Vizio e472vle Occasional flicker of source, menu will only stay up for 3-10 sec unable to use, smart tv menu will only stay up for 3-5 sec unable to use. Can change source, volume. Has been stuck "ON" twice had to unplug.
Follow these steps to reset your TV:
A. Using the VIZIO remote, press the Menu button.
B. Use the Arrow buttons on the remote to highlight System and press OK.
C. Highlight Reset & Admin and press OK.
D. Highlight Reset TV to Factory Defaults and press OK.
E. If you have not manually reset the parental code, please input 0 0 0 0 when it asks for the password.
F. Highlight Reset and press OK.
G. Wait for the TV to turn off.
The TV will turn back on and the Setup App process will begin.
Testimonial: "Sorry but you didn't read description. I cannot change any setting using menu because it closes after 3 sec."
Cannot use menu so this does not work.
You could try codes
10056
10178
10117
11756
11758
01377
10885
10864
10120
Codes for a remote will not help or address this issue. I have the original remote and it works fine. The menu comes up on the screen for 3 sec and then is closed automatically due to the problem.
if you have speakers next to it, that may be causing the problem, just move them away form it, otherwise you may want to take it to tv repairing for checking
No other devices next to it, has even been moved to a different room. The problem is with the tv.
mmm try to delete all apps(widget) with via plus button, also unplug other cables connected to it and see if it caused it
