Question about Toshiba 53H71 53 in. Rear Projection Television
The words on the screen is doubled or trippled.
My name is Leon Heyward. The problem that I have with my 53" toshiba projection screen is, when I'm looking at T.V on the bottom of the screen the t.v shows the cannel that i'm watching, espn, animal planet etc. I'll see espn in 3 colors, pink, green and blue, "Moreover" the screen picture is a tad blurry. The T.V is in great shape concidering 10 years. Please give me some advice on correcting this condition. Have a wonderful Thanksgiving.
  • blaaa Jan 09, 2008
    Hi, and yeah, I have same TV and similar problem. In my case however the green is out, alot.. and yeah ,doubled words etc. but in green???? Looks like someone hit the tv and green is out... but no? Just turned it on one day and , hello ! cannot adjust green converge on this set
  • 87 Answers
Go to the picture control menu and turn the color to minumum so that you are watching a black & white picture. Do this to determine if the color offset affects the overall screen or just the lower corner. If the center is off, go to the convergence adjustment menu and align the red and blue onto the green as described in the owners manual. Some models also allow you to align the outer edges as well. If the bottom is still bad you may have a problem in the convergence circuit. If the outlines are not seriously bowed or distorted a minor convergence toutchup by a qualified technician should correct the problem, otherwise parts are involved and the repair is considered major.
Posted on Nov 27, 2007
53 inch projection tv mirror broken can i have a regular mirror cut to size and work
A regular mirror will not work as the mirror has special construction; What you can do and our shop has done this is find a used one bigger and have it cut down to size.
If it is Toshiba you can also call ANDREWS ELECTRONICS in LA (they have 800 number) and see if original mirror is available from Toshiba. There are also some sites on the internet and if you google the model number with the word mirror you will find them
Be extra careful if mirror was broken as pieces will be very sharp.
Entire front screen unit will have to be removed to get at it and or replace it.
Let me know if you have questions.
Oct 11, 2011 | Toshiba 53HX71 53" Rear Projection...
My toshiba 57in rear projection the color is off and when words are on the screen they look doubled?
Sounds like you need to check the convergence. You can in the MENU under PICTURE go down to the CONVERGENCE to make the adjustment, set the RED and BLUE
May 17, 2010 | Toshiba 57H82 57" Rear Projection...
Sony color rear video projection, Sn 9720391, model KP65WS510. Looks like 3D without glasses. Red double words and pict are shadowy
Common problems with rear screen projections. Either you need to refocus the alignment, or you need to have the Convergence IC's replaced. In your owners manual, it should tell you how to refocus the alignment.
Feb 15, 2010 | Toshiba 53H71 53 in. Rear Projection...
My toshiba rear projection 55 inch tv is showing a double reflection in blue how do i fix it
Replacing the Convergence IC'S should fix it. They should be STK392-110's. I would replace both of them as a pair.
I hope this helps,
Nov 14, 2009 | Toshiba 53H71 53 in. Rear Projection...
Double image and colour
There are two common problems with these sets.
Problem #1) Convergence
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
Oct 07, 2009 | Sony KP-53HS30 53" Rear Projection...
Panasonic Rear Projection Screen TV
you need new convergence chips, there are 2, part number stk 392-110, also you must check for burnt resistors, if you don't have very good soldering skills at least, you will need a tv repairman.
Sep 15, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Double picture & color problem
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya
Jan 22, 2009 | Sony KP-53XBR45 53" Rear Projection...
see if the mirror in side is broke or cracked
Rainbow on the screen
Do you have any larger speakers close to you tv. Or any magnets been neer it. If you unplug it for a while the tv should have remove the rainbow
Aug 28, 2008 | Panasonic PT-53TW53 53" Rear Projection...
My toshiba tn61x81 projection tv
have you tried the convergence option in the menu? i believe it is under "picture". this allows for nine different sections of the screen to be adjusted when projection images get out of whack.
Oct 20, 2007 | Toshiba TN61X81 61" Rear Projection...
Toshiba 53H71 53 in. Rear Projection Television Logo
145 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
