Question about Garden
Where can I see an exploded view of the clutch for the front wheel drive on this puppy? It'a Scotts 6.5hp Magnatorque 3 im 1 with a Tecumseh OVRM120 22043E engine. It looks like that little gearbox under the axle drive pulley rotates when you push the drive lever forward, but it doesn't disengage when I pull the lever back. I'd rather not take it apart with no idea what I'll find if I can avoid it.
    Problem Solver:
  • 10 Answers
Try partstree.com I'm not sure if they would have this model online. but they might be able to get it for you.
Posted on Jul 26, 2009
My 8hp Tecumseh jumps in and out of drive as Im snowblowing. Have to pull it back and forth and sometimes jerk it around to get it to kick back in. Any advice?
which blower is this on?
sounds like the drive wheel is worn or out of adjustment
or you could have worn bushings on the axles or grease on drive plate
be sure gas is less than 1/2 full
tip it on its nose remove plate on bottom and inspect
Jan 04, 2015 | Tecumseh Garden
I have a i=2 year old Scotts lawn spreader. It is in good shape but the wheels fell apart. Where can I get replacement wheels
I am sorry to hear about the problem with your spreader. We should have replacement parts available to send. Please give Scotts a call @ 1-800-543-8873 at your earliest convenience to see what we can do to assist you.
Feb 11, 2011 | Scotts Company Scotts& Accugreeen 2000...
Need diagram for serpentine belt
Fig. 1: Exploded view of the belt drive fan assembly-1992 vehicle shown
To install:
1. Position the fan on the drive clutch. Install the bolt and washer assemblies, then tighten to 12-17 ft. lbs. (16-24 Nm).
2. Position the fan drive clutch, fan assembly and fan shroud, then bolt the fan and clutch assembly to the water pump hub. Install and tighten the clutch retaining bolt and water pump assemblies evenly and alternately to 15-22 ft. lbs. (20-30 Nm) for the 3.8L engine or to 36-47 ft. lbs. (48-65 Nm) for the 5.0L engine.
3. Install the fan belt. Align the fan shroud and adjust for equal fan-to-shroud radiator clearance but maintaining a minimum of 0.38 inch clearance to the fan tip on 5.0L engines.
4. Install and tighten the shroud retaining screws. On 5.0L engines, snap the air deflector assembly to the sub-frame cross brace.
Hope helps (remember to rate and comment this
Dec 03, 2010 | 1995 Ford Thunderbird
Valve setting for a Tecumseh Model ovrm120
.004 inches on both intake and exhaust
Jul 01, 2010 | Sears Garden
How many clutch plates are inside A 1990 suzuki dr650s
Reading from my manual (Suzuki Service Manual)
Primary drive gear (the clutch "basket")
Spacer
Clutch pressure plate
Clutch drive plate (has friction pads) x 6 of these alternating with...
Clutch driven plate (smooth) x 6 of these
Clutch drive plate (thicker with friction pads) x 1 of these to finish plates
Wave washer
Wave washer seat
Clutch sleeve hub then goes on with springs etc.
please check the site below, it has exploded views of the bike in all categories.
Cheers.
http://www.cmsnl.com/suzuki-dr650-s-1990-1991-usa_model15961/partslist/
May 09, 2010 | 1990 Suzuki DR 650 RS
Replace front wheel bearings. I NEED TO SEE AN EXPLODED VIEW OF AXLE AND BEARINGS AND SPACERS
hi emelinabarne
the link below is the parts catalogue for your bike. page 47 and 48 includes an EXPLODED view of the front wheel assembly. actually of all the parts.
http://www.yamaha-motor.com.mx/Manual_Partes/Catalogos/Deportivas%20(Crucero)/XVS1100%20V%20Star/5YS8_2005.PDF
hope this helps you out buddy.
regards,
voodoo
May 04, 2009 | 2005 Yamaha V Star 1100 Classic
Oil leak tecumseh engine OVRM120-22053F
oil seal is worn out from durbis wrapped around crankshaft need to replace oil seal by removing blade and hub
clean cranksaft with fine sand paper
a sharp awl punch in the outter edge corner of seal on a 45 degee angle then slide seal off
heres the manual.pdf page 75
Mar 23, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Scotts 20" reel mower. Drive wheels will not turn blades any more. Blades turn freely, but will not be driven by wheels.
This is almost certainly a problem with worn pinion gears, which are unfortunately made of plastic. Replacements are just a couple of dollars, but you'll probably want to buy a few for each side in the event this happens again. The Scotts 20" reel mower is manufactured by Great States 1-800-618-7474. You can also find more information at www.reelmowersetc.com and the user manual for this particular mower can be viewed at http://www.reelmowersetc.com/2000-20.pdf.
Feb 17, 2009 | Great States Corp. 18 In. Scotts Deluxe...
Garden Logo
133 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
