Question about Sewing Machines
How to fill the bobbin spool on a dressmaker sewing amchine
How to fill the bobbin spool on a dressmaker designer series 125 sewing machine
SOURCE: Kenmore 10 Sewing Machine
kenmore sewing machines relics
Posted on Jul 13, 2008
SOURCE: bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
Posted on Sep 29, 2008
chris592
  • 86 Answers
SOURCE: instruction manual for the dressmaker 6800
goto ifixmachines.com they have your manual, just email them if you don't see it
Posted on Nov 03, 2008
  • 2692 Answers
SOURCE: Need Dressmaker 300z sewing machine manual
you're welcome. have a good new year.
Posted on Jan 01, 2009
SOURCE: thread knotting around bobbin case
hello, I had the exact same problem and could not find the solution until i took my machine to my sewing sensei and i solved my tedious problem. It was actually not a tension problem at all but a threading problem. Make sure you have threaded your bobbin correctly and that when you pull on the bobbin thread that the bobbin turns the right way. (mine must spin anti clockwise to work)  Make sure that when you pull up the bobbin thread using the needle that it is not over the feed dogs connective bar but under it. A big problem when the thread gets caught around the bobbin case wheel is that the thread is looped around the feed dogs once and that causes the thread to get caught around the bobbin wheel. In conclusion, thread the bobbin correctly and read over your instruction book before spending the money to get it fixe in s shop.
Posted on Mar 31, 2009
For the dressmaker II, the first bobbin, I got through step 1-5 but where the does step 6 go BECUZ that's really trippin me, PLS tell me. And the instruction is not clear at all, I don't understand it
Hi Vicky, I hope this helps you:
1. Remove the slide cover plate by sliding it toward you, and lift
up the bobbin and the bobbin case from the machine.
2. Put the bobbin pin into the hole on top of the hand wheel and
place an empty bobbin on the bobbin pin (spindle).
3. Lift the large spool pin from the back of the machine and
place the spool of thread on the large spool pin.
4. Place the bobbin winder tension clip into the hole in the back
of the machine.
5. Pull the thread to the left and pass it through the bobbin
winder tension disc.
6. Insert the thread through the hole in the bobbin from the inside
out and leave about 3" of thread out. (ensure that the hole on the bobbin is facing upwards)
7. Hold the end of the thread and start the machine, either by
pressing on the start button or the foot control. After the
bobbin winds a few turns, stop the machine and cut the thread
close to the bobbin. (Cut the thread end that is protruding from the hole at the top of the bobbin).
8. Start the machine again and continue winding until the bobbin
is full or the quantity of thread is enough for your needs.
9. Stop the machine and cut the thread. Remove the bobbin from
the bobbin pin.
10.Take out the bobbin pin from the hand wheel and push back
the large spool pin into the slot in the back of the machine.
Good luck :)
Jun 21, 2015 | Euro-Pro Dressmaker 998B
Manual for 750 dressmaker
Any sewing machine repair and sales store has bobbins, they are in different sizes so bring an old one.
Jan 21, 2012 | Sewing Machines
When I go to fill my bobbin spool, the machine just beeps at me. I've tried everything. Please help!
If you try to wind the bobbin with the embroidery unit on, you need to send a design to the machine before trying to wind the bobbin. If the embroidery unit is off, you should wind the bobbins without any problems
Aug 22, 2011 | Singer CE-200 Quantum Futura Computerized...
How do you adjust the bobbin
Hello
Set the tension on the sewing machine for the weight of the material you want to sew. The tension setting shows in the stitch on the material. Use the chart on the machine that matches types of stitches with suggested material tensions. An example of this is, the stitch to sew jean material is different than the stitch to sew silk.
Take the bobbin and wind the thread around it. Make sure the bobbin is empty and don't fill it too full of thread. A bobbin filled too full won't stay tightly spun.
Thread the string evenly on the bobbin. Move the thread back and forth evenly and in layers that are level. Many Singer sewing machines have a bobbin winder on the top of the sewing machine, and the consistency of how it threads can save you frustration later.
Find the hole on the bobbin that is located near the inside spindle of the bobbin. Take the thread sitting on the sewing machines spool and insert the thread in the hole from inside the bobbin to the outside. Set the threaded bobbin on the spool designated for spinning on the top of the sewing machine for some Singers.
Turn the side drive wheel slowly until the threaded bobbin has a layer or two of thread on it. Push down on the drive peddle and fill the bobbin, but don't thread it to the very edge. If the bobbin is too full the thread will release erratically. Cut the thread from the spool.
Drop the bobbin into the bobbin case under the area where the needle sews the material. Close the case and turn by hand the side wheel drive until the bobbin threads into the sewing machine. You can tell when the bobbin is threaded by the tiny piece of thread that juts out of the bobbin case where the needle goes up and down.
Grab the thread with your fingers and pull it out approximately 4 inches. Your bobbin is now spun and threaded.
Aug 02, 2011 | Singer 1120 Mechanical Sewing Machine
HOW TO THREAD THE BOBBIN
Take the thread-end from the thread spool to the left, around the bottom of the "silver" "button"; across the top of the button and back to the right to the bobbin winder.
Run the thread-end through a hole in the side of the bobbin spool, hold onto the thread (pull through about 5" of thread) and place the bobbin spool onto the the bobbin winding pin.
You may have to turn a bit to the left or right to get the spool in place. Push the bobbin spool to the right; against the bobbin winding wheel.
Press on the power pedal - keeping hold of the thread-end.
As the bobbin fills, the thead end will twist.
When you can not longer hold on. Stop the machine and clip the thread end then continue to wind the bobbin.
You can view and download a manual here (free) - http://www.brother-usa.com/manuals/default.aspx?PGID=3&R3ModelID=XL2230
Mar 25, 2010 | Brother XL-2230 Mechanical Sewing Machine
I cant remember how to fill the bobbin with thread :(
Insert the empty bobbin case onto the bobbin winder in the sewing machine.
Step 2 Set the spool of thread onto the thread peg. Use the same thread you want to use on your material to obtain the best finished stitch.
Step 3 Follow the arrows or guides to take the thread from the spool to the empty bobbin.
Step 4 Start the thread around the bobbin in a clockwise direction.
Step 5 Push the small lever against the bobbin spool to hold it in place. This disengages the needle so it won't go up and down while winding the bobbin.
Step 6 Press the foot or knee pedal to start the winding process. Stop when you have enough thread on the bobbin for your project.
Step 7
Cut the thread between the thread spool and the bobbin. Insert the bobbin into the bobbin case so you can begin sewing.
Open to clarifications.
rate this.
Jan 10, 2010 | Janome Jem Silver 662 Mechanical Sewing...
Thread is not pulling off spool while trying to fill a bobbin.
There are a couple things that come to mind. If your plate is not pushed all the way up where it engages the metal tab on the bobbin, it will not wind properly. Second, if you are using a generic or an old bobbin, you need to replace it. I have seen many machines drive the owners crazy and it turned out to be a bad bobbin.
Jan 20, 2009 | Singer 132QRFB Mechanical Sewing Machine
Sewing Machines Logo
342 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
