Question about Kenmore 60721 Refrigerator
I have a 69461 series. water run from under the refrigerator. What do I need to look at? Thank You
Water does not enter into the ice maker
Hey Lou, thank you for your inquiry!
Based off the information you have provided water is not entering into the icemaker of your Frigidaire refrigerator. There could be a block within your water line you can clear any blocks by manually defrosting your water line. In order to do that you would need to disconnect power from the refrigerator for at least one hour. If the icemaker does not fill you could be experiencing an issue within your water valve or water line. Since it could be anyone of the se underlying issues I would suggest having a professional technician out. This will prevent any unnecessary part purchases. I hope this information is helpful to you. -Matt
Feb 29, 2016 | Frigidaire Refrigerators
Why is my freezer leaking water into the refrigerator ?
Hey Trudy Guldin, thank you for your post!
Based off the information you have provided its sounds like there could be a potential issue within your solenoid, water valve, or water filter of your Frigidaire refrigerator. When was the last time you changed your filter? I would remove and make sure there is no damage visible on your filter. If so, you would need to replace the filter. If it is any one of the other underlying issues I would recommend having a technician come out to the home and properly repair your appliance. -Matt
Aug 27, 2014 | Frigidaire Refrigerators
Frigidaire professional series refrigerator leaking water under door
Hello - Typically when water is coming out from under the refrigerator there could possibly be a loose connection from the house water supply line to the water valve or a cracked drain pan (located underneath the refrigerator). Try confirming that the valve is tightened. If the connection is still leaking, turn off the water supply valve and take the connection apart. You can try using Teflon tape when retightening the connection to ensure a good seal. There could also be a loose water connection to the door. This connection is located on the bottom left of the freezer door.
Sep 25, 2012 | Frigidaire Professional Series PHS68EJSB...
Water buildup inside my gold series refrigerator
on the back of the unit at the bottom, there should be a tube that you can pull off and it is probably clogged. You might need to get a towel or something to catch the water that is in the drain line. Also, be careful to get the tube back into the drain pan ( under the refrigerator) so that it doesn't drain onto the floor. This tube is attached to the line that comes from the freezer. water is shed during defrost. I had to do this about a month ago on my refrigerator at home.
Hope that helps.
Apr 19, 2011 | Whirlpool Gold Series GB2SHTXTS (219 cu...
I have a GE profile series fridge. Its not old, as it was in the house we just bought. It has a bottom freezer. The problem is that almost every morning there are small puddles of water under the...
It is probably water from the auto defrost feature. It is suppose to go into a pan under the machine and evaporate into the air ... yours may be over flowing due to high humidity condition in your area.
Sep 13, 2010 | GE Refrigerators
Older (serial # erased) GE freezer top frost free Water pools in bottom of frig. cannot find drain.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Drain is under the coils and may be froze shut...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | GE J Series 18.2 cu. ft. Top Freezer...
My freezer is getting a lot of ice buildup at the bottom and I am now getting water buildup under the storage bins in the refridgerator as well. What is the problem and can I fix it myself? Please advise....
heatman101
Aug 25, 2010 | Whirlpool EV171NYMQ
Water is pooling under vegetable bin at bottom of refrigeraqtor. Seems water is coming from insude refrigerator under freezer shoot. Placer plastic cup under it and it has collected water that froze....
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 19, 2010 | Whirlpool Refrigerators
The freezer auto defrost puts a lot of water into the bottom of the freezer which in turn just freezes again. Then the next time it dumps more water there and it runs out the door.
There should be a drain hole or line allowing it to drain into a drip pan under the unit. You need to unplug the unit, melt or chip the ice out, make sure the drain is not plugged ( it could be plugged under the freezer.
Sep 23, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water problem
Sounds like the  drain for the defrost system is plugged....
Oct 10, 2007 | GE J Series 20.6 cu. ft. Top Freezer...
Kenmore 60721 Refrigerator Logo
130 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
