Question about HP OfficeJet 6110 All-In-One InkJet Printer
Changed black cartridge, kept getting the alignment error. Used the hold enter for 5 seconds then menu. Cannot copy anything colour or black and white
    President:
  • HP Master
  • 1,996 Answers
It sounds like you've already seen this article, but just in case...See also here for cleaning cartridge contacts.
Otherwise, work through the steps outlined here to try a power cycle or reset to clear the error.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 25, 2009
My printer window on the HP PSC 2175 continues to read: 'Press Enter to align cartridges' I have done this 5 or 6 times and the message will not go away. How do I fix this problem so it will print?
Perform the following steps to align the ink cartridges:
  1. Disconnect the power cord from the unit, wait five seconds, and then plug it back in. This will reinitialize the unit.
  2. Print another alignment test page. If the Press Enter to align message is not currently on the front panel display, complete the following steps to print an alignment page:
    1. Press Setup or Menu on the front panel (depending on the model).
    2. Press the right arrow button (>) until Maintenance or Tools is displayed, and then press Enter or OK (depending on the model).
    3. Press the right arrow button (>) until Align Print Cartridges is displayed, and then press Enter or OK (depending on the model).
  3. To determine if the automatic alignment is functioning correctly, look into the output tray as the alignment page is printing; a blue light should be visible periodically on the page as the cartridges move back and forth. If this light is not visible, the product will not be able to align the cartridges and will require service. Service the product.
  4. If the blue light is visible and the alignment pages are printing correctly, but the alignment pages still fails, there still may be a hardware problem with the unit.
    • If there are no other printing problems and you wish to continue, use the information in the Bypassing the ink cartridge alignment section below to bypass the alignment. The information from last successful alignment will be used.
    • If the message keeps reappearing or other print quality problems occur, service the product.
Models with a semi-automatic print cartridge alignment Some HP products have a semi-automatic alignment process. These models do not have an additional sensor and will print two pages for the alignment process instead of one. The alignment page must be placed on the scanner glass or into the automatic document feeder (HP Officejet V series) and scanned.
  1. Disconnect the power cord, wait five seconds, and then plug it in. This reinitializes the product and forces the scanner to calibrate again.
  2. Examine the scanner glass and white scan backing. Clean the scanner glass and scan backing if they are not clean. To clean the scanner glass and scan backing, use a soft cloth towel slightly dampened with clean water.
  3. With the product turned on, open the scanner cover and check the bulb assembly. If the scanner bulb is not lit, the product must be serviced.
  4. Verify that the alignment page is placed correctly on the scanner glass or in the ADF (if the product has one). Place the printed side down.
  5. 5. Make a copy of the alignment page. The unit will make a copy even if the alignment message is displayed. Compare the copy to the original. If vertical lines appear in the copy, check to see if the scanner assembly requires cleaning. If cleaning the scanner assembly does not correct the problem, service the product.
  6. 6. Use the information in the Bypassing the ink cartridge alignment section below to bypass the alignment. Operate the HP All-in-One to determine if there are other problems. The unit should be serviced if other error messages or problems occur or if alignment problems occur every time the ink cartridges are changed.
To bypass the ink cartridge alignment: Press and hold the Setup button, and then press Options (or Copy Options ).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 26, 2011 | HP PSC 2175 All-In-One InkJet Printer
HP Deskjet F4180 colour lights flashing and printer offline
Hi I have exactly the same problem, and can't scan or make copies. I went to HP Online, and tried their advice, which didn't work. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00867129&lc=en&dlc=en&cc=us&product=3177566&rule=25623〈=enHP's solution made me realise it might be a scanner problem. I made a wild guess and kept the cover above the glass panel open. Turn off your printer, lift the cover up and turn on again. The lights should stop blinking and you should be able to scan/copy/print. I guess the cover prohibits the device to scan properly causing the blinking lights. Hope this helps!
Jul 01, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Changed black cartridge. Machine works fine, but
To align the cartridge from the control panel:
Please follow the steps given below:
1. Please Load a plain paper.
2. Press and hold the "Scan" button for three seconds.
3. An alignment page prints.
4. Place the alignment page onto the scanner glass.
5. Press the "Scan" button.
6. Once scanning is complete, the cartridge has been aligned for optimal print quality. Alignment must be complete before continuing with any print jobs.
Apr 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Canon MP610 out of black ink
Cannon Pixma MP610 - when the black ink is empty and you receive the replace ink message, then hold down the "cancel" button for 5 seconds or so and it the printer automatically bypasses the problem. It does work but Ive had mixed success in terms of the print quality when doing this.
Mar 26, 2009 | Canon MP610 Photo All-In-One Printer
Error message after replacing the black cartridge
You must replace both ink carts to get an alignment.
Dec 29, 2008 | HP PSC 2210 All-In-One InkJet Printer
Printer cartridge alignment
You can also bypass the alignment. When the message for alignment displays on the display => Press Setup and Options (or Copy Options ) simaltanious.The last known alignment is used when the alignment is bypassed.
Sep 04, 2008 | HP PSC 2175 All-In-One InkJet Printer
I keep getting cartridge error or it prints a blank page. There is no tape on the cartridge and they are installed properly. It prints sometimes but not all the time Printer keeps saying cartridge error
This has been just happening with me aswell - I just changed the colour cartridge with the black cartridge ran out but i kept it in as it told me to place one in. Trying to print out but black ink wont come - just blank pages - surely the colour cartridge can make black? However, if you have the colour cartridge and are on microsoft word or similar, change the colour of the writing to dark navy and it will print out documents.
Aug 26, 2008 | Lexmark P6250 All-In-One InkJet Photo...
CANNOT ALIGN CARTRIDGES
Press and hold the Enter button, and then press Menue.
Also visit
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bpu00657#Bypass_Alignment
Jun 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Replacement cartridge
Try removing the colour cartridge. Clean the contacts (the part they tell you not to touch) with a damp tissue and then with a dry tissue. Ensure there are no obstructions within the printer and that there is no tape left on the cartridge which should have been removed. Fit the cartridge back in. Turn the printer off then on again.Now hold in both the colour and black copy buttons for atleast 10 seconds. (Sometimes these printers think you are using a cartridge which has been previously used, and in canons attempts to stop refillers, they have incorporated an error. Hold in the previously mentioned buttons to overide that error.)
Jun 06, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Printer will not copy
It Does keep asking if it fails to get it right, usually it fails to get scan of alignment page completed correctly because it fails to see one of the colours printed on its alignment page correctly,
I would guess that you should change colour cartridge as well (these I have seen deplete themselves trying print black when black ink is not present.
There is also a way of telling your printer to forget about alignment would you like to know how......Press and hold the Setup button, and then press Options (or Copy Options ).
Here is a link to how an alignment page should look and HP answers to your problem, please rate my solution for me.
Nov 21, 2007 | HP PSC 2175 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
114 people viewed this question
Seeker5211
Seeker5211
