S/N:07-281-550120-01 I lost the software for my dial up modem and need to know where i can get it again? i dont even know the name of the manufacturer.
    Brigadier General:
  • 4,090 Answers
Well sorry my crystal ball is not able to deduce any brands or manufacture from a series of numbers. The only thing i can say is that it was manufactured in 2007. DSial upo modems can be bought for about $30 now so perhaps get a newer one with software. it;s likely that you dont eb=]ven need the software anyway as most modems will work in windows if you select Standard or Vanilla modem
Posted on Jul 26, 2009
Sir MMX 310G 3G usb modem, when i was connected, the message shows only "dial failed". My profile setting is right, but what's the problem.Please solve the problem. Connection Profile...
there would be some software problem.......... please reinstall the software and use your device......... dont forget to vote for me...........
Apr 04, 2011 | Computers & Internet
Using a broadxent DI3635 modem. I can dial but will not connecton my desktop with Win XP, however on notebook using Vista, works fine.
probably winXP needs aditional software for the proper working of this hardware ,
WIn vista may have the software within it so that it woks fine
you could find the software or assistance in the in the website of the modem provider dont forget to comment and vote thanx
Mar 25, 2011 | Broadxent Creative Blaster Di3635 Modem
I,VE LOST THE installation cd can i get the software online?
In most cases you can. Simply use your choice of search engine to look for:
modem name + modem model + installation cd
or
modem name + modem model + support
Feb 28, 2011 | Computers & Internet
I need usb driver in linux for my mobile samsung sgh x820
hi...
many mobile phone companies dont provide drivers for linux.
But there is a software i would personaly recommend to you. Actually its not a software, its a shell script.
Name of software is "Sakis3g". It can connect to mobile phones and other mobile devices which can be detected by linux kernel. You can use IR, Bluetooth, even USB cable to connect to your device.
You can use this software for the following
connect to mobile devices by IR, bluetooth, USB Cable
  1. Send and receive files between computer and device
  2. Access Internet from Device by Dial Up Networking
  3. Browse files on Mobile device
  4. Mount the mobile device on a user specified mount point or communication port.
    usually it mounts connected mobile device to /dev/rfcomm0. Through this port, you can communicate with the device .
Connect to USB Modem (Like Reliance DataConnect, TATA Photon, IDEA Netsetter etc.)
  1. ability to connect to any locked/unlocked USB internet Modems (Zero Devices)
  2. fully automated connection setup. No manual input is needed except to specify connection name.
You can find more details and download Sakis3g from this address
http://www.linuxconfig.org/mobile-broadband-connection-and-sakis3g
hope this will help you to solve your issue.
Dec 12, 2010 | Samsung SGH-X820 Phone
Code 10 problem showing in on modem(device manager)
that is a problem with your DIAL-up modem which is the old style, use your phone and dialin type of internet connection. so basically if you're on high speed you dont really need it, you can right click and disable. if the modem is in a desktop in a pci slot, you can actually just remove it all together. code 10 means the device wont start either due to hardware failure or bad drivers...but again, its a dialup modem and oyu're on highspeed so you dont even need it.
Apr 26, 2009 | Arris SM56 (SM-56-PCI) Modem
Modem
Found this after some deep looking from blackberry itself: Good Luck
A BlackBerry smartphone with tethered modem capabilities can be used as an external modem to connect a computer to the Internet.
Summary of Tasks To set up a tethered modem, complete the following tasks:
  1. Install BlackBerry Desktop Software 4.1 or later (one time only).
  2. Set up the Internet access point name (APN) (one time only).
  3. Configure dial-up networking (one time only).
  4. Connect to the Internet using dial-up networking.
Task 1
Install BlackBerry Desktop Software 4.1 or later on your computer.
When you install BlackBerry Desktop Software, the drivers that allow the BlackBerry smartphone to communicate through the Universal Serial Bus (USB) port and virtual communications port are installed. The standard modem, which is used by dial-up networking, is also installed.
Note: If upgrading your BlackBerry Desktop Software from version 4.0 to 4.1, the required virtual communications port and standard modem might be removed during the upgrade process. If this is the case, re-install the BlackBerry Desktop Software 4.1 or later and choose the Repair option to re-install these components.
Task 2
Set up an Internet APN.
  1. Click Start > Settings > Control Panel.
  2. Double-click Phone and Modem Options.
  3. In the Phone and Modem Options window, click the Modems tab.
  4. Select Standard Modem and click Properties.
  5. Click Change Settings.
  6. In the Standard Modem Properties window, click the Advanced tab.
  7. In the Extra initialization commands field, type the following: +cgdcont=1,"IP","<your Internet APN>"
    Note: The following is applicable for T-Mobile® customers only:
    The extra initialization command is: +cgdcont=1,"IP","wap.voicestream.com"
    Note: If you do not know your Internet APN, or if you do not have an Internet APN, contact your service provider.
  8. Click OK.
  9. In the Phone and Modem Options window, click OK.
Task 3
To configure dial-up networking, complete the procedure that is appropriate to the operating system you are using:
Windows Vista
  1. Click Start.
  2. Select Connect To.
  3. Click Setup a connection or network.
  4. Click Setup a dialup connection.
  5. In the Dial-up phone number field type *99#.
  6. Type the user name and password provided by your service provider.
  7. In the Connection Name field type BlackBerry.
  8. Click Dialing Rules.
  9. Make sure the profile created in Task 2 has been selected, and then click OK.
  10. Select Connect to establish an internet.
Note: For instructions on connecting a computer to the Internet using a BlackBerry smartphone with CDMA as a tethered modem, see KB04664.
Windows XP operating system
  1. Click Start > Settings > Network Connections.
  2. Double-click New Connection Wizard. The New Connection Wizard opens.
  3. Click Next.
  4. Select the Connect to the Internet option. Click Next.
  5. Select Set up my connection manually. Click Next.
  6. Select Connect using a dial-up modem. Click Next.
  7. If the Select a Device screen appears, select the Modem - Standard Modem check box. Click Next.
  8. In the ISP Name field, type a name for your connection. Click Next.
  9. In the Phone number field, type *99#. Click Next.
  10. Indicate which users will have access to the connection. Click Next.
  11. Type the user name and password provided by your service provider. Click Next.
  12. Click Finish.
  13. In the Connect window, click Properties.
  14. In the Properties window, verify that Modem - Standard Modem appears beneath the Connect using heading, and then click Configure.
  15. In the Modem Configuration window, clear the Enable hardware flow control check box and make sure none of the other check boxes are selected. Click OK. In the Properties window, click OK.
Windows 2000 operating system
  2. Double-click Network and Dial-up Connections. Note: The following is applicable for T-Mobile customers only:
    Under the networking tab in the properties window for the dial-up connection, clear the Enable LCP Extensions check box, as well as all check boxes beneath the PPP Settings window.
  3. Double-click Make New Connection. The Network Connection Wizard opens.
  4. Click Next.
  5. Choose Dial-up to private network. Click Next.
  6. In the Phone number field, type *99#. Click Next.
  7. Indicate which users will have access to the connection. Click Next.
  8. Type a name for your connection. Click Finish.
  9. In the Connect window, click Properties.
  10. In the Properties window, verify that Modem - Standard Modem is selected, then click Configure.
  11. In the Modem Configuration window, clear the Enable hardware flow control check box and make sure none of the other check boxes are selected. Click OK.
  12. In the Properties window, click OK.
Task 4
Note: During this procedure, do not operate the BlackBerry® Browser or any third-party applications on the BlackBerry smartphone. An active data session might interfere with the modem connection. Also, make sure an ethernet connection is not active at the same time.
  1. Connect the BlackBerry smartphone to the computer.
  2. Open BlackBerry Desktop Manager.
  3. Click Start > Settings > Network Connections > <name of your new connection>.
  4. Type the user name and password provided by your service provider.
  5. Click Dial.
Apr 07, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Driver not kicking in dial up modem win 98 it says put in start up disc wich i dont have
Sir,
Which modem.? also send me the which driver? i will send back you link for free download. Plz tell me the exact software name.
Thanks Good Luck
Appreciate to rate as "Fixya"
Mar 10, 2009 | Microsoft Windows 2000 for PC
I have acer aspire one without a modem
Hello there,
You say you dont have a modem....but you want to connect via dial up?
Well ok, you need to do the following:
1. Contact an ISP (people like Virgin, Tiscali, TalkTalk, etc etc etc)
2. Sign up for the package you want.
3. They will send you a modem. It wont be for dial up but broadband.
4. Connect it and off you go.
However, if you REALLY want to use the internet using dial up you will have to go find an old cheap dial up modem.
BT, Tiscali and a few others do let you use a pay per min rate for dial up, but their is no one I know of that lets you get on line for nothing at all.
The only other service I have heared of was here:
http://www.connect4free.co.uk/
And even they charge 1p per min.
So if I were you.... go broadband as its faster and in the long run, cheaper.
If this has helped you please rate it so that I know.
Thank you.
Feb 15, 2009 | Acer Aspire 5500 5570-2609 Laptop
Missing modem
what is XE3 circa 2002, 15 years young. wow.
XP is now 3 years dead, at microsoft.
why not at least upgrade to Win7. be wise to do that.
XP must have SP3, if not it will fail, and even with it it fail.
lots of USB devices for example will fail. here.
dial up, you dont run DSL.
ive not see dial up in 20 years. why dial up.?
if compelled to use dial up, you need a modem that XP understands
most of them it does not. nor will it ever,
there are 2 classes of modem. (DIAL up to POTS)
1: software modem (99% software, and a box) they SUX. all do.
2: hardware modem, best is USB. by
and A good dial up program,. windows dial up software stinks.
https://www.cdw.com/shop/products/Hayes-ACCURA-World-Approved-V.92-56K-External-USB-Mini-Modem/1651998.aspx
i see this is HP supported (was) modem
Agere systems soft PCI
it needs the HP.com driver to run that modem
does the number you dial buy hand (using a POTS phone)
dial up and answer and squeal? if not its hopeless that number
you need to pay for superscription service, and with a pass word.
LIKE HERE
http://www.earthlink.net/dialup/
THE PROBLEM IS HP NO LONGER SUPPORTS YOUR PC
SO THERE ARE NO DRIVERS. now.
why not get 10 year or newer PC, or get DSL to home
or cable modem with only 1 channel active, (slow like dialup)
for cheap. (im using 16channel now, as i type)
or buy a new modem and connect it and use the new modems
disk to install a nice dialer for you.
but finding one is not easy now.
the best modems, are Hayes, there hardware modems are like rock. i used them back in the ARPnet days and on amocat.
Apr 20, 2017 | HP XE3 SYSTEM BOARD WITH MODEM & LAN HP...
Prada ke850 software
hey there,
This took me sooo long to figure out; half the global LG sites don't work for downloads, and even then you're never sure which one you need!
1. google 'LG Mobile support tool', and download it.
2. go into 'settings -> connectivity -> USB connection' and select 'data service'.
3. connect the phone to your computer with the USB cable.
3. run the LG mobile support tool (it's a small exe file that doesn't need installing)
4. go into 'customer support -> application, manual and USB driver download'
5. enter the IMEI, select the model number (KE850A), and serial number in the fields given. These can all be found behind the battery
6. click 'read info'
7. It should list 3 things in the box below; the software, manual, and USb driver.
8. double-click on the one(s) you want to download!!
Spread this around; I think many people have had this problem and I spent hours try to obtain the software myself.
Oct 15, 2007 | LG Prada KE850 Cellular Phone
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
