My washing machine stops advancing in the middle of the agitation cycle and is full of water. I've tried to advance it myself by moving the knob manually to the rinse and spin cycle but this does nothing. I thinkg the timer may be broken but I am not sure. Help?
Actually, I don't think it is the drain hose, I think the mechanism that tells the machine the lid is closed is broken. You might be able to run a screw driver under the front lip of the washer, pop open the "rim" and physically press the button together with your fingers, which will start your cycle.
good luck
Posted on Nov 14, 2009
    Problem Solver:
  • 10 Answers
It sounds like your pump is pluged up or stop working. You will need to take out as much water as you can. Unplug the machine. From the back side you will see a pump with two hoses. You will need to remove one of the hoses and drain the rest of the water. Then check pump to see if there is any blockage. You might need to remove pump and take apart. It could be build up, nail or small screw. Only simple tools with screw drivers should be needed. Rinse and spin cycle will not work with water in the machine.
Posted on Jul 26, 2009
Washer will not cycle
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Kenmore 70 Series Washer Won't advance in the
    Bad timer. Try to find a used one if possible, this item is a little expensive.
    Aug 23, 2010 | Kenmore Washing Machines
    Stops in the middle of wash cycle
    Hi!
    If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Frigidaire washing machine gets stuck on cycles
    Apr 01, 2009 | Frigidaire Washing Machines
    My Kitchenaid washer stops on the rinse cycle...
    Do you have an age of the machine and model number? Is there a "spin only" cycle? On older machines, there was a center knob you could slowly rotate, one click at a time, to advance it through its cycle. Can you do that? If the unit is agitating, I don't believe the belt is your issue. Age and model please.
    Jul 31, 2017 | KitchenAid KAWS750L Top Load Washer
    GE washer does not agitate. Water does not stop filling.
    If it does not agitate at all, then it is either the motor, the clutch/motor control or the agitator.
    If the machine start agitating only when you advance manually the control knob, and at the same time is overfilling, that is probably because of the problem with the water inlet valve, or the water level switch, and that is also cusing the cycle to stop.
    See:It's overfilling
    Nov 20, 2008 | Washing Machines
    Whirlpool Washer will not progress to the rince cycle.
    that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
    I quote from : The cycle doesn't advance
    The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Washer won't advance from cycle to cycle
    * It's the timer, if your washing machine fills with water and begins agitating, but the timer never
    the timer.
    * It may be a cold-water supply problem, if the washing machine fills with water, agitates,
    Nov 16, 2008 | Danby DDW1805W Designer Series...
    Washing Machines Logo
    113 people viewed this question
    Top Washing Machines Experts
