Just had to replace the water pump to my mastercool, now it smells like fish! I thought that bigger was better so i went from 7000gpm to 7500gpm. Could this be the problem since the pads are becoming saturated and not having a chance to evaporate? It has been more humid lately and maybe the is a coincedence? Maybe I should go to an even smaller unit (500gpm). I have the smaller mastercool. It makes sense that they need to get wet AND evaporate for proper cooling, duh! Just wanted to double check with someone who may know for sure. Thanks, Louis
Louis, The cooling does not come from the volume of water running over the pads. It cools by cooling the air passing through the wet pads. So, Yours is an impeccably logical argument that leads to a false conclusion. Bigger is not better in this caThe fishy smell is from the matting (pads) when kept saturated, Molds and algae will form if there is too much water also.. Best you get the original size pump Good luck and stay cool - Ned
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Mastercool 67680 Evaporative
Mastercool 67680 Evaporative Cooler Air Conditioner
Wiring diagram for Braemar Evap Cooler. Have had control box serviced and now refitting.Need to...
(More)
Wiring diagram for Braemar Evap Cooler. Have had control box serviced and now refitting.Need to check correct orientation of wires to fan motor
im looking for a cover for the front pad of my maseter cool down draft unit i cant find a website...
(More)
im looking for a cover for the front pad of my maseter cool down draft unit i cant find a website that carries one
Blower motor has no power (240) to it, on either hi or low switch setting. Both phases are present...
(More)
Blower motor has no power (240) to it, on either hi or low switch setting. Both phases are present on the control bd. Water pump works OK. I can hear relay for lo-hi clicking when sw. is moved on the termostat. Need schematic for control bd
I have the same problem as rmrjr9901 . My 8 year old mastercool control/junction box had 4 wires. My...
(More)
I have the same problem as rmrjr9901 . My 8 year old mastercool control/junction box had 4 wires. My Mastercool Thermostat is labeled as follows Blue -OV, Red- +5.6v, Yellow-Control 1, Green Control 2 . The new junction box I have it is also a Mastercool but it uses 5 wires. Y(fan). W(pump), R(24v), G(com), B(drain). The old unit has no white. What do I need to do?
