Connected wii consule to bush ws6671 tv
Connected consule to tav but cannot get a av channel that will work with it-nothing comes up on screen
  • 372 Answers
If you are connecting via scart lead use scart 1 on the rear of tv set & switch off any other devices connected to tv set.
If you are connecting via phono sockets red, white, yellow,
You will need to select the input on the remote see if remote has AV button you will need to depress this buyyon several times as it will go AV1, AV2, AV3, etc.
Posted on Nov 21, 2007
Everything is plugged in, the disc is in and the wii is on, on the other television, it used to come on autmatically but on my hitachi television, it doesn't come on automatically, i have pressed many...
Mine too, we need to find the AV channel. All our friends who have a Wii have had no problems, just plug it in and switch your remote from TV to AV and it's there. My Hitachi remote does not have a TV/AV button, and the other options, S.Video, Composite Video, Component etc is taken up with other things eg Foxtel, DVD player and DTT tv channels .... HELP!!!!
Jan 02, 2011 | Video Game Consoles & Games
Wii help
Hello :
1:Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console.
Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
Yellow = Video Input
White = Audio Input Left (or Mono)
Red = Audio Input Right
3:Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
I hope this will help .
Mar 23, 2010 | Nintendo Wii Console
Bush LCD tv wont allow Wii to be tuned thru AV
Hi, the av lead with the three connectors at the end make sure you have them connected correctly -
Yellow - Video
White - Left Audio
Red - Right Audio
It's a simple mistake to make , but check it.
Let me know - Anthony
Feb 10, 2010 | Televison & Video
Have an alba tv with bush dv3 but cannot get signal
not able to play wii on av channel - just comes with blue screen and count down timer? Have connected to the require colour codes on tv
Jan 01, 2010 | Bush 5693D 24" TV
Power light is green but nothing on the screen
Check the AV cables may be not connected right or the AV cable is broken.
Mar 27, 2009 | Nintendo Wii Console
Nintendo wii wont work with older model of Sanyo TV
how are you connecting the wii to the tv...through the rca jacks?  If so, you can not get to the input channels by the channel button.  On the remote there will be a button called either AV, Input, AV Video, Video, A/V, Input or something similar.  Hit this button until your tv goes to the appropriate av channel.
Mar 07, 2009 | Nintendo Wii Console
No picture on Bush WS6667 TV
hello make sure the scart lead is connected tight
Jan 20, 2009 | Bush WS6671 28" TV
Setting up Wii with TV
I'm 60 plus years old. Do I connect the AV cables to my TV or to my SAT receiver.
Jun 18, 2008 | Nintendo Wii Console
Finding the correct channel on the TV for Wii
ok. push tv video button on your tv,
first turn on your wii, be sure that the av cable are connected to ur televison properly. Then turn on your tv start from channel 1 then scroll down the channel button until you locate the blue screen or logo of wii.
Jan 24, 2008 | Video Game Consoles & Games
Tv has lost two outer sides of vision despite changing picture mode
That's either a high voltage problem, or a deflection problem. WARNING, CRT Based Televisions have potently life threatening voltages inside them, and should be serviced by trained personnel only. With that out of the way. According to It's a capacitor failure Fault - Width and E/W correction fault Remedy - Replace R626 and C630 I don't have a manual so I can't tell you for sure what the resistor and capacitor do, or where they are located.
Dec 30, 2006 | Bush WS6671 28" TV
Televison & Video Logo
389 people viewed this question
Top Televison & Video Experts
