Question about Panasonic AG-DVX100B DV Digital Camcorder
Unsteady White balance
Even if I set the white balance it'll always shift....  it does it in preset, as well as in the other settings.
    Problem Solver:
  • 9 Answers
SOMETIMES WHITE BALANCE DRIFT IS DUE TO THE SHUTTER BEING ON, TRY TURNING SHUTTER OFF
Posted on Jan 22, 2010
  • 22 Answers
You must switch to preset, push the awb button on the front to switch from auto white balance indoor to auto white balance sunlight (3200k to 5600k). This will automatically balance the camera to the approximate settings needed. For fine tuning the white balance.....
If you want to set the A and B buttons, first switch to A, then hit the Auto button by the user 1,2 3 button until you are off of auto total white auto focus auto iris mode AWB A ch will show in the viewer hit the Auto again and ATW shows, meaning Auto total white is on, and you will not have control over the white balance, it will continue to float and try to automatically balance in the middle of your footage. Once you are on AWB A ch from hitting the AUTO button, then point the camera at the white you are balancing to (of course put the white under the lighting you want to balance to) push the AWB button on the front of the camera and hold it in until the camera goes through the white balance mode and the black balance mode,...the camera will go dark while this is being done but an OK with the correct color temperature will show briefly on the screen when it is done and you can release the AWB button. Now you have set the A button to the white balance for the current lighting.
If you are going to be switching between indoor and outdoor, do the same for the B button above and set it's white balance to the exterior light color temp. that way you can just switch between A and B when you are moving fast between interior and exterior shots and have the correct color temp.
You could always leave the switch on preset, and hit the AWB button on the front to switch from 3200 to 5600, but remember not all light is either 3200 or 5600, that is why we use the A and B settings and get the White balance for the exact color temp of the space being shot in.
Posted on Aug 10, 2009
All the pictures come out with a pink tint! I have a E-500
Not much to go on here but I'll have a go at it. My first impression is that the camera "white balance" has been altered the E 500 has eight programed white balance settings. It also supports five picture modes one of which is Sepia which is a soft overcast of tan which could be mistaken for pink.
What may have happened is that camera white balance has been shifted to the florescent setting.
Here is a link that might help you reset your camera
http://www.cameralabs.com/reviews/OlympusE500/page3.shtml
About half way down the page you will see the presets for white balance titled colour and white balance.
Dec 18, 2010 | Cameras
My Nikon p80 has difficulty focusing in low light. Also, the white balance is difficult to control and most low light photos are too yellow.
Seems to be interesting.
For low light focusing problem here is the solution which works with any digital camera.
I have observed that P80 has a slow focusing symptom. If you are in TELE range that is lens out. Then you will be hitting this issue very frequently.
Check if you are not restricting that red light bulb from throwing the light on your subject.This light is to assist the camera to focus.
Try doing this. Illuminate the object with a small/capable torch. Sometimes AF assist lamp is not doing the job.
another solution is focus in small steps. move lens out a little half press the focus/snap button. repeat this till you get the desired frame. This somehow helps camera to focus difficult objects.
White Balance:
Nikon P80 has good white balance functionality. But if you do not get what you want you need to set the WB manually. Here is the procedure to set white balance manually.
Procedure:
You need to select the preset manual for this procedure. Keep a white colored object with you always. This should be of size of a playing card at minimum.
when you will select the manual white balance preset. it will show you the measure option. Keep your white subject in front of the lens and press measure such that the camera view is filled with that white object's view.
Now you are ready to go. Your Camera will take the pictures just right.
Sep 22, 2010 | Nikon COOLPIX P80 Digital Camera
White balance presets
You cannot access white balance settings while in the Auto or a Scene mode. Set the camera to P, Av, Tv, or Manual, then press the Func/Set button. White balance should be the top icon on the left side of the LCD (usually says AWB).
Jul 20, 2008 | Canon PowerShot G9 Digital Camera
What are the white balance modes available with the camera?
The following White balance settings are available for the A2: AUTO, Preset (Daylight, Tungsten, Fluorescent, Shade, Cloudy, Flash and Custom1 to 3) The following slight adjustment is possible: * At setting Daylight, Tungsten, Shade, Cloudy and Flash: +3 to -3 (one unit is approximately equal to a 10 mired shift.) *At fluorescent lamp setting: equivalent to 7 fluorescent lamp(3 -wavelength colored fluorescent bulb, 3-wavelength white fluorescent lamp, 3-wavelength neutral white fluorescent lamp, 3-wavelength daylight fluorescent lamp, white fluorescent, neutral white fluorescent, daylight fluorescent lamp)
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
The following White balance settings are available for the A1: AUTO, Preset (Daylight, Tungsten, Fluorescent, Shade, Cloudy, Flash and Custom1 to 3) The following slight adjustment is possible: * At setting Daylight, Tungsten, Shade, Cloudy and Flash: +3 to -3 (one unit is approximately equal to a 10 mired shift.) *At fluorescent lamp setting: equivalent to 7 fluorescent lamp(3 -wavelength colored fluorescent bulb, 3 wavelength white fluorescent lamp, 3 -wavelength neutral white fluorescent lamp, 3-wavelength daylight fluorescent lamp, white fluorescent, neutral white fluorescent, daylight fluorescent lamp)
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
White Balance
Color reproduction differs depending on the lighting conditions. For instance, when daylight, the setting sun or indoor lighting is reflected on white paper, the shade of white produced will be slightly different for each. By setting the WB (White Balance), you can achieve more natural-looking color. You can also preview different color tones by trying the different settings under the actual light source, and checking the result on the viewfinder and monitor. You can choose mode from Auto, Preset 1, Preset 2, Custom, One-touch, and White balance compensation.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
White Balance
Color reproduction differs depending on the lighting conditions. For instance, when daylight, the setting sun or indoor lighting is reflected on white paper, the shade of white produced will be slightly different for each. By setting the WB (White Balance), you can achieve more natural-looking color. You can also preview different color tones by trying the different settings under the actual light source, and checking the result on the viewfinder/monitor. You can choose mode from Auto, Preset and One-touch.
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
White Balance
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
Balance Function
This function is useful when you need more precise white balance than the Preset White Balance can provide. To set the optimum white balance for the shooting conditions, point the camera at a white object under the light source that you want to use, and press the OK button to set the white balance.
Sep 04, 2005 | Olympus C-7000 Zoom Digital Camera
White Balance
Color reproduction differs depending on the lighting conditions. For instance, when daylight, the setting sun or indoor lighting is reflected on white paper, the shade of white produced will be slightly different for each. By setting the WB (White Balance), you can achieve more natural-looking color. You can also preview different color tones by trying the different settings under the actual light source, and checking the result on the viewfinder and monitor. You can choose mode from Auto, Preset 1, Preset 2, Custom, and One-touch.
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Panasonic AG-DVX100B DV Digital Camcorder Logo
346 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
