I have taken this thing apart, ran things through the hose etc. There are no other places to unclog! Everything works correctly, but no suction. Can't figure out what is going on!
Is the beater bar actually turning when the power is turned on? Sometimes the belt is fine, but something is jammed and keeping the beater bar from turning. What about the section behind the beater bar, but before the hose upright. I've found large pieces of paper jammed in here and then hair gets caught, ultimately blocking the whole system. Usually you have to turn it over, remove some screws and disconnect the belt and beater bar to get underneath. Just reassemble it in the reverse order to how you took it apart. Double check the hoses and run a "unwound" metal coat hanger through to unclog anything. Does the vacuum " suck" with the hose or tube up to it disconnected? If not you may have a motor that somehow got junk pulled into it. You can open this up as well and clean this out. Of course unplug it all before doing anything.
Well, you have to deal with it, you have to play with this electrical things if you want to fix this problems.
The good news is, the sources of the problems is the switch already
broken.The first things before you do anything is, find this switch on
the market first to changes the old ones.Then, remove the power cord
from the outlet of course.
After have it, then you must open the old switch, and remove it from
the unit by cutting the cables using cutter/ pliers or anything.But
remember, you must remember the locations of each cable that been cut,
you can use Camera Cellphone to make sure of it if you like.
Then put the cables back together with the new switch, after all done, clean all the mess and try operate it.
very easy. you have clog. take the brush off look where the hole is thats where the clog is. it might be in there you might have to take the housing off of the motor
Your problem sounds to be an obstruction in the foot (lower body) of the windrummel. Most all windtunnel's have a second cavity for suction to go over the top of the roller. When you remove the bottom plate, next remobe the belt and roller, under the roller will be a removable cavity, take it out. remove the dirt and clean out any debris. also check the suction path connecting hose. if your belt has not been changed in the last 12 months, I would recommend changing that as well.
You probably have a broken belt, or the belt came off. The Self PropelWindtunnel has an issue with the pulley that tightens the V-belt in place getting stuck and needs to be taken apart and released, but most likely its just the belt. They should be replaced every 6 months or so, and the part number is usually on the serial tag of the machine.
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=40600&thid=562967 Hoover Wind tunnel supreme, loss of suction posted by bazballfan on May 01, 2008 Hello, I purchased two of these models in late 2007 and after changing the bags on each of them I have little to no suction with the vacuum. The hose is fine and I have taken them apart and there is no obstruction in the hose or in the base. These worked so well and now they don't do anything. The bag isn't filling much and the simplest things can’t be vacuumed up Please help me to fix this Hello, I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover U5450-900 Windtunnel Supreme Vacuum Sorry you are having a problem, it sounds lie you have done almost everything, but just in review it could be some of these problems: Belt change – every 4 to 6 months Are the brushes in good shape Where does your suction drop off Is the bottom plate securely on the bottom Are there any gaskets that are broken or leaking Is the bag installed securely Did you check for any clogs or obstructions Is the filter clean Feel free to contact your local vac dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. http://www.hoover.comTelephone Contact our Customer Service Department at 1.330.499.9499 Monday through Friday 8 a.m. - 7 p.m. EST Thanks,Don – The Vac Man Go Ahead.Use Us.
Well firstly, whats the model number and do you have the user manual to hand?
If the main hose has been unblocked, then it could be the main dirt channel which is blocked just after the moving roller brush panel. A long pipe cleaner or wire brush can remove this blockage easily rather than taking everything apart.
If you have low suction at the end of the hose, then you either have a clog in the hose or a clogged filter. Take the hose off and drop something in it to see if it comes out the other end. If you have suction at the end of the hose, then the dirt inlet by the brush roll is clogged.
