Question about Acer Aspire 5335-2257 Notebook
How do i find my built in webcam on my acer laptop?
I found that it is installed into my laptop but i dont know where to find it.
  • ted1430
    ted1430 May 11, 2010
    Are you trying to physically locate it, be sure the drivers are loaded properly, or use it? If you want to use it, what exactly do you want to do with it? Also, what OS are you using?
You go to all programs and select webcam but if you have vista than type in webcam at the start icon!
Posted on Jul 25, 2009
5 Suggested Answers
SOURCE: acer aspire 5630 -built in webcam doesnt work
My acer aspire webcam has stoped working pc doesnt recognise it
Posted on Oct 21, 2008
SOURCE: acer's built in webcam
remove pictures in pictures should solve problem did with me best of luck all
Posted on Apr 26, 2008
Pyrhyc
  • 2028 Answers
SOURCE: how to fix and install the built in microphone of my acer laptop aspire 4720z
If the sound has worked on this machine after the new hard drive was installed, then all you need to do is a system restore from the start menu, acessories/system tools. You may need to go back a couple of restore point in order to get it back, but this should do the trick. If it hasn't worked since the new hard drive was installed, then ou will need to go to the manufacturer's support site and download the drivers.
Posted on Aug 20, 2008
  • 1481 Answers
SOURCE: Built In webcam Installation
go to Device Manager and check all hardwares there...there will be webcam listed there try updating the driver...if not listed...then select any device there and chose the Computer Icon on the top...to update the "Scan for Hardware Changes"
if u get a Cam there listed there with any yellow ? or ! amrk chose it and update the driver...
it should be ok now...
Posted on Dec 26, 2009
I can't use webcam in my ACER 4750Z, it said
It is true that your laptop has no built in webcam. You just have to purchase an external webcam. Once you have it you just have to install it to your laptop then you are good to go.
I hope you find it very helpful.
Thanks.
Sep 20, 2011 | Acer Aspire 3003WLCi Laptop...
I have an acer laptop and it has a webcam built in the only problem is i dont have it installed and i dont have the cd for it is there anyway to do it online
go to the website snd look up your laptop. in the driver support area and look for the web cam driver.
You have to look for your laptop. Not the web cam. it is a laptops driver,,,
That should speed up your search
Oct 23, 2009 | Logitech QuickCam Communicate STX Personal...
My built in webcam dont want to work..in yahoo and picture taking
Acer Aspire 5610-4648 PC Notebook
Get Support from the link below.
you will get each driver from this link at support solutions by selecting your laptop / Note book
http://gd.panam.acer.com/home/
Dont forget to Rate.
Thanks.
Jul 23, 2009 | Acer Aspire 5610-4648 Notebook
Acer crystal eye webcam
You can go to the manufacturers website to check if you have the very latest driver for your webcam. if not, you should be able to download it from there.
Go to control panel, then system properties, then device manager, then hardware. check imaging devices to see if your webcam is recognized.
Mar 12, 2009 | Acer Extensa 5420-5687 Notebook
My laptop has a built in webcam... crystal eye
if ur drivers are updated from www.acer.com then u should look into settings of yahoo messenger and select and test ur camera but these settings will only work when u are online try if it helps check ur camera if it works somewhere else
Feb 20, 2009 | Acer Aspire 4315 Notebook
Acer's built in webcam
Take your laptop to your local computer repair shop, as it will take too long to explain a solution.
Good Luck.
Jan 22, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
After weeks of trying to install my Acer Crystal Eye Camera on an Acer Aspire 6920 with a fresh vista install, I have finally solved this problem.
The error I was getting when trying to install the drivers:
"Could not install device. The required section was not found in the INF."
The problem is a missing registry key for Imaging Devices.
Here's how to fix it:
1. Start Menu > regedit.exe
2. Expand HKEY_LOCAL_MACHINE
3. Expand SYSTEM
4. Expand CurrentControlSet
5. Expand Control
6. Expand Class (and keep it highlighted/selected) 7. Edit > New > Key
8. Rename the key to: {6BDD1FC6-810F-11D0-BEC7-08002BE2092F}
9. Open the key, in the right hand side double click (Default)
10. Rename the Value Data to: Imaging Devices 11. Reinstall device drivers and you're done!
May 11, 2008 | Genius VD3000022 Webcam
** Note ** When the My Pictures or Pictures folder gets full, camera will not work - Cut and Paste all pictures in that
folder to another folder and restart Orbicam program.
If that does not work then do this:
Start - Programs - look for Acer Empowering Technology then Acer E-Recovery - The look at the bottom and you will
"Backup", "Burn disk" and Restore" choose Restore - choose Apps and Drivers at the bottom of Restore tab (it will say
extracting) - once extracted - click Install or Guides and Manuals if needing Orbicam instructions - click Vista or (XP) on the left - click Drivers - click Camera or CCD - on the
right side of the screen, then look for Bison driver or (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) you have then click a phrase that has something like "Install now", follow on screen instructions. Then repeat steps above and instead of driver choose Bison (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) Utility
Nov 10, 2007 | Acer TravelMate 2300 Notebook
Did you install the necessary drivers for the webcam. If not, use the CD that came with the laptop to install the drivers and then try to use it with Yahoo, etc..
Mar 07, 2007 | Acer Aspire 3000 Notebook
Open Questions:
acer aspire 5335-2257 replaced 4 pin power jack intermittent power, only runs with battery but barely charges. acer aspire 5335-2238. My son's friend recently asked me to take a look at his laptop because he couldn't get it to take a charge or run without the battery when plugged in. Right away I noticed the dc jack was charred and the plastic around it melted. He said the power cord "brick" got really hot, all the way to the tip where it plugs into the laptop. I know the bricks can get warm but he said it actually burned his sister. I ended up replacing the dc jack and 4 pin harness with a new one and figured this would solve the power issue. It won't get power with the original power cord and I also tried a few others that were similar. The only one that worked was an adaptor that I think went to a cordless phone or something like. The next problem was I had to fiddle with the dc jack to get the yellow battery light on. Still won't turn on without battery. The battery at this point is drained so I left it plugged in all day, at least 12 hours and the green light finally came on indicating a charged battery. The battery only charged about 8-9% and died fast. I tried more adaptors and got another one to light up the yellow battery light, again a small modem adaptor, not one with the brick. This time I left it over night and got about 12% charge. Both times the laptop turned on, booted up and ran until the battery died after about 5 min. I'm out of ideas aside from maybe a bios problem but I can't get it to stay on long enough to do anything about it. I don't understand why the new jack isn't working, it's a pretty simple install, no soldering. I looked real close at the board and didn't see any obvious fried chips or anything like that. Any suggestions would be great. I've had this 14 year old kid's laptop for almost 2 weeks trying to figure it out (I also replaced his keyboard, disc drive and cleaned it up) and he's calling me every day.
Feb 27, 2017 | Acer Aspire 5335-2257 Notebook
Acer Aspire 5335-2257 Notebook Logo
1,623 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
