Question about GPS
Touch screen wont work but it comes on has correct time but i cannot program it
    Brigadier General:
  • 4,090 Answers
Cost of replacing screen is in excess of a new GPS You might just want to ditch it and buy a new one
Posted on Jul 26, 2009
Nothing but black after replacing broken touch screen
Open the phone back up and unplug all the FLEX cables from the system board then plug all the FLEX cables back in, be sure that the flex cables are aligned correctly and full plugged in. Then try the phone again, I know there has been 4 times where I replaced an LCD and upon turning it on had nothing but black screen. Did what I said above and 3 times the LCD worked perfectly(must have been a FLEX cable not seated all the way) and the 4th time it was a bad LCD screen.
Aug 17, 2014 | HTC Desire Cell Phone
Fix touch screen phone
what type of phone is it? it sounds like your digitizer has either come loose or stopped working. I specialise with iPhones but on most displays youll have your LCD (picture) and your digitizer (touch screen) actualy attached to the screen is 2 ribbons which connect it to the motherboard in the phone. Your digitizer could be gone and hence why your touch screen wont work. either that or its came loose somehow.
Jul 04, 2013 | Cell Phones
Please tell me how to program my timer. How do I set the time and when it should come on and go off everyday
Smarthome has the T-1032 pdf manual
http://www.smarthome.com/manuals/4256.pdf
1) Test installation to see if your wiring technique is correct.
Open cover > set on-off switch to 'ON'
Press the tiny round reset button with paper clip
Screen displays 0:00, MO, MAN, OFF
Close cover
Push cover inward like a push-button (the cover is the manual override)
Lights should turn on
If lights don't turn on, then you need to rewire ... so re-post a re-wire question ... and then come back to this answer to program
2) Set Time and Day/ Correct time and day are needed for programs to work.
To start, notice on the screen - in the corners are little letters: MAN, MO, OFF. And to left of time is PM.
Set the Hour: Press hour button until correct hour shows, including PM or AM
Set minutes: Press MIN button until correct minutes show
Set the day. Press day key ... MO in corner changes ... for example TU is Tuesday, WE Wednesday, TU Thursday
Press one of the control buttons to finish operation
Programming overview
Timer allows 7 programs
Program 1, Program 2 etc
Each program has ON and OFF time
So you have to select Program 1
And then set DAY for Program 1, set ON time for Program 1, and then set OFF time for Program 1
Next you do the same for Program 2 , and then Program 3, 4 etc to 7
If you only want Program 1, then you do not need to set Programs 2 thru 7
Let's program
Press PGM button ... the timer screen show a P to right of time
The number 1 appears below P and indicates Program 1
Set days you want Program 1 to work: Press day button and you can see MO TU WE TH etc appear on screen.
If you want all week long, press day button until all 7 days appear in tiny print on bottom of screen
Now you have the Day set for Program 1
Notice the screen shows ON ... this means you are going to set the ON time for Program 1
First, Set hour you want Program 1 to turn ON: press Hour button until correct AM PM time shows on screen
Last, set minutes to go along with hour: press MIN button until correct ON time minutes show
You have the day, hour and minute set for ON time
Set OFF time for Program 1: we are going to set a Day, hour and minute you want Program 1 to turn OFF
Press PGM button, and notice that OFF appears in top right corner of screen
Set the day you want timer to turn OFF for Program 1 by pressing DAY button >>> Tip set same days you set for ON times. So if you selected all seven days for ON time, then select all seven days for OFF time
Set the hour and minute you want Program 1 to turn OFF by using Hour and MIN buttons as before.
OK, the ON and OFF day, hour and minute are set for Program 1.
To continue to Program 2, press PGM button until a 2 appears on screen below the P
If you do not want to set more Programs, then you're finished
To finish, press any control button
Close the lid, cross your fingers, you did good
Sep 30, 2010 | Aube Technologies Aube 7-Day 40-500w Light...
My coby touchscreen wont move back and forth or up and down
reset your phone once if not works then contact on the product website for updates or correction.thanx
Dec 25, 2009 | Coby MP-C7097 MP3 Player
Dropped phone in toliet. touch screen wont light up and wont work.
I do this all the time, grrr. This phone is toast most likely. Take out the sim card and memory card to prevent them from corroding. The phone may dry out and return "some" functionality, but it probably won't work correctly again.
Dec 03, 2009 | HTC G1
My touchscreen wont work on my 655 I believe
did you try calibrating the screen.if it doesn't work when you try to calibrate it then it looks like the touch screen is bad and you will have to replace it.even if the touch is bad the video should still come through.go to pref= use the directional keys to to the top. you should see a blue rectangle are the date and time.click the center button and go to touch screen to calibrate it.if it won't let you touch it then the screen is bad. if you have any more questions please email me at gaecmrazy944@yahoo.com
Jun 30, 2009 | Palm Treo 600 Handheld
Touch Screen fails to work
get it serviced?
my guess, damaged screen.
most shops would touch any Ipaq.
why not ask on a real HP forum?
my guess, the only hope for old Ipaq
http://h30434.www3.hp.com/
May 10, 2017 | HP iPAQ hx2190 Pocket PC
JIVA TP-5800 touchscreen problem
try cleaning the touch screen glass between the glass and the frame, if that fails, you need to replace the touchscreen glass
Jun 08, 2008 | Posiflex Jiva 5800 All-In-One...
Acer empowering technology
Hi
This should be correct solutions as well as risky..
Go to start menu and click on run.. A run window opens.. U type in that window that msconfig. Another window opens.. U select the start up tab.. There u can find some programs which are run at start up.. Many are unwanted for home use.. But don't touch others because u touch others means it may be a os file.. So u disable only the compaq program.. U can easily find that program from that.. Please don' t touch others.. After disabling restart ur system then that program will not run at startup..
After this restarting windows give a warning message that the system configuration settings changed.. There u can find the option that don't show this message again when start up.. U enable that and give ok.. I think now the problem is solved for u..
Arun
Feb 12, 2008 | Acer Aspire 5100 Notebook
Bottom screen wont respond to touch
Try closing and opening the device a couple of times, then try again, I think your flex cable is damaged...
Dec 10, 2007 | Nintendo DS Lite Console
GPS Logo
80 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
