Question about Dryers
THE DRYER IS NOT GETTING HOT EVEN AFTER REPLACING THE COILS. I THOUGHT IT WOULD FIX THE PROBLEM. WHAT NOW?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please check the following things that could stop a electric dryer from heating:- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 25, 2009
  • Dryers Master
  • 1,606 Answers
You have a thermal cut-off . located on the burner box . The box you installed the element . That is probably the part that it bad .
Dryer works but sometimes it doesn't get hot even though the burner is lit
Them coils is probably getting weak and when they get old they will fade after working once. Then again way later. Easy fix here is my video explanation:
Sep 28, 2013 | Whirlpool Dryers
This is an older wirlpool gas dryer, as the egnighter is getting hot before the gas kicks on it is making a loud buzzing noise at the gas unit.
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video on replacing the dryer coils. If you need further help try this link for troubleshooting a gas dryer
Nov 19, 2010 | Dryers
I have a Maytag Gas Dryer Model# MDG508DAWW. It comes on and tumbles but won't heat up. I bumped the back of it with my hand and it came on and got hot then a few minutes later it started getting cold...
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help Replacing the dryer coils
Oct 06, 2010 | Dryers
My dryer is not getting hot consistantly. It will warm up then cool off - at times getting warm again. It seems to be doing this on auto-dry as well as timed dry. I changed the cycling thermostat, it...
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video on replacing the dryer coils. If you need further help try this link for troubleshooting a gas dryer for whirlpool and Kenmore styles or try this troubleshooting a ge style gas dryer
Oct 03, 2010 | Maytag MDG3706A Gas Dryer
Dryer is not getting hot . The vent is clean and only warm. it is a gas whirlpool.Thanks
On cotton setting you ought to be getting 155f out the vent. maybe 160f max. You have warm air so everything must be working. That tells me the coils need replacing. they get weak and they get hot. Feel the coils after a few times and the bad coil will be very hot to the touch. the coils are sold in pairs for $20 I have a great link that shows what to do HERE
and I have another page HERE
Jan 19, 2010 | Whirlpool Dryers
I have almost the same problem... but I have plenty of heat.
If it's takeing that long and your element (coil) is that hot your exhaust is probablly blocked it will need to be cleaned out.
Oct 05, 2009 | GE DLSR483EE Electric Dryer
Hi
Please check the following things that could stop a gas dryer from heating:- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Thanks
Rylee
Jul 25, 2009 | Whirlpool GGW9250PL Gas Dryer
I have a Whirlpool gold Ultimate Care II gas dryer and 2/3 times the ignitor glows and lights the gas, 1/3 times it won't. When the gas does light, it doesn't seem like it's getting hot enough to do...
I would suggest the coils on the gas valve . Also check the vent to make sure good air flow is getting out of the dryer . Try disconnecting the vent hose and drying a load to determine if maybe the vent is the problem .
Jul 14, 2009 | Whirlpool LGB6300 Gas Dryer
Dryer does not get hot.
Check the following to address this issue-- 1. Gas valve coils Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective. Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common. 2. Thermal fuse Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting. Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse. 3. Igniter Igniter may burn out or break. Replace the igniter if found defective. Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color). 4. Flame sensor (or radiant heat sensor) Replace the sensor (located near the igniter) if found defective.
Jun 03, 2009 | GE DVLR223 Dryers
Dryers Logo
67 people viewed this question
Top Dryers Experts
