Question about Canon PowerShot A520 Digital Camera
Two different Canon A520 problems.
I have 2 Canon A520 cameras. One was dropped on the open lens when nearly new and the lens is stuck out. It displays the message E18 on the display screen when I power it up. On the second camera, when taking a picture, the subject is only about half as bright as it used to be on the display screen and the resultant pictures are dark as well. There is color.
  • beckypt Nov 28, 2007
    Yep, same problem with the lens stuck and e18 error screen after the camera was dropped on an open lens. Looking for suggestions!
  • 1,894 Answers
Hey guys. there is no solution that you can do it for yourself. the best solution i can give for you is take it to service centre. here in india we get charged nearly 1800rupees for servicing the lens portions.
Posted on Dec 23, 2007
  • dewan nafees ahmed May 16, 2008
    i gave a right solution for him which he could try..
    with our replying anything for my solution how can he rate that inappropriate?
    i gave him a solution what i had.
    please remove this rating
Playback switch does not operate
PDF]Camera User Guide
Switching between Shooting and Playback.....32 .... Please note that Canon digital cameras are intended for personal use and should never be used .... Do not operatethe flash with dirt, dust or other items stuck to its lens. ..... PowerShot A520:.
Repair tips for digital cameras that won't power on. 'Do It ...
Nov 30, 2007 - It was a fix for a Canon A520, but am not sure if it would work for ..... I have a Canon Powershot A540 which will not turn on and lens is stuck out extended.... (even when they are new) in camera mode and not playback mode.
Digital Cameras - Canon PowerShot A520 Digital Camera ...
Dec 02, 2015 | Canon PowerShot A520 Digital Camera
My daughter dropped our A520. The power comes on for a second and then shuts down. The lens is stuck open. Is this worth fixing?
I had this problem once. The lens was stuck open and the power would not go on. I took out the storage card and the lens retracted.
Aug 23, 2010 | Canon PowerShot A520 Digital Camera
Lens is stuck about 97% open. The camera will not
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Nov 04, 2009 | Canon PowerShot A520 Digital Camera
Camera was dropped. When turned on, LCD is blank
sounds like the lens is stuck you should check if its jamed good luck!
Sep 08, 2009 | Canon PowerShot A520 Digital Camera
Describe hi, i have a canon powershot a520 that was left in someone's purse when she gave it back to me the lens is now sticking half way out and when i push the power button it blinks on for a split...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jul 22, 2009 | Canon PowerShot A520 Digital Camera
Lens cover won't open when Canon Powershot A520 Camera turned on
I have two Canon Power shots---the A610, and the A630. The lens cover is starting to hang on my 630 when the lens retracts.
If the lens is extended, take your fingertip and try to move the cover a bit to see if it springs open. If not, then the mechanism within the lens needs to be replaced.
Canon makes a great camera, and I would tell you to try to have it fixed if it costs less than 75 dollars. At 75-100 dollars it's a toss-up. More than a 100 dollars---it's your call.
Mar 26, 2009 | Canon PowerShot A520 Digital Camera
Canon Power Shot A520
Dear JudyCrossrds:
Due to impact damage your camera has suffered an obvious lens error and possible even sensor damage. It will have to be sent into the Facttory Service Center for a repair.
Call Canon Tech Support at 1-800-828-8080 to set the service up. They are open from 8 AM til Midnight, EST; M-F.
Hope this helps.
Mar 21, 2008 | Canon PowerShot A520 Digital Camera
My canon A520 lens cover don't open
lens opens about 25% . Will not close back.
Mar 15, 2008 | Canon PowerShot A520 Digital Camera
Canon PowerShot A520 Digital Camera Logo
147 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
