Question about Shaw Robert RS-9420 Thermostat
No display on Robertshaw 9600; unit seems dead/furnace works
How do I troubleshoot a Robertshaw 9600 with no display?
  • richielj Jul 26, 2009
    I've changed the batteries twice. I know the heater works because we have two zones in our house and the other stat turns the unit on. I'm thinking I should just buy a new Robertshaw 9600.
    Thanks!
  • richielj Aug 22, 2009
    This is a good tip. I double-checked the batteries but the display on the unit was dead. I replaced the thermo.
  • 142 Answers
Have you checked to make sure you have a fresh battery in it
Posted on Jul 26, 2009
Testimonial: "A+"
How to fix robertshaw thermostat display after changing batteries?
How To Replace Thermostat Batteries - YouTube
? 1:46
www.youtube.com/watch?v=QFd5jGL6vpM
May 10, 2012 - Uploaded by KungFuMaintenance Kung Fu Maintenance demonstrates how to change out thebatteries on most digital air conditioner and heater ..
Sep 19, 2015 | Robertshaw Thermostat Accessories 9010-1...
My Robertshaw 9600 displays 99 degrees and because it is satisfied, is not calling for heat. The temp is actually in the lo 60's and falling. I've tried battery replacement, but nothing changed. Other...
Hmm. I don't think it posted the first time around. So I'll try again.
There is a temperature sensing diode on the back side of this thermostat's circuit board. This diode may have failed or become disconnected.
I'd lean towards its having become disconnected, as I've been inside an example of this Robertshaw (originally Maple/Chase) 9600 thermostat and noticed that the soldering on this part was of poor quality. So if you have a soldering iron, and know how to use it, you could probably fix it.
I have a web page (just the facts, no ads, malware or fluff) that talks of some other common problems with this thermostat and how to fix them:
http://greyghost.mooo.com/maplechase9600/
Feb 04, 2010 | Shaw Robert RS-9420 Thermostat
How to install maple chase 9600 thermostat
The manual is very specific.  http://www.icca.invensys.com/manuals/robertshaw/110-653B.pdf    The Robertshaw 9600 is the same unit. The terminals marked RH, RC, W, Y, G are where you put the wires, just loosen the set screws with a small flat head screwdriver, insert the bare wire into the hole and tighten the screw. Leave the jumper between RH and RC for most installations. The red wire goes to the RH. Please come back and comment if you need more specific help. Good luck
Jan 08, 2010 | Heating & Cooling
I have a RobertShaw 9600 and would like to set
go to there website and print the set up instructions, this should give you stsep by step set up.
Oct 27, 2009 | Heating & Cooling
My thermostat
Maple chase is the same I believe.Sounds like the thermostat is bad.I personally think the Honeywell 3000-4000 series thermostat are better.But the Maple should work!
Aug 18, 2009 | Honeywell Programmable Thermostat Heater
Hello
you have to have a thermostat! The thermostat tell the unite what to do. Get a new one.
Jul 25, 2009 | Honeywell Programmable Thermostat Heater
Repace the tstat. Bad display. Make sure the batteries you put in were good First. Russ
Jul 25, 2009 | Heating & Cooling
Thermostat problems
Have you confirmed that the thermostat is programmed correctly?
Did the thermostat ever control the temperature of the house properly?
When you indicate "kick", are you talking about flipping the Auto-On switch back and forth? The Auto-On switch only controls the fan, and no heating or cooling (Auto - fan runs on call for heat or cool, On- fan runs all the time.).
If "kick" means making the heating work, and if you have the same problem for making the cooling work, chances are good you have bad thermostat.
If the problem only occurs with the heating, and cooling works fine, then the problem could be in the controller board of the furnace, assuming you have a more recent (1990's or newer) furnace.
Jan 16, 2009 | Heating & Cooling
Shaw Robert  RS-9420 Thermostat Logo
1,983 people viewed this question
Top Shaw Electrical Supplies Experts
obsteiner
Gil Shultz
Are you a Shaw Electrical Supply Expert? Answer questions, earn points and help others
