Question about Whirlpool GU2400XTP Built-in Dishwasher
Start light flashes - lot of water in machine - she no work!
ADP 951 dishwasher is not working - found a quantity of water in the machine after last wash yesterday - the start light is flashing but won't turn the machine on although I can get it started for about 20 seconds by holding the start button down for a while but then the machine cuts out. The machine is 9 years old but had little use.
  • kingsley5 Jul 26, 2009
    Drain has been completely cleared but still doesn't work. We had a serviceman in about two months ago when we had the same problem but he said that we were using the wrong (and too much) dishwashing powder. He said that we were lucky that an expensive part underneath the dishwasher was OK - not sure the name of the part he was speaking about. I have changed to the recommended brand of powder and have been careful not to overfill the powder receptacle.
  • Michael Canto
    Michael Canto May 11, 2010
    Check the drain for debris, that maybe the reason for the remaining water. Holding the button down for a while isn't good.
  • 52 Answers
Check to make sure the drain hose and filter is clear
Posted on Jul 26, 2009
  • acereno Jul 26, 2009
    i would say there is still some clogging .....remove machine and have a good look underneith the pump itself may be cloged ....if this is beyond your skillset you may have to call service man back
    note ..please use liquid detergent ....and you should only need to fill compartment about half way ....if machine is not cleaning dishes it may mean it's time for a new machine ...very important to get a good machine , the cheap machines are garbage ...i recommend the "whirlpool quiet partner" about $500 bucks but worth every penny ....
    good luck
Whirlpool adp 951
I have nardi dishwasher model LSFHLX IT SHOW E2 error after completing the programe what problem plz help
Dec 15, 2013 | Dishwashers
ADP 951 start light flashing permanently
how many times does it flash there is a pause look for it, there is a tech sheet glued to the lower cover or to the bottom of the tub behind the lower pannel that has the codes discriptions and tests turn off power to it befor removing pannel
Dec 08, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
GREEN LIGHT KEEPS FLASHING ON MODEL ADP 951 STARTS FOR A FEW SECONDS THEN STOPS
The same occurred with my dishwasher. I solved it by depressing the start button for 10 seconds. Worked for me...hope it works for others too.
Dec 04, 2009 | Whirlpool Dishwashers
Dishwasher (Whirlpool ADP 952) not working
I have a whirlpool ADP 952 and the start button is flashing and it won't work
May 25, 2009 | Dishwashers
Flashing lights on Hotpoint FDW20P Dishwasher
No solution! tried resetting to factory defaults but ended up that even the drain pump stopped working. after flooding the kitchen (nearly). I decided it was terminal and am loking for a new dishwasher urgently as I type. Cheers.
Feb 18, 2009 | Hotpoint 24 in. DWF32P Free-standing...
Flashing light
I had this problem at home too, it turned out to be a kink in the water outlet pipe. I straightened out the kink in the pipe, put duct tale around it to strenghten it and the dishwasher has been working perfectly since.
Aug 08, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Dishwasher not draining
if you hold the start button in it should reset,possible cause could be a blockage in the pump or drain outlet under the sink where the drain hose connects.hope this helps.
Mar 05, 2008 | Dishwashers
Start light flashing
start light on and no other action could mean that the door catch has gone faulty, test accordingly and replace if needed, no wash cycle will work if this item is faulty, the waste outlet pump may be the only part that will work on some models, this is a safety feature hope i have helped if so please rate me, work safe unplug when testing
Sep 21, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Machine won`t fill
the water-inlet solenoid valve is inoperative-replace it
May 30, 2007 | Zanussi 24 in. DE6544 Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
1,025 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
