Garden Logo
Michael Siebe Posted on May 31, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a JD LT166W/48 and need a mower deck belt
Level 3:
  • Master 6,688 Answers
  • Posted on May 31, 2017
Cindy  Wells
Master
Level 3:
Answers
6688
Questions
0
Helped
3532622
Points
21745
Do you mean the John Deere LT166 Lawn Tractor with 48" Convertible Deck mower. If so, the replacement belt is GX10063, according to the maintenance sheet: https://jdparts.deere.com/partsmkt/document/english/featbene/fb_MaintSheet_LT166_48CdeckLawnTractor.pdf . One vendor has the belt here: http://www.greenpartstore.com/John-Deere-Drive-Belt-GX10063.html .
I hope this helps. If you have a different mower deck, please add a comment with more information about your specific mower. I may be able to find additional JD parts for the machine. You can also look up parts here: http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt .
I need a belt diagram of John Deere L120 mower deck
Belt path for JD 100 series, 42" cutting deck, 2 blades.
How do I replace the drive belt on a john deere 265? There doesn't seem to be a clear answer anywhere. Please help
you can look at the manuel that came with the mower or if you did not get one, go to the JD mower web site and look up you model and download the needed documentation. If that is not possible contact the local JD mower dealer and get a copy of the mower deck docs and look at the instructions for belt replacement.
Dont know wheter to get primary mower belt or secondary mower belt for craftsman gt3000 48 inch deck mower...?
primary belt goes from the engine to the deck the secondary goes on the deck and connects the blades together
3helpful
2answers
I need a belt diagram for secondary belt on a john deere f525 with a 48 inch deck
Hi and welcome to FixYa, I am Kelly
By secondary belt I am assuming you need the deck belt routing. Here is a picture of the front deck belt routing: http://opebycrigby.tripod.com/decks/jd/jdf525.jpg
Thanks for choosing FixYa,
Kelly
May 04, 2011 • Garden
Replaced Mower Deck Drive Belt. Belt runs from Engine pulley to Mower deck Pulley. Purchased new belt rom JD dealer. Belt is slack, Is there suppodes to be a tensioner for this belt.
Yes, there is an idler arm with a pulley that presses either inward or outward against the belt to tension it. In some JD mowers, the arm is tensioned by pulling on a long metal rod that latches near the edge of the mower deck, but without the model number I can't be more precise about that. Just look for that extra pulley and arm it's mounted on -- you'll see a tension spring, and you should also see a way to pull the arm away from the spring to place it under tension. Good luck!
Aug 15, 2010 • Garden
4helpful
I need a belt diagram for a lt166 john deere mower 48''deck
From the JD site, you can get the drive and deck belt diagrams here:
***Don't forget to VOTE for the guys who take an interest in helping!
1helpful
John Deere Lt 166 ride on mower
jd lt 166 has 5 different decks
3 of which have the same belt routing
1st the belt needs to be adjusted correctly to stop it from "slacking off"
then on most decks the belt is routed in between the 2 small idler pulleys and then to the engine pulley
so let me know the deck i.e. 36", 42 ", 46", 48"
different belt sizes also
kendo
Top Garden Experts
Jay Finke
Jay Finke
john h
