I have a luxman m-117 the left channel stops working
I do not have the mannual.i am using a marantz sr6400 as a pre amp. the luxman was given to me,works great. there is a switch at the back blt opperation on or off.The left channel cuts out after 2hr of use!! PLEASE help
    Scholar:
  • 113 Answers
Hiya, the first thing that comes to mind for me is the bias setting is incorrect. This is a common mod done by many people that often leads to bad things! The good thing is that it does sound likely as everything is OK at this point (hopefully).
I suggest it goes in to be checked and get someone who knows amps to set the bias correctly. I would advise you try (unless you have a bit of experience with meters etc) as things can go bang.
The bias setting for the amp are 0.5mv between TP1/TP2 and same on other channel TP3/tP4
Hope that helps
Posted on Jul 26, 2009
B&K AVP2000 left channel not working
Yes amps buzz when something gets near them - say a pen or probe and if you know what it is safe to touch a finger! Fortunatly for you the left channel is the same as the right. So if you believe it's the pre-amp work backwards from the where the power amp connects to the pre-amp, going through the pre-amp stage by stage - prodding the parts. Remember a buzz in the right a buzz in the left! No buzz in the left but one in the right fault found!
Ignore the power supply it's nothing to do with that as it's common to both channels.
Dec 30, 2012 | Audio Players & Recorders
How do I connect Marantz AV7005 to Marantz SR9600
Remove the little black jumpers on the 9600 that link the pre amp section to the main amplifier inputs. They are the top row of rca inputs on the back. Using single rca cables from the pre out of the 7005 into the main amplifier of the 9600 connect all the channels you have wired speakers for, L,R,C, SL,SR, etc up to 7. Connect all your sources to the 7005 with whatever cables you have it doesn't matter. Turn off the 9600 volume and use only the 7005 to control the volume. It works perfectly giving an awesome amp a new lease on life. Good luck!
Oct 17, 2011 | Marantz Audio Players & Recorders
Hi There, I have a Marantz SR7005 Receiver and Bose 901 Series VI speakers with the Bose equalizer. I'm struggling to figure out the best way to connect the Bose equalizer/speakers to the SR7005. ...
It sounds like you've read one of my many posts on 901 deployment in the AV world.
Functionally, what is the difference between one amp with 'x' channels or 'x' mono amps? Nothing. Pre-outs don't know or care what else an external amp does.
According to this link http://www.ecoustics.com/electronics/products/new/642968.html those amps are 2- and 5-channel, respectively.
There was a time when I had two bridged-mono Carver Cube atmps (at a real 400 watts) pushing one 901 each but that was big time overkill.
I now use a Carver AV-406 (functionally the same as your MM7055) with the 901 EQ in between the AV Receiver's front pre-outs and two 110-watt channels. Other channels on the AV-406 pull subwoofer and surround back duties. My AVR directly powers only the center and surround speakers.
The MM7025 would work for you.
Jul 07, 2011 | Marantz SR7005 Receiver
Center channel dosen't work on 10 yr old marantz 500$ receiver. Should I just buy a new one?
I'd do some more investigation first. Have you determined if the amplifier for the channel works or if it's a preamp problem using the built-in speaker setup controls?
With this unit's great audio processing features you might be able to bypass a failed amplifier using the pre-outs and drive an external amp for the missing channel.
You could always just get a modest stereo amp (like a Carver M-100T and bridge it), or use the extra channel for another center speaker or a subwoofer, for example.
Aug 12, 2010 | Marantz SR5500 Receiver
Will a Luxman R-117 receiver run my Bose 901's through the required equalizer?
Yes, connect the Active EQ into one of the abundant tape loops and set the receiver to monitor that one constantly. Or place it between the Pre Out and Main In's. What you don't want to do is have the Active EQ in front of any actual tape decks attached to the Luxman as it would affect their audio. Yeah, pre/main is the best place.
Jan 31, 2010 | Bose 901 EQ1915 Home Equalizer
The left channel tends not to work intermittently. I have tested the pre-amp and it appears it is from the turntable. One day it might work and the next it will not.
There will be a pre-amp in the turntable too, presumable you have checked the cartridge, and the everything on the turntable for bad connections?
If yes take the base off and check the pre-amp.
Dec 02, 2009 | Marantz Reference TT-15S1 Turntable
LUXMAN L-85V AMPLIFIER LOW VOLUME
Make sure that you have the turntable connected to the PHONO input. If there is none (I don't know your specific model), then you will need a phono pre-amp. Connect the output of the pre-amp to tape-in or Aux in and the unit should work as expected. The alternative is that you may have the tape monitor turned on. Check that as well.
This unit is old enough to have pre-out and amp-in connectors on the back. Make sure that those are connected to each other. Use standard RCA cables.
If none of those resolve the problem, there is an internal problem that will need a bench to resolve.
Dan
Oct 26, 2009 | Audio Players & Recorders
Multi Room Function on marantz SR-19
Hi..
Put a RCA (phono cable) splitter at the pre-out /main in.
That way you can go to both amps with the same signal
Jan 14, 2009 | Marantz SR-19 Receiver
Loud distortion on Front Channels
Well, the nice thing about the newer amps is that the actual amp circuitry is all contained in a module and you don't have to do much troubleshooting. Just replace the module for that pair of channels. Bad news of course is the modules can be pricey. Should say right on it the part number, order it from mcminone.com or whoever, solder it in, use new conductive grease (many times I think these modules fail because the grease gets old, the module overheats and toasts) and you should be fixya'd
Jan 12, 2008 | Marantz SR-5200 Receiver
313 people viewed this question
 Grubhead
Grubhead
