Question about RCA 32V524T TV
Rca 32v524t chassis-atc010a
Tv powers on but when picture comes up tv shuts down and hold down the volume bution tv stay on but no sound.
  • 1 more comment
  • yme17770 Dec 23, 2007
    tv turns on after about 5 seconds it shuts off
  • Mieux Jan 26, 2008
    I am having the same problem with my RCA 27v414t chassis atc010a. I am only able to watch it for a few seconds before it shuts off. I tried unplugging it overnight with no luck. I can hold in any front panel button and the TV will stay on but as soon as I let go of it, the TV powers off. When I plug my TV in, I hear a clicking noise that sounds like the TV is powering on, then it will click itself off.
  • gmccarter Aug 26, 2008
    I have the same problem with my RCA model 27v414t chassis atc010a where it turns on and off by itself. I would assume that replacing the button control module would solve my problem. Now my problem is finding that part. Where is a good on line parts dealer with an exploded view of the tv that you can order parts from?
Replaced,off/on vol,up and down,and channel up and down.
Posted on Jun 23, 2008
Picture on TV shuts down but sound still on.
If this RCA TV has a Chassis number of ITC222 then you need to call a tech to swap out the deflection circuit board for a new or rebuilt board. This RCA Chassis is a TV Techs worst nightmare to repair.
Jul 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
On light stays on and can not be put out. no other action takes place such as a lit screen or sound.
bad panel its done u can unplug re try after 45 min is i clean alot dust aorund it heat can build up gotta have good power supplies with these monster power strips with clean power to make power stable these tvs so touchy on vlatge going up and down
Jan 18, 2008 | RCA 32V524T TV
Parts for rca 32v524t / ATC010a
Hello Rick008,
Try www.electronix.com they have a wide range of parts. Just make sure to match the IHVT properly.
Thank you,
Shuttle83
Oct 04, 2008 | RCA 32V524T TV
RCA Model 32V434T chassis ATC010A
for shure your fly back transformer is bad is a commom problem in this chassis
Mar 29, 2008 | Televison & Video
CAN IT BE FIX?
Sounds like a bad horizontal transistor and flyback transformer . Do you know how to unsolder and or solder ? If so you might have a chance . If no the avg. to get repaired is around $90.00 to $130.00 so shop around as some shops will charge more . The parts you could buy your self for around $30.00 to 40.00 . Good luck and if you think you could fix let me know and see if i can get you part numbers .
Mar 15, 2008 | RCA 32V524T TV
RCA 32 in TV no picture no sound just a beeping noise TV power is on
Hello cote,
This indicates a problem in the power supply either the low voltage switching supply or the High voltage power supply. The sounds you hear is the shutdown circuit activating, I would not suggest that you try to repair this problem because of the dangers involved. I would suggest that you take it to a qualified TV repair shop. This problem should not cost you much, however it is the best choice for the problem you described.
I hope this helps,
Thank you,
Shuttle83
Mar 14, 2008 | RCA 32V524T TV
My RCA TV
I Just started to service one of these RCA ATC-010 chassis,I found a shorted Horizontal Output transistor 2SD-3402.
This could be just a failure of the transistor itself or the transistor failed because the flyback transformer has either shorted windings or internal diodes. These parts are not expensive,I suggest replacing both at the same time to save yourself future aggravation.
Jan 28, 2008 | RCA 32V524T TV
This sounds like something best handled by an experienced tech since the fix involves extreemly high voltages nearby,
If you have a very good knowledge of the inner workings of tv's then ask for more information.
Nov 21, 2007 | RCA TruFlat 27F520T 27" TV
RCA 32V524T- Blown fuse?
If you blew the fuse, the TV would do absolutely nothing - no lights, no sounds, nothing. It could be that the loud zapping noise you heard was the high voltage transformer arcing or shorting out. This could have caused the horizontal output transistor to short, and the set will not start as a result. You should have the set serviced by a qualified tech.
Sep 01, 2007 | RCA 32V524T TV
Television will not turn on
look on the rear of the set and find out what chassis in your set.
Aug 30, 2007 | RCA 32V550T 32" TV
RCA 32V524T TV Logo
553 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
