Question about GE GSS25WSTSS 25.4 Cu. Ft. Side-by-Side Refrigerator with External Controls and Dispenser
Trouble with freezer fan
The fan at the bottom of my integrated freezer is permanently on. Is this correct?
  • mattnoone Jul 26, 2009
    Thanks. The only problem is that its a brand new ex-display model that I bought off MFI, so it wont be on warranty. When I first plugged it in the fan casing was in pieces, which I bought back together. The noise doesnt sound like its broken it just sounds like an industrial sized air conditioning unit!
    Novelist:
  • 108 Answers
Usually, yes. It should be very quiet, so if it sounds loud enough for you to hear it easily it may need replacement- if that fan breaks, everything in the freezer will melt.
Posted on Jul 25, 2009
  • StanStihl Jul 26, 2009
    Well, in my experience, the fan is usually quiet... if it seems to be blowing hard then it's probably fine... perhaps it is vibrating in the housing a little bit, or a mounting screw is a little loose, or something like that.
My bottom mount french door refrigerator, the upper part does not cold, it's warm
Sorry your having trouble so soon!
First thing you need to check is inside the freezer section.
The freezer fan, the fan is W10128551 and should be running
along with the main compressor. Since the freezer is working,
I would check the food on the top drawer or on the freezer door shelf.
They too might be soft..without the fan.
I would You tube 'evaporator fan motor replacement Amana bottom freezer model' Yes I know it say's Whirlpool, but your unit is really
a Amana designed unit. I would give this a difficulty of 3 out 5 wrenches.. Take your time..
John Wright
Jul 27, 2014 | Whirlpool GX5FHTXT Bottom Freezer French...
Neff fridge/freezer has stopped cooling
pull the unit from the wall, remove the bottom back panel , see if the small fan is working ,if the fan is , there's probally alot of dust back there,unplug the fridg. and vacuum the area real good,use a flash light to make sure you get it all, if the fan is not working and the compressor is running the fan is the problem ,the fan keeps the compressor and coils cool so the freon can cool down so the unit works like it should,if the freon is hot ,the air the fridg.will be blowing will be hot. this should fix your problem, and YES its worth fixing.alittle p.m.saves alot of $$$$$$$$$
Dec 03, 2013 | Neff Freezers
Does this bottom freezer refrigerator need ventilation when integrated?
Hello there,
Yes, the bottom freezer refrigerator needs ventilation when integrated.
All the best. Elect_Comp
Sep 21, 2011 | Zanussi ZI918 / 12K Bottom Freezer...
Water leaking from freezer forms ice on bottom of the freezer needs to be removed every week or leaks onto the kitchen floor. water coming from back wall of freezer from what appears to be vent cracks in...
Hello and Welcome to FixYa!
Well, it seems like the drain pipe or the drain channel is clogged, and the defrost water from the evaporator coils is dripping through the quoted regions, down to the base. Try checking the drain hose/ channel and remove the clogging if any (Blow some moderate temperature air through the channel and check/ remove any permanent clogging If any). Feel free to ask the details, or any question relevant to the trouble..
Concerned.
Aug 11, 2011 | LG LRDC22731 Bottom Freezer Refrigerator
Zanussi integrated fridge freezer, top half fridge not working
It appears you need to get the cold distributed from the freezer section to the frig section. This can only be accomplished by a fan that forces the cold air throught openings between both sections. Since the freezer in at the bottom, cold air cannot go upward, thereforethe fan. Chech that the interior fan (in the freezer section) is running. Check that the air openings between the sections are not blocked. Finally, if all looks good, then maybe the compressor system is slowly failing and only making enough cold for the freezer, but not enough to be circulated. Goodluck, Macgivor
Jan 02, 2010 | Refrigerators
Freezer too cold, fridge not working - Amana freezer on bottom
Something tells me you are right.
I'm sure you know that cold air seeks the lowest point, in your case, the freezer drawer.
About every combination unit I have ever seen uses a fan to 'stir' the air in a controlled manner and one or more adjustable vents to allow you to balance the distribution of the cooled air.
I'd place my bet on the failure of a (possibly Chinese) fan motor that isn't turning anymore.
Jul 26, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Smeg integrated kitchen fridge and freezer unit - freezer stopped
beneath the freezer usualy installed timer and a fan look for a hidden screw on the sides...check the fan bushing f its lose or has a clearance change it f not check for the timer if its busted...replace.. becareful...electric shock can kill
Jul 11, 2009 | Smeg FC40RX Bottom Freezer Refrigerator
Water in bottom of refrigerator
WARNING-It is a condition for the reader to take full responsability in attempting repairs and author shall not be responsible or liable for any damages. If you have no knowledge or experience to do this repair do not attempt it.
I have had the same issue with Fisher Paykel Active Smart fridge . This can be due to:
1) 12Volt fan in freezer is not functioning.
To test: open freezer door, place a magnet on magnet switch at the bottom of freezer where door seals(white plastic rectangle) It takes few seconds for fan to rev up so move magnet slowly until switch on. You can also close door and listen carefully if fan starts if unsure.
If fan works go to 2) 3)as defrosting resistance can be the trouble
2)If fan does not work . UNPLUG FRIDGE at the main plug
Empty freezer and defrost it if too icy (do not use sharp objects). Then on back panel you will see two holes on top. Put two hook tool and pull down and slightly forward until top lip is free. This is hard to do but the plastic panel is very strong so you can apply a bit of force there!!!
On the second panel is the fan, check wires are not broken (common cause of failure). unplug fan, you can check fan on 12V battery (+red). Buy a new fan if faulty and put freezer panel back.
3) If fan OK and you see a lot of ice on condenser (do not remove it by force, just let it melt completely) then the resistance is the cause of you trouble. It is delicate to remove and make sure FRIDGE IS UNPLUGGED! Do not force anything as condenser is very fragile and if you damaged it, your fridge can go straight to the dump. You can test the resistance with an Ohm meter to make sure internal resistance is broken or not. If broken replace it and your fridge will be fixed. If not broken then trouble is either with on board computer (very seldom) or the thermistance.
Oct 16, 2008 | Fisher and Paykel Active Smart® E522BR...
Bottom of freezer/fridge only getting cold.
Thre is a fan inside the freezer which circulates the cold air around both the fridge and the freezer compartments.
You should be able to feel cold air blowing around the inside, particularly at the top of the freezer.
If the defrost thermostat fails open, the internal fan (depending on freezer) will stop and this can be the cause of the freezer being warm at the top and no ice.
You say the bottom of the freezer is blowing cold, but are you sure its blowing, as it can feel like a cold blow. Of course the fan could have failed or may be the defrost heater itself.
Have a look at this site for some useful trouble shooting
And a good site for troubleshooting and general info
Refrigeration Help Section, Fridges, refrigerators, not cold enough, frost free problems and how to test, noisy fan motors, clicking on and off compressors, door gaskets
Nige
Sep 26, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
142 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
