Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Is there a short term fix or some way to get the tv to come on with g-board issues?
2 Suggested Answers
vortash
  • 431 Answers
SOURCE: Horizontal Bars Across the Screen
The problem sounds like hum bars that is the term when ac power is leaking on to your set from the power supply in simple terms .
televisions have a switch mode power supply and the front stage of this is the AC filter one or two large capacitors that block the ac from your set these are set across the + and --_ terminals of the Bridge rectifier the device that converts the AC into DC .. this is not a fault that should be re-ocuring so often especialy with this age of set , unfortunate that this was only repaired so recent but a new board may not realy be needed here just a few components I suggest you get a free estimate done on your set , warranty work and insurance work is always loaded , but private work has to be competative give it a try you may be pleasently surprised
Regards Vortash
Posted on May 13, 2009
We have 4 hisense TV's that are being used in teletext mode at a horse race track and they all keep freezing,remote will not operate either, to fix we repeatedly turn tv off and back on, this is short term...
If all are acting the same I don't think its an issue with the TV's, chances of all them having the exact same issue is slim to none, I'd look at the input signal for starters.
Feb 04, 2018 | Televison & Video
60 inch mitsubushi tv keeps turning off
What is the Model Number.
Depending on the Model, using the TV front control panel buttons, press either the INPUT + MENU or DEVICE + MENU and hold both depressed for about 6 seconds. DO you get the flasinng green light indicating a ERROR CODE. If so, what is the error code.
Press the RESET button, using a paper clip or other item ... May fix the problem "short term"
Possible Issues:
1. Inadequate cooling ... unlikely
2. Cooling Fan intermittent or defective ... unlikely
3. Temperature Sensor is defective or not seated properly ... probable cause
4. Reseat the Temp Sensor ... may fix the problem
5. Remove and Replace the Thermistor.
Jul 22, 2012 | Mitsubishi Vehicle Parts & Accessories
The 37 " lg tv
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Hope this will helpout....
May 14, 2011 | LG Televison & Video
I have a Westinghouse lvm 37w1 tv and it keeps turning itself off sometimes it will let me turn. it back on and sometimes I have to wait a few minutes do I need to buy a new tv can I fix this myself
I hope this will help to solve the problem....
May 10, 2011 | Televison & Video
I have a toshiba tv rearprojection the sound works but no picture but some times when u hit the side of it the picture will come on
While percussive maintenance works in the short term, it's going to be time to fix it sooner or later.
I would specifically check for cold solder joints on the power board.
Touching up the solder connections even if they don't look bad may provide the answer.
Try moving the cables or tapping the boards while it's on with an insulated instrument (I use a sharpie plastic marker myself) until you zone in on what board and eventually what connector/cable/component is causing the issue.
When in doubt, if you at least locate the board with the problem, SOLDER EVERYTHING.
if you actually locate the issue though, just solder the area that needs it.
Apr 12, 2011 | Toshiba 43A10 43" Rear Projection...
Tv want come on and standby light blinking 9 times
I do not agree with given info by previous expert that has no idea how tv works.
9 times red light blinking shows problem with sound output chip in tv, please check following things to fix the issue or pass it to local tv repairman if you have no electronics stuff fix experience.
/- 19V line is shorted on A and B boards
IC708 is defective on A board
PS701 or PS702 (both are fuses) is blown on A board
Hope these info will help you.
Thanks.
Sep 10, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
During bootup, the screen shows: 1. server raid-7k on board power-on self test takes up to 60 secones. after 60 seconds, displyed another line shows: status - not responding properly - error-code 2807
It means that your raid is not seeing its drives. Usually after a power failure.
Rebooting the server will fix it in the short term.
To fix it long term you need to update the servers firmware.
Aug 25, 2010 | Computers & Internet
Call Sony they our a reasonable company and keep very good records of repair. One of the questions that should be asked is, do the bars show up in the tv's on screen menu? That would tell me where the problem is.
Apr 13, 2009 | Sony BRAVIA KDL52XBR2 Television
Stopped running
try putting on fast freeze. if it starts up this means thermostat is faulty. get back to me if you want
Apr 04, 2007 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
53 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
