Question about Microsoft Windows Vista Home Basic Edition for PC
6to4 adapter won't start, internet down
HI, wireless internet down, ideas?
Thanks
  • 225 Answers
Reset the modem and reset the router if you have one, have you tried those?
Posted on Jul 25, 2009
Can not pair to my computer.
If you see this status associated with a Microsoft 6to4 Adapter on a computer running Windows Vista in a home environment, you may be able to uninstall the 6to4 adapter to resolve the problem. To uninstall the 6to4 adapter, right-click it and click Uninstall. After you uninstall the 6to4 adapter (or if the problem is not associated with the Microsoft 6to4 adapter), it may also be helpful to run an automated troubleshooting service from the Microsoft Support Web site (http://go.microsoft.com/fwlink/?LinkId=192795).
If your computer is part of a business network, consult your network administrator for the most appropriate action. There may be company tested drivers for your computer or there may be other considerations before you disable any IPv6 components.
Jan 18, 2016 | Computers & Internet
I need to reinstall microsoft 6to4 adapters
microsoft 6to4 adapters? Not sure I know what that is?
Dec 01, 2012 | Computers & Internet
6 to 4 adapter no working and 1 Sat adapter #2 adapter not on, so I cant connect to internet, how can I fix this
I would like to bring to your notice one of the issue that came across with a Vista based PC of a EU who reported in his mail that in "Device" manager their are 6 to 4 adaptor is listing by name itself and for this he is unable to install any drivers as it is showing that the drivers are not installed for it. Even though EU is able to browse the internet.
Normally the above issue is related to TCP/IP transmission protocol that uses by Vista. As Vista by default support IPv6 TCP/IP protocol for data transmission over the network. 6to4 adapter is a component used for transmitting IPv6 packets trough IPv4 network correctly. If the drivers for this component is not properly installed or corrupted there will be a code 31 or code 10 error appearing beside this component. You may update the driver for your network adapter or chipset, and then try to uninstall and reinstall the this component as mentioned below. I am enclosing a snapshot of the issue along with the mail so that you can also have a clear idea of the issue.
=======Uninstalling 6to4 Adaptor==========
1. Click on Windows icon, and enter device manager into the Start Search field.
2. Right Click on all 6to4 adaptor and select uninstall from the droplist.
=====Reinstalling 6to4 Adaptor===========
2. From the device manager window select "Action".
3. Select "Add Legacy Hardware".
4. Click on Next.
5. Select "Install the hardware that I manually select from a list".
6. Select Network adapters from the window.
7. Select "Microsoft" from left window.
8. From right window select "Microsoft 6to4 Adapter"
9. Click on next and finish the wizard.
After performing the above steps issue shoule get resolve. If the issue persist then, I request you to disable this device in device manager. By disabling this it will not effect your internet browsing or your wireless conectivity, as Microsoft also confirm this in their database. In order to disable this device perform the below said steps.
1. Click on Windows icon.
2. Select Accessories.
3. Right click on "Command" prompt.
4. Select "Run as administrator".
Once the command window open, type the below said command.
netsh in 6to4 set state disable
After typing the above command press enter key on the keyboard.
After performing the above steps restart the PC.
Apr 05, 2010 | E-Machines eMachines Desktop PC
6t04 code 31
To solve this problem with 6To4 adapter device with code 31, make sure you do the following:
1). Make sure you have all the updates installed for vista, such as, Important and Recommend updates.
2). [Right Click] my computer icon, and select (properties).
3). Select (Device Manager).
4). [Right Click] on the 6To4 icon, and select (Update Driver Software).
5). Click [Browse my computer for software drivers].
6). Click [Let me pick from a list of device drivers on my computer].
You should see the Microsoft 6To4 adapter listed?
If not you must uncheck the [] box show compatible hardware.
7). Then scroll down the list of Manufacture until you find (Microsoft), NOT Microsoft Corporation!
8). Click on (Microsoft) as the Manufacture and scroll down about two clicks, you should see 6To4 adapter.
9). [Left Click] on Microsoft 6To4 adapter and (Click Next), it should load the drivers as normally.
Dec 04, 2009 | Dell Inspiron 1545 Notebook
6T04 Adapter failure
That 6to4 adapter has been a problem for as long as I have been aware of it but I only have that issue when I use my print server. I don't believe the 6to4 is your actual wireless. Are you using a wireless print server?
Sep 04, 2009 | Packard Bell 1580509280 Network Adapter
6to4 adapter not working...
Check the device status under the Device Manager. if the status of the device was just "drivers were not installed..." you may simply click on update driver button on the same window. If the error is code 10 or device could not start, the problem has something to do with the hardware. call the manufacturer of your laptop and check the warranty if it is still covered.
Jul 16, 2009 | Enterasys Network adapter
Abit wireless adapter unable to locate wireless network
well!! I have an answer for you.your comp is loosing the IP address.connect your computer through cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 26, 2009 | Abit (WLP-01) Wireless Adapter
The 6TO4 and ISATAP Adapters have stopped.
You don't mention what laptop you have, but if you browse to the laptop manufacturers website, eg. www.hp.com, they always have driver downloads for their products.
Download the drivers for your laptop and reinstall these to get your network card working.
Feel free to ask me for any further assistance regarding this matter.
Best wishes,
Graemevm
May 21, 2009 | Computers & Internet
Network adapter
your adapter driver is not installed plz install it
Aug 13, 2008 | Computers & Internet
Connection problems
If Internet sharing is set up correctly one pc will be the one that connects directly to internet, the other will connect through a gateway or other device connected to your network. Check they have'nt both got the same IP address. Is this related to last problem, did you get the wireless card working wirelessly online?
Nov 20, 2006 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Microsoft Windows Vista Home Basic Edition for PC Logo
223 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
