Question about Kirby G4 Bagged Upright Vacuum
The belt wom't catch when I try to attach it to the motor spool
  • 636 Answers
Do you have the latch in the wrong position? try and hook the belt with front dial and this should work for you.
Posted on Jul 25, 2009
Replace the belt on a upright vac
There is a very small wheel attached to the motors drive. Belt goes around the motor drive wheel and then around the drive roller assembly
Feb 22, 2010 | Kenmore 34612 Bagged Upright Vacuum
The brush roller stops turning and I can smell the belt burning, then it will catch and start working normal. I looked under the plate to check the belts and they looked okay and no hang ups of string or...
better to replace both belts the smaller one is stretched out thats whyits slipping ,be sure to clean the old rubber off the motor shaft before replacing the belts.it will cause the new belts to run unevevly and go bad before their time
Aug 30, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Replacing a belt on the unit. How do you get the belt onto the spool?
Place the belt on the motor shaft then slide the beater bar into the belt. Center the belt where it should be on the bar, then insert the bar into the end sockets. It'll be tight. Replace the base blate. Done!
--W/D--
Aug 17, 2009 | Bissell Vacuums
Belt
Hi. This isn't a hard repair at all.... Unplug your vacuum. Turn the vacuum beater bar side up. Locate the catches or screws that hold the plate on that covers the beater bar. Remove the plate. The beater bar sits in sockets where it attaches to the vacuum, so remove carefully, making note how it comes out. This will make reassembly much easier. Place your new belt on the motor shaft, then onto the beater bar while you replace the beater bar back into the sockets. Test your work by revolving the beater bar a bit by hand. Reinstall the cover plate. That's it!
Regards! --W/D--
Jul 17, 2009 | Bissell 6594 PowerForce Bagless Upright...
MY VACUUM IS NOT PICKING UP
Hi This is quite complicated but I'll try and simplify this for you:
If this is a Panasonic upright then there are two drive belts as you know. Once you take off the sole plate (where the beater bar is) by undoing screws and the beater bar is looking at you, you would have to take off the smaller belt motor pulley first before putting on a new larger drive belt. If the smaller belt is still intact and you only need to replace the larger belt, you'll still have to take off both belts to put on the new drive belt.
Motor pulley belt has to be taken off first then the old drive belt, then grasp the beater and slide on new larger drive belt before having to attach the motor pulley belt and then the larger belt onto the motor pulley. Once all belts have been attached ensure that the beater bar is pushed in correctly before you screw the sole plate back on.
Apr 03, 2009 | Panasonic Vacuums
Hoover Savvy Belt
put the belt over the brush roller first then put the brush roller on then you can start one side of the belt on the motor shaft and turn it will make its way onto the gear on the motor
Dec 28, 2008 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Floor Attachment
Try this,
With the floor nozzle off the machine spin the belt lifter around until the red arrows match. If you look at the side that attaches to the vacuum you should be able to see the belt up on the hook. If is not on the hook offf the machine you will never get the belt on. Once the belt is on the hook attach the floor nozzle to the front of the machine. At this point you need to spin the belt lifter back to where the green arrows match. Oh and another suggestion make sure your hieght adjuster the pedals with arrows are all the way up. Hopefully that helps you out.
Jul 04, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Attaching the Belt
Leslie,
Rotate the square knob on the front of the attachment to the "Belt On" position (green marker). Insert your fingers in the attachment port (the round opening on the back where the "hook" is) and position the belt so it's centered and as high up as it will go (that's usually just below the center of the opening. THEN rotate the square knob on the front to the "Belt Off" position. You should feel the belt tighten up and the know harder to rotate.
TJ
May 02, 2008 | Kirby G5 Bagged Upright Vacuum
Belt replacement
The belt handle should be turned so the red arrow is lined up. Then make sure the belt is hooked on the inner assembly handle. Reconnect the vaccum assembly to vaccum and turn handle to allow green arrow to align and the belt is hooked on motor rod anmd your ready to vacuum.
Jun 16, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G4 Bagged Upright Vacuum Logo
78 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
