Question about Grilling
Why southbend temp various over the grill ? set on same settings but will be hotter in spots
  • 3,497 Answers
This uneven heating is something "grillers" have dealt with since we started cooking...the heat is higher directly over the source and gets progressively cooler as you move away.. This is more pronounced with gas or electric grill/cookers..because the heat source is in a fixed position...WITH charcoal, you can spread the coals out (if you use enough).. and get even heat over a larger area.... I have a NEW 4 burner(w/hot pad) Charbroil gas grill and a old Charbroil charcoal grill...I HAVE NEVER used the gas grill...and I grill 1-2 times a week!! ..(it was a gift/two years ago.... wanna buy it?)
Posted on Jul 06, 2017
  • 24 Answers
SOURCE: the temp/flame on my weber grill won't get hotter
Check the excess flow safety device, which is part if the barbeque to cylinder connection, may have activated. To reset the excess flow safety device turn all burner control knobs and the cylinder valve off.
Disconnect the regulator from the cylinder. Turn burner control knobs to high. Wait at least 1 minute . Turn burner control knobs OFF. Reconnect the regulator to the cylinder. turn cylinder valve slowly.
Posted on May 24, 2009
  • 3 Answers
SOURCE: the oven temp is 100 degrees hotter than the set
On most oven temperture controls, if you pull the knob off there is an adjustment screw down in the shaft turn counterclock wise?? to lower setting. Good luck
Posted on Nov 14, 2009
  • 6 Answers
SOURCE: Dryer temp control is not
CLEAN THE FILTER,PROBABLY ON TOP,GOOD LUCK
JOE
Posted on May 20, 2011
  • 5245 Answers
SOURCE: You have to keep turning the temperature up yo maintain water temp
Crossover caused by worn single-handle faucet cartridge.
Bad gas control valve thermostat.
Sediment in tank.
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Posted on Oct 24, 2012
dmftrucker
  • 1922 Answers
SOURCE: oven set at 350 goes way higher
the oven sensor rod on the rear wall of the oven cavity is defective,remove screws holding it sometimes you can plug a new replacement sensor in from the front,if you can't then remove rear panel on the back of the oven to access the connector to replace it
Posted on Nov 28, 2012
How to use the grill
grills are used with the front open
if it has a separate door open it, switch on the grill and select which tray level by the grooves in the side of the opening
closer up the hotter the cooking , the lower the more temperate setting
just turn on grill switch , open door and go for it.
Apr 12, 2015 | Ovens
I need to calibrate my southbend model #x436d standard gas oven
If you pull the knob off there is a very little screw in there that you can turn with a small screwdriver. I believe left is increase and right is decrease, but I could be wrong. Very little turns do a lot. You can tell if you are going the right way if the burners get bigger or not. This takes a while so do a 1/4 turn and let it sit for a while, take temp and adjust again if needed.
Jun 16, 2012 | Southbend Kitchen Ranges
How can I adjust the shower knob to produce hotter water then it does now. It used to be hotter. Taking the knob off reveals a white piece of plastic with a colder to hotter temp. gauge. How can I adjust...
Should be able to adjust clockwise or counter clockwise to adjust the temp. You said that the temp used to be hotter. Check the temp setting on your water heater. Did you replace your old water heater? Hope this helps.
Mar 07, 2010 | Home
Rear Burner is hotter than the front burner on my Weber Grill
Since the grill is 15 years old, it is probably time to rebuild it. Replace both burners and anything else that is not working properly
Dec 20, 2009 | Weber Genesis Silver B Grill
Do we need an exhaust flue for a southbend half size gas oven?
Depending on your local code, you will need an exhaust hood due to the byproducts of the gas burning. Some locals allow for electric ovens to go without hood. Gas units generally require a hood system with proper fire suppression equipment. You may want to check with your local fire and building inspectors.
Mar 22, 2009 | Southbend S560DD (Gas) Oven
The temp/flame on my weber grill won't get hotter
Mar 06, 2009 | Weber Spirit? E-310 Propane Grill
Temp
Not sure on your climate.
But a Holland grill cooks cooler in the coller months and Hotter in the hotter months. This type of grill doesn't reach a very high setting approx: 400 degrees. It might reach higher temperatures in the hotter weather 450-475 degrees.
Also, it has to shut down the same way every time you use your grill.
Here is a Tip to fix a grill that not getting hot:
1. Turn the gas valve knob off. then close LP tank valve knob.
2. Unscrew the plastic hose coupling knob from the LP tank. You may hear a slight "hissing" sound as pressure is released this is normal.
3.Wait a minute then screw the coupling knob back on to LP Tank.
4.With lid open.slowly open LP tank valve.
5.Relight the grill the proper way by turning gas valve knob to ON position while turning the igniter knob at the same time.
6.After you are sure the grill is lit preheat the grill for 30 minutes.
This was called purging the line or releasing the air out of the line.
Another thing your orifice could be clogged with spiders or dirt. If it is LP gas check to make sure your hose is not kinked.
Hollands are known for the slow cooking process and a Healthy way of cooking!
Apr 27, 2008 | Grilling
Grilling Logo
307 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
