://www.lowrance.com/en/Products/Marine/Full-Size-SonarGPS-Chartplotter-Combos/LMS-332C/Downloads/LMS-332C-Software-Update/
If the update doesn't help, this is going to be a compatibility problem with the LMS-332 and that particular card. You will need to replace the card or upgrade to a newer unit...but probably can just get used to removing and replacing the card when you turn the unit on.
Jul 08, 2009 | Lowrance LMS 332c Mapping Sonar/GPS...
Turn the unit off.
Nov 03, 2008 | Lowrance LMS-330C GPS Receiver
Lowrance 330c gps unit
A "soft reset" can be accomplished by pressing and hold "Pages" key and press and hold "PWR" key till USA map comes on , then release both. A "hard reset" requires press and hold both "Z in" and "Z out" buttons and press and hold "PWR" button releasing all three when USA map appears.
Oct 18, 2008 | Lowrance LMS-330C GPS Receiver
I need a manual!!
you can find the manual here,
www.lowrance.com/upload/Lowrance/Documents/Manuals/LMS339cDF_iGPS_0152-011_011206.pdf
Hope my info solves your problem,
Thanx for using fixya.....
Oct 02, 2008 | Lowrance LMS-332C GPS Receiver
Sonar Problem
Try a soft reset first, if that doesn't correct it try a hard reset. BE SURE and Save Data before th eHard Reset, it clears all waypoints and such.
Soft Reset Hard Reset
LCX 15mt Reset 1. Turn unit OFF 1. Turn unit OFF 2. Press and hold the PAGES key 2. Press and hold the ZIN&ZOUT Keys at the same time 3. Press and hold the PWR key 3. Press and hold the PWR key 4. Release both buttons when the USA map appears 4. Release both buttons when the USA map appears
Jun 26, 2007 | Lowrance LC X-15MT Sonar
Lowrance LMS-330C GPS Receiver Logo
312 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
