Question about HP Photosmart C7280 Laser Printer
MY HP PHOTOSMART C7200 ALL-IN-ONE WILL NOT RECOGNIZE THE PAPER
I HAVE RELOADED THE PAPER IN THE PAPER TRAY AND PRESSED COPY AND A MESSAGE COMES UP SAYING THAT THERE IS NO PAPER. I HAVE UNPLUGGED IT, RE PLUGGED AND GET TH SAME MESSAGE. THIS PRINTER IS JUST OVER A YEAR OLD AND NOT USED FOR BUSNESS PURPOSES. I NEED HELP PLEASE........
    Brigadier General:
  • 4,090 Answers
Try cleaning the paper rollers with alcol to remove impregnated ink which causes the roillers to become shiny. It is failure to grip the paper that usually causes this. use a plastic pot scourer to gently roughen the platten roller to allow it to grip better.
Posted on Jul 25, 2009
I have an HP Photosmart C7200 All In One Series. On my previous HP printer, I was able to copy documents and shrink the images. Is this possible on my new Photosmart C7200?
yes it is ,, Once you install the drivers propperly then all the features will be in the toolbar. you can axcessthis tool bar by pressing the copy button on the printer, then you can reduce the image size. Another method is by using the scanner tool bar, aviable in the all programs menu(START / ALL PROGRAMS) once you start the tool bar, simply click copy and folloy the onscreen instructions then set it according to your desire.
Jul 29, 2008 | HP Office Equipment & Supplies
Can't print onto photo tray!
There should be a switch on the front to select the "paper feed". There should be an indicator laight to show which paper feed is active.
Aug 23, 2009 | HP C7200-69016 Network Adapter
My HP C7200 printer keeps saying out of paper.
Usually when this happens you need to clean the rollers that pick up the paper from your paper tray. This video shows you how to fix that...
Mar 28, 2009 | HP Photosmart C7280 Laser Printer
HP c7180 message "Push output photo tray all the way down"
I have the HP C7280 and I was able to fix the problem.
HP seems to have 3 trays. The bottom tray is for the paper. The middle one has a small blue tray for the photos and the top tray is where the paper comes out.
Well I lifted the top tray where the paper comes out (it can angle up) and then I clicked OK on the problem. I may have even rebooted, but then I got a new error message which is good. It said to push photo tray (the small blue tray) all the way in which I pulled out and pushed back in. Then I pushed the top tray down so all is flat again. I clicked OK and it re-calibrated with no more error messages! Hope this helps.
Feb 16, 2009 | HP Photosmart C7180 All-In-One InkJet...
Out of Paper
Your welcome. So, fix ya?
Jan 30, 2009 | HP Photosmart C5280 InkJet Printer
My HP C7200 printer won't print from the photo tray
If you using a mac: After choosing the Photosmart C7200 to print your file on the print preview, change PAPER SIZE to 4x6, then lower down, change from PREVIEW to PAPER TYPE/QUALITY, more options will open underneath, on SOURCE, change from MAIN TRAY to PHOTO TRAY. You should also change the PAPER TYPE to some kind of PHOTO PAPER (whichever one your using, but the standard seems to be HP ADVANCED PHOTO PAPER)
Jan 27, 2009 | HP C7200-69016 Network Adapter
HP Photosmart c5180 Paper Feed Problem
first of all power off printer
then after back side open tray. and clean all dust.
some time paper are jam or cut their so, printer sense paper still in their.
so do this u can printer again easy.
Nov 09, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart 3310 does not recognize paper in tray
This is usually do to a sensor, your correct on that, thers usually a plastic piece that indicates theres paper and its broken or worn.
The other thing is that it may be the little rubber grabber is worn and not grabbing the paper, so the printer thinks thers no paper because nothings going through. These parts can be orderd but are usually costly depending on the printer. If its under warranty, take it back.
Also, check the trey and make sure it isnt a I.D.10.T error and you just set the paper to legal or something. I've made that mistake before.
Nov 27, 2007 | HP Photosmart 3310 Printer
HP Photosmart C7280 Laser Printer Logo
176 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
