Question about MagLite Mag Lite Led 2 Cell Aa Flashlight Select Color
Minimag LED shuts off
I have been a Maglite user since 1983. I will continue to do so. However, I recently purchased two Minimag LED lights and both of them seem to have developed a heat problem; they will run briefly and then shut off. The serial numbers are: 20001480260 and 2T002158136. Is there indeed a problem with these instruments? I would have returned them but I somehow lost the receipts and anyway the Home Depot I purchased them from seems to have de-listed this model. What can you do to assist in this problem? Nick Roberts (noprobs@telus.net)
  • 121 Answers
First question is what type of batteries have you been using.. A fault was found by Petzl a last year that identified a problem with using certain rechargeable batteries or lithium batteries in LED lights. The problem was that the batteries have a higher output than normal batteries and the heat created was damaging the LED's, shortening their life and in a couple of cases causing burning. Petzl have fixed the problem in their models and sent out warnings to outdoor stores to warn of the problem but I don't think that has spread too far across the industry..
Hope this helps..
Posted on Oct 07, 2009
My AA Mini Maglite needed a new bulb, and I am upgrading with a 3 white LEDs and a tail cap switch ... but now nothing I try can get the torch to work. Can you possibly, help, please?
You've introduced two variables to your flashlight, and each needs to be tested independently. It's possible that one--or both--isn't working properly. It's equally possible that one or both of these replacement parts isn't perfectly meshing with the conductive areas of the maglite body, meaning that they're not completing the basic circuit needed to power the light.
The best way to test your tailcap switch is either to try it with another maglite or test its continuity with a multi-tester. With the tester, you should be able to toggle between readings of infinite resistance (switch off, no circuit) and little or no resistance (switch turned on). If you're stuck at infinite resistance, there's a problem with the switch.
You could test the LED insert by using test clips to touch power to the module to see whether it will light up.
My guess is that the components are probably good, but that somewhere along the line, there's a break in the basic circuit. My leading suspect would be the connection from the LED module to the negative (flashlight body) side. It could be that the module is slightly out of round and it's simply not making contact. It could be that the finish of the maglite is acting as an insulator. However, I would recommend deferring this analysis until you've confirmed that each component works fine.
Jul 12, 2011 | MagLite Rechargeable Flashlight System
Wont turn on
mine came with the pushbutton battery end replacement to turn on\off rather than twisting the reflector end. You can not have the reflector end screwed all the way in, this still turns the light off. You have to back the reflector end off a tad from being all the way in, then use the pushbutton to turn it on/off.
Jun 19, 2010 | MagLite RAM Instrument Minimag L.E.D....
Is there a rear cap on a mini maglite. I am
Yes there is a cap. I had the same problem most likely the battery inside has corroded and leaked fusing the cap shut, contact MagLite at www.maglite.com if there were either Duracell, Eveready or Ray-O-Vac batteries in there they will replace it for free under warranty.
May 26, 2010 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
What way do i put the battries into a maglite
Place the batteries positive (+) end first into the flashlight tube and continue putting other batteries, again positive first. Good luck!!
Oct 11, 2009 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
I have replaced batteries and bulb in maglite flashlight. Problem is still the same. The light comes on but immediately dims to very poor light. Can't get at switch ---it's a maglite.
Sounds like a bad switch, but if you live in the US, you have a limited lifetime warranty on your light.
Contact Maglite at: http://www.maglite.com/feedback.asp
You should also consider installing a LED bulb in your light. If you use it much at all, it will quickly pay for itself in battery life and the light is a lot whiter.
May 13, 2009 | MagLite Mag-Lite& Flashlight
Mini Maglite LED not staying on
I found this site because I too have a pile of these with that problem. I have had maglites since the time when they weren't available to the general public and have always liked them. These new LED lights are great for the light/size ratio and I was very sorry to see this product perform so poorly. After reading the comments here I went to the Maglite site and found some troubleshooting tips. Believe it or not I fixed the one in my hand and can't wait to go fix the others. They really need to spell out on the package how the LED unit works when the batteries get low. Apparantly when they do get low the unit won't dim, it will completely shut off. You turn it off and then back on again and it flashes on but then stays off. According to the troubleshooting there is a bit of electonics in this unit that will shut the unit off if the battery voltage falls below a certain threshold. This appears exactly like a poor contact problem. I thought I had try battery replacement on some of my units in the past. The toubleshooting section does also cover other possible issues and shows how to try to fix them - not a bad document. Here is the link - good luck - I hope they stay in business. I think they need to address this issue somehow or else they will silently loose their market share. http://www.maglite.com/pdf/CustServ/Mini%20Maglite%20LED%20FAQ5222007805552.pdf
Jan 27, 2009 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
My Mini mag AA worked until I took it apart to install an LED kit
Start with a new mini-mag and put the upgrade in it. It will save you the frustration, especially not knowing for sure whether their is a missing part or not. Plus it will save the hassle.
GGBMDB
Nov 15, 2008 | MagLite Camping, Backpacking & Hiking
MagLite Mag Lite Led 2 Cell Aa Flashlight Select Color Logo
378 people viewed this question
Top MagLite Camping, Backpacking & Hiking Experts
John Egan
John Egan
David Black
David Black
Level 1 Expert
 steve
steve
Are you a MagLite Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
