Question about Samsung LN40B530 40 in. LCD HDTV
Tv not turning on and clicking non-stop - Samsung LN40B530 40 in. LCD HDTV
  • 6,784 Answers
HI, this is a typical power board issue. have it replaced asap, if possible. a weak or damaged power sector will usually click upon the attempt to distribute power. replacing the power board will fix this issue.
Posted on Jul 25, 2009
Tv power light(red) continuously blinks. and clicks off
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can vet an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/
Dec 31, 2013 | Televison & Video
When i turn my volume up or down on my vizio 32in tv. it wont stop after one click
Your main board needs replaced. The ic that is bad is in a Non Serviceable Area.
Mar 25, 2011 | Vizio L32 32 in. LCD HDTV
Timer light will not stop flashing. can't turn on TV
Unfortunately the first generation DLP's from Mitsubishi are prone to have Capacitor failure through out the chassis. Most likely that is what your set is experiencing. I would start by replaceing the suspect caps on the DM amd The Power boards. You can get the V26 Chassis DM/Power repair kit from www.tvrepairworld.com which also contains instructions.
Jun 21, 2010 | Mitsubishi WD-52725 52". Rear Projection...
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
AOC Plasma TV turns on by itself and changes channels non stop.
I have an AOC 32" LCD HDTV and it turns on by itself as well. Tuning is done via my cable box, so the tv is set on HDMI and I don't have the channel changing issue. I as well am trying to figure it out. The only thing I could suggest is perhaps the remote batteries are low and triggering on it's own. Try changing the batteries, or ensure that the remove it in a drawer or other room so that triggering the unit is impossible. Hope that helps.
Jun 17, 2009 | AOC A42HD84 42 in. Plasma HDTV
Clicking power supply? wont turn on
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsun. Know to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio conections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Jun 02, 2009 | Philips 32PF9964 32 in. Television
RCA P52929 changes channel non stop
try unplugging it from the electric wall outlet for an hour then plug back in, this should reset your tv back to factory default, you will have to adjust your setings if you changed them
Jan 25, 2009 | RCA P52929 52" Rear Projection Television
32PF9962 32''
Could be power supply failure
Mar 06, 2018 | Philips 32PF9964 32 in. Television
TV won't turn on just a clicking noise
ok this is a bit complex but im going to describe to you what you have to do\ 1) TAKE THE BACK COVER OFF 2) LOOK FOR WHERE THE SWICJ IS LOCATED 3) LOOSEN THE SCREW WHICH HOLDS THE BUTTON 4) CARRY ON LOOSEINNING BUTTON UNTIL YOU CAN PRESS IT 5) THEN CHEC IF IT WORKS IF IT DOES TITEN THE SCREW AND PUT COVER BACK ON IF NOT THEN CONTACK ME
Aug 26, 2007 | Philips Magnavox 20MT133S 20" TV
Samsung LN40B530 40 in. LCD HDTV Logo
387 people viewed this question
Jerry Greenberg
Jerry Greenberg
