Question about Motorola Mobility A1200
When i start it Phone screen just lits but don't go any further
The memory was full and I cleaned it. Then my battery kind of switched on and off repeatedly continuously for about 2 days. And finally now, when I start it the phone screen lits but it stops there. No other action. Is this problem with battery or end of my phone??
  • 35 Answers
Its not the end of your phone,if it lits and remain on with blank screen,replace the flex it will work.
Posted on Jul 26, 2009
Problem connecting Nokia 200 to PC
this is all i could find out about this problem.
Problem:
When a Nokia phone is connected to a computer through a USB connection, 'please wait' message is shown in the phone screen followed by 'no response from host' message. Further, the computer might show a notification around the taskbar area that the USB device is not recognized.
Solution:
  1. First check if the required drivers for the Nokia phone are correctly installed on your computer.
  2. If required, update current version of your Nokia PC suite to the latest version.
If the above steps do not work then follow these steps:
  1. Switch off your phone.
  2. Remove the back cover of your phone.
  3. Remove your phone's battery.
  4. If your phone has a memory card, also remove it.
  5. Wait for few seconds. If you see any dust sticking around the battery or memory card, wipe it clean. Be careful while cleaning the memory card. Hard contacts may result data loss.
  6. Place the battery and memory card back in their places.
  7. Put back the cover.
  8. Switch on your phone.
  9. Try connecting your phone to a computer again. (Your phone should connect successfully this time)...
  10. or try this link out.
Problem connecting Nokia 200 to PC No response from Host Google Search
Oct 30, 2017 | Cell Phones
Good day all, my blackberry bold 9000 battery drains within 4 hrs after full charging. I have done the following to stop it to no avail: 1. GPS - off 2. Wifi - off 3. Data service - off 4. Memory...
Try this test: remove the battery and place it on a flat surface. Try to spin in. If it spins like a top, the cells are bloated and it needs replaced. Whether it spins freely or not, cell phone batteries significantly decline after 12 months of use.
Sep 10, 2017 | Cell Phones
I have Nokia 5310 Express Music and from few days I am not able to view any Message. The phone memory status shows $9.9GB stored in message. I have tried uploading new software and formatted even the...
format the phone to this step..
press hold * , 3 , call , switch on ... w8 until the screen appear that your phone been formatting..
see to it that your battery is in Full.. Thanks
Sep 14, 2010 | Nokia 5310 Cellular Phone
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
My 200i not start up
ur phone has virus if u couldnt remove it safely so you go to ur mobile expert and get a consultation
Feb 20, 2009 | Sony Ericsson W200i Cellular Phone
Hangin out last
Virus problem try formatting your cell.
If this doesn't work tell me.
Sep 21, 2008 | Nokia N72 Cellular Phone
My n73 always shows that my memory is full
you need to format your phone. try the soft format of *#7370# , if this doesnt work then do a hard format by folowing these steps
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card.
3. Switch-off your phone.
4. Press and hold these 3 keys; Green dial key, * (star key) and no. 3 key and then press the power on/off to switch on the phone.
Do not let go all of the keys, hold until you see a formatting word screen show!
5. After a few minutes when the full phone formatting completed, your phone will be back to original system and factory setttings.
All applications installed will be lost unless you've made a backup on your mmc. You can restore the backup to the C drive again.
You should also try to save all your data on the mmc, that includes pics, mp3, videos ,games. avoid saving data on phone memory unless you have no memory card (mmc)
Formating phone will delete all your files in the phone memory so you should back up all your data before doig a full format
May 23, 2008 | Nokia N73 Cellular Phone
Not swicthing on
when i try to switch the phone on it comes up memory full.. phone start up promblem on screen.the phone wont switch on. i want to save all my info on the phne or access it. can u help plse..
Answer:- If It doesn't swithes on then there is no way to save any info. U must erase its all data by pressing
[calling key(green key)3 * and switch it on u must press all 4 of them at once and remember ur battery must be charged enough to run it atleast 20 minutes and it will show formatting and after a few minutes it will start and ask for date & time
Apr 28, 2008 | Nokia 3650
Motorola Mobility A1200 Logo
64 people viewed this question
Top Motorola Mobility Computers & Internet Experts
Unlockingcom
AJMAL KHAN
Tom Chichester
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
