Question about HP Photosmart 3110 All-In-One InkJet Printer
The printer constantly says out of paper, yet there is always heaps in it. It seems that the printer/rollers aren't grabbing the paper. Any suggestions?
    Brigadier General:
  • 4,090 Answers
The quality of paper you are using may not be compatible with the printer. If the paper does not become grabed by the rollewr the detector thinks there is no paper. Ensure the paper is stacked correctly and held in the guides properly...
Try a different brands of paper or a few sheets of firm colored poster sheet in it.. It may also be that the platten roller is worn smooth. Clean with alcohol a,d use a plastic pot scrubber on the roller a few times to remove any excess shine from impregnated ink
Posted on Jul 25, 2009
Why is my fax machine jamming all the time
Dear
If paper jam always,check the thermal ribbon correctly installed (the ink coating face upward and should above the print head)
If document jam always, check the ADF roller (white roller clean it)
Thanks.
Feb 26, 2015 | Panasonic KX FP215 - Fax / copier - B/W -...
Jam in duplex area
Its is trick..If its more then two pages print, printer grabs second page even first page in duplex unit., here its confusion. Check with simplex single print, see any paper mismatch error? or printer throwing paper in output bin after successful print?. No.. check fuser out sensor or paper out roller.
Print only two pages matter in duplex, check where paper struck? if paper our roller not grabbing paper back properly in time (slipping while grabbing back) gets jam error.
Always ensure that select proper paper size in printer.Other than this it may major issue, need technical knowledge..& possibilities are less to judge the exact problem..
Keep update us to resolve the issue.
Aug 22, 2014 | HP Color LaserJet Professional CP5225dn...
Oki c810 printer is having constant paper jams and tray not feeding paper at all
Your paper is too smooth for the rubber rollers to grab it.
You need to wet the rubber rollers. Ever licked your finger in order to turn a page in a book? Same concept solution here.
Remove the paper tray. Take a look inside the space created where the tray was, and locate the rubber rollers. Lick your fingers, and use them to moisten the rubber rollers.
Reset printer and print again. Or try "un-smooth" the paper where the rollers grab it.
Oct 05, 2010 | Office Equipment & Supplies
It will not grab the paper properly to print. After trying I receive the message saying there is no paper.
OK, if the printer does not grab, the rollers are probably wearing out.
There seem to be a number of posts of Canon printers of various models acting in this way. I think that when the rollers get old, they do not grab, and there is no economical fix for this problem.
So, I usually recommend that the printer be replaced with a newer one with good rollers, possibly brand new.
There are quite a few new WiFi printers on the market that would have no paper feed issues.
Good luck on finding a printer solution.
Jul 04, 2010 | Canon PIXMA MX330 Multifunction InkJet...
The rollers won't grab the paper. It may grab toward the end of the print job so that the second half gets printed on the top half of the paper. Or it just won't grab at all.
Dear User,
Your Printer rollers seems to go plane, and they are unable to grab paper properly. You should clean them with a clean piece of paper.
And you can also rub silghtly them with an ambry paper, if needed so that it may grip the paper properly.
Thanks
Jan 23, 2010 | HP Officejet J5780 All-In-One Printer
Paper feed problem
this is the rare case: there could be two problem 1) either some bit of paper would have been stucked inside the printer 2) or else the roller is not smooth. the roller inside the printer helps to draw out the paper gently.
Jun 15, 2009 | HP DeskJet 6122 InkJet Printer
Paper feed jams
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 08, 2009 | HP Photosmart C7280 Laser Printer
Paper feed problem, then error
SEPARATION ROLLER MAY NOT INGAGE CAUSING THE PAPER NOT TO FEED TO THE FEED ROLLERS THE PAPER DOES NT ADVANCETO THE REGISTION ROLLER THAT SET THE PAPER FO COPY CHECK TO SEE IF THEY ARE CLEAN OR WORN
Dec 07, 2007 | Konica Minolta magicolor 2400 Laser...
Constant "load paper in tray" error even when paper is loaded.
Contacted HP CEO, office getting some interest now!
Re bad paper feeder Did not use main tray feeder until now!
Nov 30, 2007 | HP Photosmart 3310 Printer
HP Photosmart 3110 All-In-One InkJet Printer Logo
52 people viewed this question
Seeker5211
Seeker5211
