Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Refrigerator Ice maker stopped working after power outage
We had a brief power outage. After power was restored, everything worked on our Whirlpool Side by Side refrigerator. Water dispenser and ice dispenser still work. Ice making switch is on (down position). Checked for ice cube blockages after looking after the trouble shooting section of the owner's manual. What next? Thanks!
  • Anonymous Mar 12, 2014
    my water filter system stop working after power outage can't get it to work how do I get for working again I cleaned it out and its still not working
  • Whirlpool Master
  • 8,220 Answers
Check THIS out
Posted on Jul 26, 2009
Westinghouse ice maker quit working
Is it your ice maker, or possible the blades that crush the ice or dispense the cubes? What can happen in the latter case is that during the storm the ice melted and pooled in the cutter mechanism. Then, when power was restored, the blades were frozen solid. To fix, investigate taking out the cutter mechanism and letting it thaw and drain. Then reinstall and use frequently for the first few days to prevent refereezimg.
Feb 26, 2014 | White-Westinghouse White Westinghouse...
My GE Side by Side refrigerator stopped making ice and dispensing water.
Check out the solenoids and power to the water solenoids for ice maker and door water.
Aug 22, 2017 | Refrigerators
Compressor will not start on a frigidaire refridgerator
The compressor gets power from compressor capacitor or compressor relay.On some models there is capacitor and on some there is relay.May be that relay or capacitor got shorted causing the problem.
But if that checks out ok,then its faulty compressor causing these.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Refrigerators
Chefmate mini fridge does not work after power outage
May be its board or board components got shorted.
These will help.
Thanks,.
Dec 22, 2012 | Koolatron Mini Fridge Compact Refrigerator
HI, I have a Whirlpool Side-By-Side Refrigerator model ED25PQXW01 and the ice maker isn't working, how do I fix it??
Hi
Check to see that the refrigerator has power and is working. Reset or replace the fuse or circuit breaker in the house if needed, especially if a power outage has recently occurred. Make sure the water valve is connected to the refrigerator and is fully turned on. Ensure that the ice maker is turned on. Some Whirlpool refrigerator models have a switch located above the ice bin; some models have an arm that should be raised up to turn the ice maker on. The arm is also located above the ice bin. Clear away any ice cubes that may have gotten jammed in the ice maker, bin or dispenser that may be preventing ice cubes from moving as expected in the system. Use a plastic utensil to clear away any obstructions. Contact an authorized service center for assistance if the above steps do not fix the issue.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 01, 2011 | Whirlpool 25.2 cu. ft. Side-by-Side...
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
98978yi
May 10, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker not making ice
i had same thing happen the line going to the ice maker was froze i too everything out of frezzer and let line unthaw for about an hour now works fine
Apr 28, 2009 | Whirlpool GD2SHGX Refrigerator
Whirlpool Fridge Freezer not working fridge is
ID THERE FROST BUILDING UP IN THE FREEZER?IKE
Mar 14, 2009 | Whirlpool ET4WSKXS Top Freezer...
Automatic ice maker quite working after 7 day power outage
Check to see if the power cable is ok. If your unit has a fuse, you may need to replace that. Looks like the power outage might have fuzzed up the power circitry. If neither of the above works, then you may need to get the machine serviced.
Sep 28, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker quit working
what happened you reset the computer (mother board) chances are you had a brief glitch in your power and it made the computer go hey wire
Dec 15, 2007 | Whirlpool ED5FHEXMQ Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
2,002 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
