Question about Alpine MRP-F300 Car Audio Amplifier
MY AMP KEEPS BLOWIN THE FUSE...i CHANGED THE GROUND AND HOT WIRE TO BIGGER GUAGE WIRE AND THE PROBLEM STILL THERE ..........THE AMP IS A ALPINE MRV-307
  • 655 Answers
Hello creelb22,
Fuses usually blow because of a short of too much current.
Test your wiring (including the speaker wires) and make sure they are not shorting or grounding against the vehicle chassis. Also make sure that the speaker voice coils are not shorted.
Hope this helps.
Posted on Jul 26, 2009
92 grand marquis i have 1 wire and fuse that keeps gettin hot and the fuse keeps blowin. the wire has melted down into where it connects to the back of the fuse box. It get very, very hot at the connection...
you have a slow short in system this can cause a fire you need to determine what circuit it is and check for either a defective part also bad electrical connection you will need to possibly replace the wire or insulate it after cause is found
Jun 30, 2012 | 1992 Mercury Grand Marquis
My amp keeps blowing its fuses whenits plugged in
Go over all your wiring. Make sure your power wire isn't grounded somewhere. If your power wire is touching any bare metal it will spark and blow the fuse the second you touch the power to your amp. Make sure your in-line fuse is about a foot from your battery, and make sure you have your ground wire grounded securely to the main chassis of the car/truck and that it is either same size gauge as your power or even a little bit bigger gauge. Also make sure no strands of wire from your ground or power wire are loose and reaching over touching the other where you plug them into the amp. If the ground and power touch eachother they will blow the fuse and possibly cause permanent damage to the amp.
Jan 06, 2011 | Pioneer Car Amplifier GM-5100T - 2CH 760...
I have a jl 10001, when i turn it up its cutting off saying low voltage. I'm running 4 guage wire do i need to go bigger?
Try using a capacitor and make sure you have a fused (+) directly to the battery post that is routed as short as possible. Ground wire should be short enough from a clear and clean body part. Try lowering down your output gain so it won't clip the system.
Jun 11, 2010 | Jl Audio 1000/1 Car Audio Amplifier
I have an alpine m1000 amp and the fuse in the wire from the battery to the amp keeps blowing. Does anyone have any ideas?
Check that you dont have a short on the main power cable from the positive of the battery too ground
If it only occurs when you connect the amplifier... then the amplifiers power supply has gone short curcuit.
Take amplifier into a qualified repairer and get it fixed
Nov 07, 2009 | Alpine MRD-M1000 Car Audio Amplifier
My amp keeps blowin fuses
try running a bigger fuse in tha power wire fuse holder
Oct 14, 2009 | Kenwood KAC-7202 Car Audio Amplifier
Using 12 gague wire on a 250 watt amp blowing fuse
Oh my yes. I would recommend number 4 as a minimum. Use the same size for the ground. Bond it to the body in the best way you can. Use a CAD welder if you know anyone in the pipeline industry.
But ideally, run the biggest guage you can afford. and FUSE IT!! Zero Guage or better, and buy a fuse block and put it at the battery. Otherwise your crash could be a crash and burn.
Apr 15, 2009 | Car Audio & Video
Alpine 1507
I would either try a bigger fuse, if possible, or turn the power output dial on the back of your amp down. This can be done with jus a simple flathead screwdriver. I suggestion would be to go out and buy a power monitoring cap. Wal-mart, or Tweeter usually distributes them. It'll have a LED reading on the top, with two wire hook-ups either on the bottom or the top for positive and negative, place this in between your amp and your subs in the wiring set-up.
Feb 25, 2008 | Alpine MRV-1507 Car Audio Amplifier
Fuse problems
output leads shorted by chance?
Jul 05, 2007 | Scosche Industries Scosche High...
"cur" error mrd-m1005
BUT MY AMP KEEPS SAYING CUR AND I ONLY HAVE 1 TYRE R IN MINE AND ITS KEEPS SAYING CUR I REMOVE THE GROUND WIRE TWICE AND IT KEEPS SAYING IT I HAVE A 8 GAUGE AND EVERYTHING THIS **** JUST DONT WANT TO WORK WITH ME SO TELL ME PLEASE
May 21, 2007 | Alpine MRD-M1005 Car Audio Amplifier
Open Questions:
See all Alpine MRP-F300 Car Audio Amplifier Questions
Alpine MRP-F300 Car Audio Amplifier Logo
259 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
