Question about Whirlpool GGW9250PL Gas Dryer
THE DRYER IS NOT GETTING HOT
I HAVE A LGR5620KQ1 GAS DRYER. THE DRYER IS NOT GETTING HOT EVEN AFTER REPLACING THE COILS. I THOUGHT IT WOULD FIX THE PROBLEM. WHAT NOW?
    Brigadier General:
  • 8,619 Answers
Hi
Please check the following things that could stop a gas dryer from heating:- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 25, 2009
This is an older wirlpool gas dryer, as the egnighter is getting hot before the gas kicks on it is making a loud buzzing noise at the gas unit.
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video on replacing the dryer coils. If you need further help try this link for troubleshooting a gas dryer
Nov 19, 2010 | Dryers
My dryer is not getting hot consistantly. It will warm up then cool off - at times getting warm again. It seems to be doing this on auto-dry as well as timed dry. I changed the cycling thermostat, it...
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video on replacing the dryer coils. If you need further help try this link for troubleshooting a gas dryer for whirlpool and Kenmore styles or try this troubleshooting a ge style gas dryer
Oct 03, 2010 | Maytag MDG3706A Gas Dryer
Model #LGR5620KQ1 thermostat and thermal fuse are good and dryer still does not ge hot.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 15, 2010 | Whirlpool Dryers
Dryer is not getting hot . The vent is clean and only warm. it is a gas whirlpool.Thanks
On cotton setting you ought to be getting 155f out the vent. maybe 160f max. You have warm air so everything must be working. That tells me the coils need replacing. they get weak and they get hot. Feel the coils after a few times and the bad coil will be very hot to the touch. the coils are sold in pairs for $20 I have a great link that shows what to do HERE
and I have another page HERE
Jan 19, 2010 | Whirlpool Dryers
I have almost the same problem... but I have plenty of heat.
If it's takeing that long and your element (coil) is that hot your exhaust is probablly blocked it will need to be cleaned out.
Oct 05, 2009 | GE DLSR483EE Electric Dryer
My dryer doesn't stay lit
This could be a operating thermostat/thermister if it comes back on again and continues that cycle. If it stays off a long time then it could be the coils on the gas valve. Eric
Sep 14, 2009 | Whirlpool Dryers
You have a thermal cut-off . located on the burner box . The box you installed the element . That is probably the part that it bad .
Jul 25, 2009 | Dryers
I have a Whirlpool gold Ultimate Care II gas dryer and 2/3 times the ignitor glows and lights the gas, 1/3 times it won't. When the gas does light, it doesn't seem like it's getting hot enough to do...
I would suggest the coils on the gas valve . Also check the vent to make sure good air flow is getting out of the dryer . Try disconnecting the vent hose and drying a load to determine if maybe the vent is the problem .
Jul 14, 2009 | Whirlpool LGB6300 Gas Dryer
Dryer wont stay hot. it gets cold after first load
If dryer lights for a few minutes and will not stay lit, I believe the solenoid coils will need to be replaced. Click on link below, enter your model number lgr5620kq1 in model search feature and go to the dryer page it shows a breakdown view of your dryer. Also go to common solutions and look for gas dryer problems. I will also be here to help you, Sea Breeze
http://servicepartstec.blogspot.com/
Mar 21, 2009 | Whirlpool Dryers
Open Questions:
Strange issue with my gas dryer and the control panel I am having a strange issue with my dryer. I have a Whirlpool gas dryer, Model: GGW9250PW0; and am having issues with the Electronic Control (mfg part 8558753). Yesterday, I went to go use the dryer and I press the "Control On" button like normal, but nothing happened. I did not get any lights or anything, yet when I open the door, the inside light comes on. I have a similar model washer plugged into the same electric outlet and everything there works fine. After researching the issue out a bit, I took off the toe panel and took off the duct-lint (mfg part W10128606) so that I could reach the wires connected to the dryer thermister and dryer thermal fuse better. I then took the wires off both of those as well as disconnected the sensor wiring harness (mfg part 3406653) and used a vacuum to clean out any lint as well as compressed air to clean off those connectors. I re-hooked all the wires back up and plugged the dryer in. I pressed the "Control On" button and all the proper lights lit up. I then pressed the "Cancel" button to turn it off, unplugged the dryer, and put the duct-lint back on. I plugged the dryer back in and tried the "Control On" and "Cancel" again, and it still worked. I then put the toe panel back on, pushed "Control On", then turned on the dryer using the "Hold to Start" button and everything worked like it used to. Here is the strange issue I am having. I ran a load in the washer and when done, I put in the dryer and tried the "Control On" button. Everything came up, but when I pressed the "Hold to Start", nothing happened. I then tried to press the "Cancel" button, and nothing happened. I could turn the knob and the different lights lit up, but none of the buttons seemed to be working. After holding the "Cancel" button for a few seconds it turned off the panel lights. I then pushed the "Control On" button again and had to press it a few times before the panel lights came on. After a little bit of playing with the buttons and knob, I was able to start the dryer. I stopped the dryer (didn't want to run it the whole time in case something is wrong) and tried to start it again. I can get the panel lights to come on, but it seems like the buttons are sticking and not fully working like they should. I don't want to have to buy an expensive part unless I absolutely need to and wanted to see if anyone can think of anything else that might be going on or that I could try before paying almost $200 for a new Electronic Control, especially if I will still have the same problem after replacing this part like some other people have reported. Thanks!
Jun 14, 2013 | Whirlpool GGW9250PL Gas Dryer
See all Whirlpool GGW9250PL Gas Dryer Questions
Whirlpool GGW9250PL Gas Dryer Logo
254 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
