Question about Kenwood KAC-9152D Car Audio Amplifier
My amp shuts off at high volumes as well
I have tried running it at 4 ohms bridged and it runs fine but when i switched over my subs to 2 ohms per sub and ran them individually to each channel it cuts out.. it won't cut out however if i turn down my bass gains. i've added a cap , i've moved my ground countless times to better spots, i've replaced all my wiring to competition wiring, brand new battery i'm out of solutions. i originally had the problem with one sub. the answer i was givin was i had a bad coil so i bought a directed sx 12 and wired it up and still had the same problem so i bought another directed and ran them into a 4ohm series and never had a problem i'd like to go down to 2 ohm but is 4ohm my only option here.?
SOURCE: AMP FOR SUB SHUTS OFF SOMETIMES
your amp may be overheating, or you have it up too loud and the surge protector is shutting it of in fear of damage to your amp.
Posted on Apr 24, 2008
SOURCE: Amp goes into protection
First change the wire,and disconnect the subwoofers to check if the amplifier turn on without going in to protection mode,if the amplifier go to protection mode you gotta change the Audio amplifiers IC's because they are in short circuit.And if don't go in to protection put one speaker at a time to check if one of them are damaged.Good luck.
Posted on Jun 02, 2008
SOURCE: KAC-9104D output terminals
ok i have the same amp and 1 2ohm dvc sub and was woundering the same thing but from futher research and askin sum xsperts. What i found out is that it is only one channel and even tho there are 2 (+) and 2(-) they actually connect inside the amp makein it one . so if u wanted to wire sumthing parralel u wouldnt have to hook wires from one coil to the other on the speaker , u can just hook it up to the amp. so basically both +'s and negatives on the amp are actually one within it so all the power if you only use one set of them and if u wanna add more subs its just easier to add to the amp by using the xtras .
Posted on Feb 15, 2009
etirbynnor
  • 655 Answers
SOURCE: Have kenwood mono amp 4,2,1 ohm capabilitie. What
Hello pelikant75,
The best answer depends on your budget for the sub(s) and exactly what kind of sound you are looking to get. Your amps RMS output at 4 ohms is 200 watts and at 2 ohms, it's 400 watts. I could not find that it was 1 ohm stable.
If you are looking for the absolute best bang for your buck, I would highly recommend a pair of entry level MTX 10" subs, model 4501-04, currently priced by Crutchfield at $49.99. And if you buy a pair, they throw in a free Bass Slammer BS210S sealed enclosure. The MTX's power range is 112.5 to 225 watts each, right in there with your amps output. 2 of them in parallel give you a 2 ohm load, just right for your amps best power. And they sound great. You simply can't find a better deal for $100 bucks!
If you want a little better SQ, a pair of Rockford-Fosgate P1S410's should be considered. Again, going to Crutchfield, they currently have this one "BOGO" (buy one get one) for $99.99. You will have to provide your own box, though, no free one with these.
Finally, if you want the best SQ, and your budget allows, consider a set of Alpine SWR-1022D's for $179.99 each. These have dual 2 ohm voice coils, allowing you to series the coils and parallel the subs, resulting in a 2 ohm load to you amp just like the MTX's and RF's recommended above. You will probably want a somewhat larger enclosure for the Alpines as well as a fatter wallet. Your amp is right at the lower end for powering them, so they probably will not be as loud. But they will sound good.
One thing we haven't discussed is the box. The enclosure is just as important, perhaps even more important than the sub(s). More accurate bass is generally produced from a sealed enclosure. A ported enclosure will be louder, but at the expense of sound quality. And whether it's sealed or ported, the enclosure needs to have enough internal volume for the particular sub you are planning to use. A sealed box in the range of .75 to 1 cu/ft will be OK for any of the recommended subs. Add about 15-20% more volume for a ported box and keep in mind that the port needs to be specifically sized for the frequency for which it is tuned.
Hope this helps.
Posted on Apr 13, 2009
  • 506 Answers
SOURCE: which are the differents diagrams to wire two sub dvc 4 ohms
I guess this Amp is stable down to 2 ohms. 500 Watts X 1. Unfortunately there is no way possible for you to present a 2 ohm load to the output of this amplifier. Here are your options.
Speakers in series with VC in parallel = 4 ohm total Z
Speakers in parallel with VC in parallel = 1 ohm total Z (not good)
Speakers in parallel with VC in series = 4 ohm total Z ( Whats the point)
Speakers in series with VC in series = 16 ohm total Z ( Whats the Point)
So your best option to maximize power transfer from your amp to your speakers would be option 1. (Z = Impedance)
Posted on Dec 22, 2009
I have Sony xm-2165gtx amp 165 watt rms x 2 at 4 ohm 200 watt x 2 at 2 ohm 400 watt x 1 bridge output at 4 ohm stereo or bridge mono output 4 ohm stable in bridge mode this mean can't go lower then 4 ohm...
You can't bridge that amp onto a load lower than 4 ohms. So you can't bridge that amp onto two 4 ohm subs. To get the most power out of your subs is easy. Run one channel to one sub and the other channel to the other sub. 165 watts RMS is plenty for most subs.
Dec 05, 2013 | Car Audio & Video
Wiring a crossfire vr602 at 4ohm
OK what you are saying now is that your speakers are dual voice coil; models? 4 Ohms per Coil? I have always used single 4 Ohm Voice ciol speakers since amps are mostly based on 4 Ohm outputs. but you can get 8 Ohm dual voice coil subs also. With 8 Ohms per coil you can get 4 Ohms if you parallel the wires. What is best for you and will get you the most stable power and still will be in the specs of that amp is to run the amp in BRIDGED MODE running each subs voice coils in series with each other then run those 2 subs in parallel to the amplifier giving it a 4 Ohm load. So, your will have two sets of wires from your amp 1 for each speaker. Then you will take a short piece of wire that will connect the + to the - of each voice coil then hook up the wires from your amp to each sub What it will be is 4 Ohms + 4 Ohms = 8 Ohms per speaker the 8 Ohms in parallel each speaker to the Bridged amp output using just the + from one channel and the - from the other will give you a total of 4 ohms and power out put of 600 Watts so that ends up being 150 watts per voice coil or 300 watts each speaker
Apr 04, 2013 | Crossfire VR602 Car Audio Amplifier
How to wire a crossfire vr602 2 channel amp at 4ohm and 2ohm
I would be more worried about the amp than the speakers, those subs should handle the watts with no problem. The problem will be in the amps ability to remain working with a bridged 2 ohm load. It may not even stay on without going into protect mode with a 2 ohm load. If it does stay on then it may get really hot and shut off from the heat off of the Mosfett Transistors, or it could burn the Mosfetts from driving them too hard. Basically it's your choice, run your amp hard and gain more volume or run it with slightly less sound and have a cleaner sounding more stable amp that will stay on and have less chance of being damaged. If it's not loud enough the best thing to do is buy a different amp that better suits your needs and fits the application. In your case a 2 ohm stable Mono amp is going to be your best bet or a 4 channel amp bridged into 2 channels and run with 4 ohms on each channel. Or another exact matching amp like your 2 channel amp bridge them both and have each powering 1 of your 4 ohm subs. I used two VR mono amps to power my two 12" 4 ohm subs for a few years
Apr 03, 2013 | Crossfire VR602 Car Audio Amplifier
I have to hook up 4 amps in my car. 4 channel 700 watt ken wood, 2 channel 800 watt Sony, 4 channel 740 watt Jensen ,and a 2 channel Rockford fosgate. Which is best way to hook them up so I'm not ki
Pace posted on Saturday, March 05, 2005 - 01:08 GMT Your subs are dual 4 ohm voice coils so if you want to bridge your 2 channel amplifier to your two subs then wire them parallel, meaning the + to + and - to - ( Do this to both subwoofers), Then run a wire from one positive and one negative on each sub and bring the two positives together and the two negatives together and hook both positives to the far positive connection on your amp and connect both negatives to the other negative on your amp,
This will create a 4 ohm load on your amp.
Although if it's a two channel and you have two subs it's usually pointless to bridge them because if you use one channel per subwoofer its going to be the same as if both subs were bridged. example) 800 watts x 1 bridged power of your amplifie (4 ohms) is the same power as 400 watts x 2 at 2 ohms.
Nov 26, 2012 | Computers & Internet
Hifonics colossus-ltd dual monoblock amp does not have much output, running a cerwin vega stroker dual 2 ohm sub wired 4 ohm load bridged
Bridge at 4ohms your only getting 600watts rms. You will need to bridge at 1ohm (parallel) and adjust the gain accordingly. This will give it 1600 watts rms. If you would of had a dual 4ohm sub, then you could of bridged it at 2ohms mono, but you can't you have to go either 1 ohm or 4ohm. I believe it's not getting enough power.
May 20, 2012 | Hifonics Colossus-ltd Dual Monoblock 3200w...
JL Audio Amp. My amp all of the sudden started cutting in and out. It's an older amp and I've never had issues with it before. I've checked all the wiring and the fuse it all seems fine. Any...
you need to determine what impedance the amp is running at ,how many spekers ,most 2 channel amps will only run 2 4 ohm subs per channel and only 1 4 ohm speaker in bridge ,Basically if you have 2 4 ohm speakers bridged at the amp it will usually cut in and out .Some amps will not do this for a while and will work for a while at low impedance but once they get older and hot and cool off many times they will then only work for the intended ohm load ,Do you have 2 speakers ,if so make sure 1 is on left channel and 1 is on 2nd channel (should not cut off ) if it is a mono amp ,make sure you are only running 2 4 ohm subs and not dvc speakers (these will run 1 ohm and shut the amp down ) there are ways of wiring more speakers or dvc speakers ,I can explain but I need to know what product you have .
May 07, 2012 | Car Audio & Video
I have a 2 channel amp pionner gm 510t 760 watt and i have 2 subs how do i hook them up for the most kick and the hardest pound do i run them series or bridged or whats the best way ????
If you bridge it, it makes 2 channels one channel so you can only have it going to one sub. So you'd have to run them in series and have one sub per channel. If you want lots of bass you need to turn the gain up and adjust the settings on the head deck.
Aug 04, 2009 | Car Audio & Video
Sony explode amp cuts out after bass hits and over current light comes on. its a xm-2150 gsx and when no speakers are connected the light dosent come on
Start by checking and making sure that you have excellent connections at power,ground, and signal. Depending on the voltage output of your rca wires if you are running rca's to your amp typicaly your amp gain should be only at half - you may be clipping the signal if you have the amp set too high. On your deck you will want your bass settings at only half -again too much boost will cause clipping at the amp. with all your settings adjusted and all possible connections checked- the only thing left to check is the compatibility of your subs in relation to the amp-by that im referring to the overall resistance-measured in OHMS that you are placing on the amp.Your amp is probably rated at about 150wattsx2 at 4 ohms or 200+watts x 2 into 2 ohms or 400-460watts into a 4 ohm bridged load. Look on the magnet of the speakers and find out if you have single coils or dual coils and see what the ohms(resistance) of each sub (or coils) are rated at- ideally you would want a set of dual voice coil 4ohm+4ohm per sub- that way you can match the subs better with your amp.---- Heres a scenario that may or may not apply to you- i see it all the time so im going to share it with you---- If you have a set of single voice coil 4 ohm subs and you are trying to run them wired in parallel to the amp in bridged -then that is why you amp is shutting down- you will have to wire the subs in series until you either get different subs that will yield an overall 4 ohm load -or find a different amp that will take a 2 ohm load - okay for now try wiring the subs in series and see if it still sends out an overcurrent light on you-good luck
May 18, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp getting really hot
well it is getting hot due to the amp drawing and pushing alot of current. try getting lower gage wiring for power to the amp and lower gage speaker wire.
Apr 20, 2008 | Power Acoustik PS2-1200 Car Audio...
Wiring my subs to my alpine mrv-1000
did you read your instruction manual. does it says "it could be bridged to other amp"?. you can't make a bridge to amplifier that is not bridgeable. bridging an amp is a way which it is made through transistor type ampilfier by bridging more transistor inside and more voltage is required for bridging.
I don't know if we could do to an IC type amplifier. ask an experts about bridging IC types how to bridge maybe they know how.
and if you had an successful bridging, you may have a problem through your speakers, they may hit hard but you will experience some errors through your speakers and easy to worn.
Jan 22, 2008 | Pioneer GM-X962 Car Audio Amplifier
Kenwood KAC-9152D Car Audio Amplifier Logo
244 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
